-   Scale E-Powered Aircraft (http://www.Wattflyer.com/forums/forumdisplay.php?f=18)
-   -   Balsa Repair Advice (http://www.Wattflyer.com/forums/showthread.php?t=70070)
earthsciteach 03-09-2013 07:59 PM
Balsa Repair Advice
I maidened my Maxford USA PT-17 in very windy conditions last weekend. Now, I am in the process of repairing. :rolleyes:
I have two damaged ribs on one wing that I need to access through the covering. I have no experience working with covering, so I'm seeking advice.
Can I somehow detach the covering from the wing and reattach or do I cut and patch the particular area I need to access?
Thank you!
gramps2161 03-09-2013 09:28 PM
You are going to have to cut and patch to fix the ribs. Just had to do that myself to a plane. I don't know what they use for glue with the Maxford but check out the glue joints on the fuselage also. Mine was a easy crash, but i was surprised on how many glue joints popped in the fuselage even though wing looked like it had the most damage.
Mine was a GP Electric Stick they use a glue that almost resembles hot glue that doesn't hold well.
earthsciteach 03-09-2013 11:01 PM
Thank you Gramps! I've cut open the wing and CA'd the ribs back together. I'm going to scab the two broken ribs with thin balsa. I'll give the fuse a good check - I definitely appreciate your advice!
gramps2161 03-10-2013 12:53 AM
Now the key question is can you find the correct color covering to match the original one. Hardest thing to do with some of these ARF'S is finding a matching color.
earthsciteach 03-10-2013 03:46 AM
Yep, that is my concern. Looks yellow to me, but which shade? Argh!
CNY_Dave 03-10-2013 04:48 AM
Oh man, one thing about bipes, you get good at repairs... :)
solentlife 03-10-2013 11:39 AM
My way is to carefully slice the covering and peel back. Bit of tape to hold it out of way.
Take thin balsa or thin foam and create a doubler to sit alongside the broken rib ... glue in place with white PVA glue. I only use CA as a last resort - it makes for an brittle repair.
Once set - I then lay covering back with a narrow section of clear tape upside down .. a piece of masking tape on top to allow me to pull the covering before sticking down to the clear tape. Do for both sides of cut - often you can get the edges to meet again and a quick waft of hot air over and bingo.
If not - then a patch of same covering with no sharp corners ... best is the oval shape ...
The old trick was of course to add another Decal ! to cover it up. ;)
Page generated in 0.11470 seconds with 13 queries
