-   Electric Ducted Fan Jets (http://www.Wattflyer.com/forums/forumdisplay.php?f=12)
-   -   Help help (http://www.Wattflyer.com/forums/showthread.php?t=72749)
ahodges 12-08-2013 03:35 AM
Help help
Low & high rates & expo elevator & airlons would not pull up on low rate 50% & 60% expo and she went into the ground on maiden all repaird but I need advice on this rates to give me half descent controll on low rate guys I'm running 4s 1800 mah as far forward towards the nose in battery compartment does it have to come back a little if so how much or is it sweet there any help from you guys would be great cheers Aaron Melbourne Australia :confused:
waytooslow 12-08-2013 03:56 AM
what kind of EDF? Its makes a difference
ahodges 12-08-2013 03:58 AM
Thanx for reply
Stinger 64 mk2
ahodges 12-08-2013 04:03 AM
Rates & expo for low & high
Originally Posted by ahodges (Post 933493)
Stinger 64 mk2
Was screwed on low rate & expo was 50% &60% expo & she would not pull up and went into ground
waytooslow 12-08-2013 04:12 AM
pop over to the stinger thread -- you will get lots of help (I have replied there)
ahodges 12-08-2013 04:17 AM
Cool
Will do:$
ahodges 12-08-2013 04:18 AM
Will be happy if she fly ok on these rates that's all I want cheers
kyleservicetech 12-08-2013 06:06 AM
Don't know about a lot of wattflyer readers out there, but I learned my lesson on those Expo settings during a maiden flight of a giant scale model several years ago.
The problem was, the expo was set at 40% or so. And, the elevator was so far out of kilter, even when the elevator trim was run to full up trim, the model still dove for the ground.
So, the model had to be flown while holding up elevator. And, that elevator was in the expo region, so just slightly moving the elevator stick up or down resulted in wild airplane climbing or diving. The model was landed in one piece, but the pilot learned a few new swear words in the process.
Ever since that flight, all of my maiden flights have been with zero expo. After the model was trimmed out, then expo was added as needed for reasonable flight control.
ahodges 12-08-2013 06:09 AM
Thank you
I've taken expo out on low rate elevator & at 60% rate so hopefully it mite be a little more forgiving
xmech2k 12-08-2013 06:59 AM
Double check your cg too.
ahodges 12-08-2013 07:03 AM
Cg stingrer 64mk2 4s lipo 1800mah
Went buy the directions nose heavy but not sure how far to put battery back boys???? Any ideas:eek::confused:
xmech2k 12-08-2013 05:04 PM
Put the battery wherever it has to be to get the correct cg. You did balance it with the battery in it, right? (Sorry to ask, but it's been done before. ) If it's still nose heavy with the battery as far aft as it can go, you may have to resort to adding weight in the tail.
ahodges 12-08-2013 09:17 PM
Ok
Hi followed instructions & def, nose heavy been advised move back 10mm, from aft see how that goes cheers mate
Page generated in 0.09037 seconds with 13 queries
