-   Indoor & Micro Electric Planes (http://www.Wattflyer.com/forums/forumdisplay.php?f=11)
-   -   Playmate motor/gearbox changeout....... (http://www.Wattflyer.com/forums/showthread.php?t=69227)
Bill Gibson 01-05-2013 06:59 AM
Just plain crazy about my Flyzone Playmate.....BUT, after many, many flights(and wrecks!)i ordered a motor/gearbox to replace the one that came with the plane...when i removed the original from the plane, i used an X-Acto knife to slice thru what appears to be a white, caulk like flexable adhesive that was used to "stick" the motor/gearbox to the nose of the plane...would anyone know what the white stuff is?? I just want to be sure not to use something that could attack the foam when i install the new parts in the plane....if acrlic/latex caulk will work, that would be fine with me! P.S. Working on these little planes is VERY unique.....my poor EYES!!:silly::Q Many Thanks!
TM4197 01-08-2013 09:22 PM
Hey Bill
The Playmate is awsome. I have changed out my motor 3 times already. I have used two types of clue to set it back in the craddle. I used elmers white glue with success..."let it dry all the way". I also used Gorilla Glue. A drop of water on the foam, and then a drop of glue on the mount. Dont use much, it will swell. Have fun!
Bill Gibson 01-12-2013 11:01 AM
TM, Thanks for the tips! Ill give it a go!!
Bill Gibson 02-24-2013 01:05 PM
TM, just wanted to let you know that after a couple of "learning errors"( hooked the motor wires up backwards!) the new gearbox/motor unit works GREAT in the Playmate....flys like NEW! THANKS!
flydiver 02-24-2013 05:39 PM
FWIW that was simple silicone caulk. It seems to work 'nicer' than glues. Sticks well but is removable. Glue can make a mess with future repairs if needed.
Bill Gibson 02-24-2013 09:48 PM
Thanks FD.... i thought thats what it looked like, but there are so many adhesives and fillers on the market today.....i actually used a coupla small drops of 5 minute epoxy as i was pretty sure it wouldnt attack the foam....just enough to hold it, but still remove if i NEED to.........!
Page generated in 0.04151 seconds with 13 queries
