-   Sport Planes (Formerly I/C & Gas Conversion) (http://www.Wattflyer.com/forums/forumdisplay.php?f=20)
-   -   Prop Location For Pattern Plane Conversion (http://www.Wattflyer.com/forums/showthread.php?t=69485)
paxskipper 01-24-2013 02:28 PM
Hello,
It looks like my next plane will be a pattern plane conversion from glow to electric.
My question is related to mounting the motor. I assume that I should mount the motor so that the prop would be in the same location as it would have been had an engine been used. I assume that the distance from the prop to the wing makes a difference for a pattern plane.
Thanks in advance
rcers 01-24-2013 02:34 PM
Yes it should follow the exact same line as the other engine for the same characteristics. Same angles as well - but suspect it is 0deg/0deg as most pattern planes are.
But again you should NOT change the thrust line due to electric - the plane has no idea what is spinning the prop anyway. :)
Page generated in 0.07592 seconds with 13 queries
