-   Indoor & Micro Electric Planes (http://www.Wattflyer.com/forums/forumdisplay.php?f=11)
-   -   Night Vapor battery (http://www.Wattflyer.com/forums/showthread.php?t=69222)
Yakfishingfool 01-04-2013 01:52 PM
Night Vapor battery
I just picked up a night vapor and see it comes with one battery, a stubbier version of the six or seven 1 cell's I have for my PZ champ and corsair....is there any possibility I can use the single cell champ and corsair battery, it is a bit bigger, in the night vapor? Or should I just go and pick up a couple more night vapor batteries. i know I can use the same chargers and I have an eflight 4 battery charger to use as well. Thanks. Scott
Heli Jim 01-04-2013 06:35 PM
I would think it would work fine, but it will
be heavier because it's bigger. Be careful of
the CG
Yakfishingfool 01-04-2013 07:39 PM
Thanks! I knew about the CG variable was wondering about the mAh going from 70 to 150 ish
bkvanbek 01-12-2013 09:18 PM
I have been using the 150s in my night vapor, I like the way it flies better with the 70. but the 150s work ok and are cheaper and I have many.
Heli Jim 01-12-2013 09:49 PM
It's like going from a 5 gallon fuel tank to a 10 gallon.
It is a bit heavier but that's all
Yakfishingfool 01-12-2013 10:23 PM
Thanks folks!!!
Pipemajor 02-17-2013 08:30 PM
I can get 10-12 minute flights on my Night Vapor with the stock 70mAh LiPo. That's plenty long enough.
I just ordered 2 additional 70mAh. Yes, they're more costly at $3+ a pop but I'll only need 2 or 3.
Page generated in 0.42305 seconds with 13 queries
