-   -   Aerobatic pattern model - small to mid parkfly size (http://www.Wattflyer.com/forums/showthread.php?t=70038)
solentlife 03-06-2013 07:51 AM
I've looked at various plans with a view to a precision aerobatic pattern model .... but nothing has really stood out and made me think - YES I MUST HAVE ! ...
Anyone with a recc'd plan link for such ?
Thoughts are :
Mid-wing
Long fuselage moment
Straight parellel chord wing ... or limited taper / sweep
Long / large fin
~1000mm span
Suitable 8x6 prop range motors
Capable of carrying 1800 - 2200 3S LiPo
rreid7 03-06-2013 12:45 PM
The humble GWS Formosa is close to what you describe. Inexpensive, easy to build and can accept quite a range of power options. With a few simple modifications like dual ailerons in the wings, it is quite a commendable little sport/pattern flyer. My first one was mostly stock, with a PowerUp 400 Sport from HeadsUp RC spinning a 9x6 on 3S 1500MaH. The second one uses the PowerUp 400 Speed, a 6x4, and 3s 2200Mah. This one has dual ailerons, rudder and elev servos moved back to the tail, and larger than stock ailerons, plus a few other minor things. Flies fast and crisp, rolls can be nearly eye blink fast, with sharp start/stop control. The airframe kit cost $35 US.
I don't own any GWS stock, I just like simple inexpensive things that work. If you are interested I have more about the modifications and flying performance of the Formosa on my website, including recorded flight data.
rcers 03-06-2013 01:19 PM
Mid wing is tough. This is the only one I can think of in that size...
Leader 480
http://www.horizonhobby.com/products/leader-480-EFL3000
Review:
http://www.rcgroups.com/forums/showthread.php?t=1501546
rreid7 03-06-2013 01:36 PM
I just remembered BMJR Models has these classic pattern models, resurrected and reduced to parkflyer size:
http://www.bmjrmodels.com/shop?page=...category_id=31
dahawk 03-06-2013 01:54 PM
rreid7,
Thanks for your Mosa input. Would like to see your website.
I was one click away from ordering the GWS Formosa II from Heads up and they ran out of stock. They were asking $50.00 for the kit with uber low shipping charges as usual. I too think cheap.
Would like to know how difficult it was to make room for a 2200. Also, still not 100% sure if my 2820/07 Emax would be overkill. Had it in a PZ-T-28 (RIP) and would like to re-use.
Thanks,
rreid7 03-06-2013 02:14 PM
dahawk,
Fitting a 2200 batt into the Formosa is just a matter of enlarging the battery compartment as needed before gluing the fuselage halves together. I use a #11 and a chisel blade X-Acto to carve it out for a snuggish slide in fit. Piece of cake.
Bill G 03-06-2013 02:39 PM
2 Attachment(s)
One just came to mind that I say years ago called the Pacifique.
The site is still up, and the plans appear to be there for downloading.
http://plans.am.free.fr/
http://plans.am.free.fr/plans/pacifique.jpg
solentlife 03-06-2013 11:09 PM
Why the specs I posted ?
I flew Curare ... Magic many years ago and found the combo to be smooth and neutral whichever way up ... But they were IC 60 + pipe powered ... and much larger than what I propose here.
The Formosa was one I looked at ......... Badius as well ....
stevecooper 03-07-2013 02:55 AM
5 Attachment(s)
FormosaII,,,I just leave the Batt hatch off and stuff a 2200 in there with Velcro strap's 5 years and never lost a lipo:rolleyes:, Great airplane, bubsteve
pmullen503 03-07-2013 03:49 AM
Here's another that might fit the bill. http://www.rcgroups.com/forums/showt...hlight=edg+540
solentlife 03-07-2013 12:43 PM
I have the HK 800mm 540 Racer Edge ... and I like that - so good link ...
rcers 03-07-2013 02:53 PM
Awe no love for the Leader? The other planes are not really suited for precision pattern flying (more IMAC).
I too don't really love the looks of the Leader but if you can go bigger the new Splendor looks AWESOME!
http://www.horizonhobby.com/products...ology-EFL10250
If you go just a bit larger there are several great choices though. Oriris from 3DHS, Sequence from GP and several others. Is your size requirement strict?
Oriris:
http://www.3dhobbyshop.com/Pattern-Aircraft_c_270.html
Sequence:
http://www3.towerhobbies.com/cgi-bin...?&I=LXWWM1&P=7
Dereck 03-07-2013 03:14 PM
Hi Nigel
One plan I've got - an internet download that's all over the shop - is the CADKaos. It was drawn by Jerry Yarrish, who is connected heavily with Model Airplane News magazine, from Joe Bridi's design. It's actually a 58" span, but I could downscale it to whatever you want and change it to jpg format, unless you do CAD and could work with the original.
It would meet most of your requirements bar the mid-wing and has a precision aerobatics pedigree. I'm building a large scale model based on the plan, to 50" span for an OS 25 motor and 4S/3300 battery right now.
D
solentlife 03-07-2013 03:15 PM
The size req't is not strict but dictated by circumstance ... flight sites / transport etc.
I realise that Ultimates / Edge etc. are not precision aerobatic jobs like Curares etc. but they do look good !!
If it was not for difficulty in obtaining Glow Fuel and also costs - I'd love a Pattern 61 model from 1980's .... but Latvia is poorly served for Glow ... and a gasoline equivalent is too heavy.
rcers 03-07-2013 03:43 PM
How about smaller?
Taurus:
Perigee:
Orion:
And.....for some other classics. How about the Phoenix Mach One or the Curare! :)
http://eurekaaircraft.com/eac_kits/babykits.htm
These are smaller than you wanted but close.... Likely a 1300-1800 3s or maybe a small 2100/2200.
Neko 03-08-2013 01:46 AM
About to try my first flight on a World Models Super Taiji. A hair larger than the Osiris 47 and the Extreme Flight Vanquish.
http://www.airborne-models.com/html/...?ProductID=155
The Osiris and Vanquish are both great, but neither is available currently.
cyclops2 03-08-2013 11:51 PM
Go to the American A M A plans site. They used to have LOADS of Pattern / stunt planes. Some were contest winners.
Have not been to the plans section in years.
cyclops2 03-08-2013 11:59 PM
The A M A plans service has some Patterns from 1975 foward.
Give the site a try.
solentlife 03-09-2013 12:28 AM
I went back to Outerzone ... and downloaded Prettners Curare and the mini Curare20 ............ will have a look at what can be done with them in foam ... with wood doublers / stiffeners etc.
Tks to all who took time to reply ... valued and archived !
Bill G 03-10-2013 09:05 AM
I searched outerzone and couldn't find the Prettners Curare and the mini Curare20. Do you have a link to them for outerzone?
The Pacifique I posted a few posts back has been gaining my interest as I look at it more. I think it's a good looking model.
solentlife 03-10-2013 10:35 AM
I assume you are registered with Outerzone / Hip-Pocket ? The plans are in the Aerobatic section .. about 7th page I think. I just browsed through looking for a candidate and found them.
http://www.hippocketaeronautics.com/...t_id=34&page=6
then
http://www.hippocketaeronautics.com/...t_id=34&page=7
solentlife 03-10-2013 10:59 AM
That I like ! Parellel chord wing - so simple to build etc.
But went on the site - but cannot find it.
solentlife 03-10-2013 11:00 AM
If you can find it - can you paste a link direct to it or the plans ? I went on the site you said - but cannot find it.
Bill G 03-10-2013 09:16 PM
The entire site is only one page. Just scroll down a bit and you will find the photo.
edit: I just tried it, and it took me about 3 seconds to scroll down and find the photo on the right. It is one of the few photos listed, so it makes it really easy to find.
Originally Posted by solentlife (Post 903606)
I assume you are registered with Outerzone / Hip-Pocket ? The plans are in the Aerobatic section .. about 7th page I think. I just browsed through looking for a candidate and found the plans.
Trying to make me think I'm losing my mind there Nigel? :Q You mentioned only Outerzone, and not Hippocket. That's why I couldn't find them. There is no Outerzone/Hippocket site, as they are two entirely different sites. There was no mention of Hippocket:
dahawk 03-10-2013 10:51 PM
BillG,
I found them, no problem: http://plans.am.free.fr/, but I believe you'll need a-cad or an a-cad viewer. Viewers are easily downloadable. The other thing is French. I cut and paste into google translate.
-Hawk
Page generated in 0.11713 seconds with 13 queries
