-   Electronic Builders Workshop (http://www.Wattflyer.com/forums/forumdisplay.php?f=32)
-   -   Airbrake hinge (http://www.Wattflyer.com/forums/showthread.php?t=70156)
p3arljam 03-17-2013 04:20 PM
Airbrake hinge
1 Attachment(s)
I'm designing an airbrake for my T-28 it will be made of balsa or lightweight plastic. Its going to be approx 1X1 inches my question is how or what can i use to hinge the opening flap to the framed square ? The picture i have posted is a side view and it will be inserting it into the bottom of the aircraft.
CrimzonRider 03-17-2013 05:03 PM
found this... pics of a large rc scale, pics showing hinge and speed brake about half-way down the webpage.
http://www.largescaleplanes.com/arti...le.php?aid=101
just some more cool pics...
http://www.grubby-fingers-aircraft-i...alkaround.html
cr
p3arljam 03-17-2013 05:36 PM
Thanks CR good pictures hows everything going?
fhhuber 03-17-2013 06:19 PM
You can just use any common CA hinge... or if you want more scale operation find the correct pivot line and glue a piece of tubing to the airbrake on that line. Tape the airbrake into the model's structure and install a piece of music wire (or even a toothpick) through the tube into whatever type of support works. (1X1 inch isn't going to give much load)
Be creative... there are probably dozens of ways to do it.
Page generated in 0.10817 seconds with 13 queries
