UM T-28 Maiden.
Hi!
I just now maidened my UM T-28! Here is pretty well how it went: After sitting there still too nervous to launch, I finally hand launched it (No good place to really take off in a grass field :p>.) and it went up waaay too much and stalled out. Took a look at it, and my CG was way off. Adjusted the CG, and tried again. Same thing happened this time. Not sure what happened there. Then, finally, I had a successful launch, and flight. I was surprised at how well it handled, even in the slight breeze we had. Landing went prefect, and had 2 more flights just like that one before my battery drained. Now I guess I had a little question. It sort of "bobbed" up and down as it flew, any idea what could have caused this, or how to fix it? |
you mentioned "slight breeze". even this will affect the um planes pretty well. mine would "bobble" around flying into the wind, but flying with the wind it was smooth. i think when i would fly into the wind the plane would climb and i would push the stick to try and keep the plane level, thus i was causing the bobble.
i've flown the um t-28 in around 10mph winds and its a handful. fun once you get confident enough to do it, scary as all get out if your new to flying!! congrats on the maiden flight!!!! |
Thanks.
I guess it's just a little sensitive to the wind compared to my champ...I can usually pilot my champ in up to about 6 mph winds and still be able to keep it airborne and on a general flight path. I guess I could have thought and figured it out, just sort of used to my champ, I guess, so I wasn't expecting the bobbing effect so much. |
Update: I flew it again today! However, I did have to wait the whole day for the wind to die down. I had a nice first flight, practicing keeping it nice and steady, and had a nice landing. Second flight was absolutely beautiful, I kept it very level and had some nice turns. Third flight was interesting... I ended up losing orientation of the plane (it was getting a bit dark outside.) and then cut the throttle, and promptly hit the branches of a tree, thank goodness it didn't get stuck, but just took a fall. The only damage was some paint chipped off the cowl and a *tiny* bit of crumpled foam in the same spot.
That was my flights today in a nutshell... |
lol, it seems that trees just love to eat planes!! i swear they will jump right out in front of a plane to get a bite.
I know right? Not the first time one of my planes had a run-in with a tree. My champ got a face full of branches once as well.
The 'bobbing' up and down sounds like it's maybe flying in a series of climbs, stalls and dives (looks like a roller-coaster?) that's often simply due to not being trimmed out properly, you may just need some downtrim?
Yeah, figured that out yesterday. I noticed when I came in for a landing it acted just a bit tail heavy, so I figured it had too much up trim on the elevator. Thanks for trying to help anyways!
I think the small spool of 30ga. wire was the most expensive part. 12$ IIRC. 3mm LEDS were 1 or 2 bucks for a pack of 3. I got red, green, white, and blue. A small pack of 100 diffrent size resistors was like 5 bucks. You could do it with a basic soldering kit. I set it up on a breadboard to make sure it worked.
Oh, side note, tape a length of .060 CF rod down the center of both wings. Keeps the wings from cracking during rough landings and chance encounters with trees. |
Sorry didn't respond earlier, I'm on vacation and I've been busy. Anyways, I really want to have one of those LED setups, but, I didn't think about having to use a soldering kit... Because, I don't have one. How much does a soldering kit cost? I don't want anything fancy just one that'll do the job. Thanks!
| All times are GMT +1. The time now is 12:40 AM. |
