-   RC Radios, Transmitters, Receivers, Servos, gyros (http://www.Wattflyer.com/forums/forumdisplay.php?f=68)
-   -   Unwanted interference mix (http://www.Wattflyer.com/forums/showthread.php?t=68901)
Dave180 12-04-2012 05:55 AM
Hi. I have a weird problem with my radio. I've been flying off and on since the '80's. I have an AMA 1991 gold label FM World engines Expert radio which has worked great till now. Currently, I'm flying a HOB Super Decathlon converted to electric.(10 years old) Everything works ok on the pre-flight ground check. I handlauch as it has a glider skid on it. It climbs great and flys great.
Here is the problem: At altitude, If I pull back more then 1/2 way on the stick, it immediately snap rolls to the right. It does it every time. Even with the motor turned off at speed. Less then 1/2 way, its just fine. Its like its a controlled mix. Its crazy.. I won't be flying it again till I figure this out. Actually I've done 3 flights with it like this. No more flights.
Any ideas of what could be causing this???
rcers 12-04-2012 01:41 PM
Yes - it is too much elevator control deflection. How much does the elevator surface move?
Dave180 12-04-2012 04:07 PM
Thanks for the reply. It moves 5/8" at full throw. I turned down the dual rate adjustment so its like 3/8" now. Somehow I don't remember it doing this before but its been awhile.
rcers 12-04-2012 04:36 PM
Give that a shot - many airplanes will do a high speed snap with too much elevator.
newjak 12-04-2012 05:22 PM
I'd also take a look at the structural integrity of the horizontal stab and the elevator itself. You said the plane is old. Some glue joints may have worked there way loose.
Page generated in 0.09152 seconds with 13 queries
