-   Indoor & Micro Electric Planes (http://www.Wattflyer.com/forums/forumdisplay.php?f=11)
-   -   Moving electronics from on fuselage to another.....help needed (http://www.Wattflyer.com/forums/showthread.php?t=69384)
mattman0182 01-17-2013 03:55 AM
I am rebuilding the Champ. O ordered a new fuselage, motor, gearbox, and tail section.
My question is what is the best way to take the electronics out of the old fuselage? The factory had a pretty thick application of adhesive holding in the electronics.
Carefully use a hobby knife? Some sort of chemical?
And what should I use to fasten it into the new fuse? CA or epoxy?
I am hoping the electronics are still good. They have seen some use. The motor was pretty much done, which is why I got a new one.
Now I am wondering if it was even worth fixing up the thing, I mean it is only a Champ.
If anything this can be a learning experience.
Wildflyer 01-17-2013 05:20 AM
The adhesive is some sort of calking. I would pull it off the foam, then CAREFULLY cut or remove the stuff from the board. Don't damage any of the copper strips on the board.
I would use a latex calking material to stick the board to the new plane.
If you used epoxy it would be hard to remove and reuse the board again with out damage. There are some double side foam tape that might work, use a large enough piece to keep the board from rocking back and forth.
There are a lot of planes the 6400 can be used in, check Bob Selman designs.
http://www.bsdmicrorc.com/ I want the Micro Triton
mattman0182 01-18-2013 02:27 AM
Thanks much for the advice! All I have right now is foam safe CA and some epoxy.
I should for sure wait and get some caulk instead?
I noticed those motors in your link and I was wondering if they are more powerful than the one that comes in the Champ
BroncoSquid 01-18-2013 03:14 AM
That stuff they use is more like Silicon RTV than glue. I just carefully cut around the boards then used a hobby knife to cut most of it away. Then I used foam safe CA on the corners (so it is possile to remove again if needed) with no issues. This was done on a UM T-28.
RonR214 01-18-2013 05:38 PM
Be careful if you use a silicon RTV as some of them can damage the electronics. The acid in the RTV will do a number on the gear.
Ron
mattman0182 01-19-2013 12:36 AM
Think I will just use the CA or maybe even just a little epoxy/
hayofstacks 01-19-2013 01:08 AM
Or some velcro.
mattman0182 01-19-2013 01:43 AM
Right now it is sitting on double sided tape. May CA a little on the edges.
hayofstacks 01-19-2013 03:19 AM
I bought about 6 feet of velcro while I was shopping at walmart. My esc's are covered on one side, and my fuse in another. When you get your cg set and where you want it, put a drop of ca on it so it won't come off. Done deal.
mattman0182 01-19-2013 03:59 AM
Wow I did not even think about the velcro but thats a great idea. I already got her back together though. The old electronics and new motor are working fine. Now when i get a chance ill see if she flies lol.
mattman0182 01-22-2013 03:58 AM
Went to the park today to fly her for the first time after the rebuild. It was pretty windy, but went very well. She struggled in the wind, but the flight went well.The g is good as are the controls. I am very happy with my firs rebuild.
Only downer is I could not get her to bind with the DX6i.
Page generated in 0.12720 seconds with 13 queries
