-   Warbird Electrics (http://www.Wattflyer.com/forums/forumdisplay.php?f=50)
-   -   GUYS, i need your help. (http://www.Wattflyer.com/forums/showthread.php?t=68143)
wedoitall 09-28-2012 06:00 PM
im getting a t-28 trojan, very soon. i like the fms and dynam planes but then there is the parkzone model also. i really like the first 2 because they come with lights, retracts, flaps etc. but the only thing im worried about is finding parts. the parkzone model, looks like parts are aplenty, but not so much on the fms and dynam(at least not for me to find).
now im pretty much a noob, only been flying for a month. but i have several solid takeoffs and landings, so i think im ready for the t-28.
so my questions are:
  1. which brand would you guys recommend? if its fms or dynam where would be the best place to purchase plane and or parts for it (when i crash hehe)
  2. have any of you bought crashproofing from killerplanes?
  3. does flaps on the motor(like the fms brand) help all that much.
  4. after i get the plane, are their any recommendations on hop-ups and mods?
any and all help is greatly appreciated, cant wait to get my warbird *fist pumps, and figured your knowledge and expertise would benefit me greatly.
johnny o.
rcers 09-28-2012 06:14 PM
ParkZone - 100% better for you. Wait on the others until you have more airplanes under your belt. It flies better anyway. :)
There is no such thing as crash-proof.
Flaps don't help much for small lightly loaded models. In fact the weight and complexity they add sometimes makes the plane fly worse! On large heavy fast models they are sometimes almost essential. But the benefit to park fliers is very limited - other than cool factor.
The only "Mod" I did on the ParkZone was to increase throws - but you will be fine for now.
xmech2k 09-28-2012 06:17 PM
1) Can't help you too much here. I don't have a T-28, and looks like you have most of the +/- figured out. The other consideration is reliability. I've seen all these at the field. The FMS plane's rx was having brownouts probably due to overloading the bec with all those servos. It was also having plenty of nlg (nose landing gear) issues and mlg door sequencing problems. Dynam one seemed OK, I think he might have had nlg issues as well. The legendary PZ T-28, being the simplest, had the least trouble. The only thing I see wrong with those is the canopies falling off. If I ever got one, I'd add magnets to it.
2) Haven't seen it done, but seen their stuff. I'm sceptical about it, but that's just my opinion.
3) The cowl flaps are only eye candy. You understand on a full scale plane those are used for controlling airflow, and therefore, cooling of the engine. The guy having brownouts? I recommended he just unplug those and I think his brownouts stopped.
4) Search the threads out there. Plenty of T-28 stuff mostly involving speeding them up. Haven't seen much about the others, but then i haven't followed the threads on them. Hopefully others who actually own them will chime in and help out.
wedoitall 09-28-2012 06:48 PM
i have a spektrum ar6110e on the way(thanks to cheese pudin). do you think that would be better to use?
dahawk 09-28-2012 06:59 PM
+1 on Rcers comment. I have the PZ T-28 version and while the FMS and Durafly are sexier with more bells and whistles, the PZ T-28 is a brute. I've souped mine up with a bigger motor/esc combo and modded out the LG for bumpy grass fields. The weak point of the PZ is in fact the stock nose gear. If you like retracts, forget about grass fields altogether. And there's no free lunch on paved runways either. A hard landing on a paved runway will break the retracts.
Your LHS will carry parts for the PZ version. You'll have to wait on the boat from China to get parts for the others in most cases.
Good luck on whichever you decide. I love this plane !
-Hawk
Nitro Blast 09-28-2012 08:09 PM
Parkzone....
Hands down more value than the others. Reliable, out of the box solid, good support and nearly bulletproof.
Heres some reasons why:
(I'm the Jim in the "Jim's all over my tail" comment)
And some info about our racing series:
http://www.sefsd.org/index.php?optio...100&Itemid=110
I have seen many of the other brands come and go... what I see most of all however, is pilots having trouble with those other planes with all the fancy 'stuff'. Everything from gear failures, to sequencer failures, bad esc's, loud growly motors and more. Usually a couple of crashes, and you dont see them again. The Parkzone is solid reliable. If it crashes, its going to be because of your own thumbs, not some low budget electronic failure.
WayfaringDreamer 09-28-2012 08:13 PM
Retracts are problematic if flying off of grass. I went for the durafly and wish I'd gone for the Parkzone.
Turner 09-28-2012 08:17 PM
You would be far better off to choose one of the full range Spektrum Rx's for a plane this size.
xmech2k 09-28-2012 09:33 PM
The rx itself isn't the cause of brownouts, if that's what you're concerned about. It's too weak of a power supply to the rx. In this case, all these planes supply that from a BEC built into the ESC, which in the case of the FMS bird seems to be overwhelmed with too many servos from the reports I've heard, and the one I saw. The 4 regular control surface servos, 2 more for flaps, 3 gear, at least 2 for gear doors, then I think 4 for the cowl flaps. 16 servos! :eek: I can't speak for the range of that rx, never used one.
earthsciteach 09-28-2012 11:34 PM
I'll jump on the bandwagon, here - Parkzone! Pay the extra cash for a plane that will fly out of the box. RCERS nailed it with his recommendation of waiting to purchase the other brands you mentioned.
xmech2k 09-29-2012 12:25 AM
Nitroblast, did you have the racing clip where someone zoomed up out of them frame then came screaming back down, and the plane looked like confetti when it hit? I LMFAO at that one! I'm NOT saying the PZ planes are weak. They're TOUGH! (Ask my PZ Corsair...) Just loved that clip! I'm moving further north soon. May have to find a PZ T-28 and join you guys. Looks like fun!
wedoitall 09-29-2012 02:02 AM
hey guys , thanks for all the responses. you guys sold me, i had my "not so local hobby shop" (closest shop is 1hr drive one way-i live in the sticks)order a PK t28, should be here monday *fist pumps. i have a concrete pad i take off and land on, actually its prolly a scale aircraft carrier size pad. but i live on a 300 acre farm and was thinking about upgrade tires, to land in grassy fields also. what size is good? also would really like to get nav lights. are you guys using them if so where is a good place/link to get them.
Neko 09-29-2012 02:14 AM
Get some Dubro 2-1/4" low-bounce wheels for that PZ T-28. Makes it FAR easier to take off and land off grass. The provided wheels are too small and squishy. And some 2200 mAh 3S batteries. The model can handle the extra weight easily. But have fun. It's a great plane for learning with.
I have been flying mine for a few weeks now. Tore off the landing gear trying to land in 15 mph winds. Glued back on, took right off again.
dahawk 09-29-2012 02:35 AM
I replaced my gear completely with heavy duty gear taken off a hobbico trainer. You won't regret the Park Zone T-28. I'm running 4S now and she screams !
pattern14 09-29-2012 09:39 AM
Originally Posted by Nitro Blast (Post 883804)
Parkzone....
Hate to pour cold water on this. but pz is the reason I went to EPP scratchbuilds and S&B warbird kits. Guess you can't please everyone:p>
dahawk 09-29-2012 12:15 PM
Nitro,
You guys are having way too much fun out there ! I guess my souped up 4S T-28 would be disqualified, especially when I slap my big 4S Nano down on the table.:D
wedoitall 09-29-2012 03:09 PM
pattern: that vid is awesome. wish we had stuff like that around here. i race 1/5 scale 2 stroke bajas. had to build a race-track in the back yard, just so i could race. had to do some serious negotiations with the ol lady to get it done, but it is fun. but i live in the middle of nowhere so we dont have stuff like that, unless we make it.
would like to put the checker pattern on my wing, like the one in the video. is that paint? or a sticker
Nitro Blast 09-29-2012 04:59 PM
Those videos are just a teaser to how much fun we really have, and yeah, those are just stickers.
wedoitall 09-30-2012 02:29 AM
do you have a link for that hobbico gear?
WayfaringDreamer 09-30-2012 02:42 AM
Understood!
I've had issues with their micro bricks failing.
I'm new to this hobby but when I moved away from HH umx components I felt the same way as when I was a kid and upgraded from an all in one stereo to a component based system.
wedoitall 10-12-2012 02:42 AM
THANKS FOR THE HELP... the t28 and umt28 are awesome!!!!
just maiden both of my t-28's in the past few days and all i can say is wow!!!!! flew on 100 percent rates (think the sim has helped alot) with no problems and no buddy box'n. did almost stall on landing today, gotta remember to use rudder instead of aelirons. think i learned my lesson on that tho. but i love my new planes , thanks for all the advice and help.
Page generated in 0.48905 seconds with 18 queries
