-   -   Retracts and fitting legs ... (http://www.Wattflyer.com/forums/showthread.php?t=72765)
solentlife 12-10-2013 02:26 PM
I have these style servoless Retracts ... and they work nice ...
http://www.hobbyking.com/hobbyking/s...m_1pc_54g.html
Mine are a little smaller than those ... and I intend to fit 2 as main U/C on tail-dragger.
My question is this ... having had retracts before on a few models - I always had trouble keeping the wheels aligned and stopping the leg from turning in the mount. I tried grinding flats ... everything ..
So how do you guys keep your retracts from having legs turn ?
I want to fit either to my new Pattern flyer or if not enough depth in wing - to my Mig 3 ...
dahawk 12-10-2013 04:50 PM
I do the same thing in terms of milling or grinding a flat with a Dremel tool. But I also grind the base of the grub screw flat. So , flat on flat.
-Hawk
CNY_Dave 12-10-2013 05:35 PM
On my retracts I add a tiny bit of CA after the set screws are tightened, I then heat the leg a bit if I need to remove it.
My retract body is metal, so your mileage might vary with that method.
I use axles that slide onto the strut and attach with a set-screw, a drop of CA down the leg is a must with those.
solentlife 12-10-2013 07:00 PM
-Hawk
Now never thought of that ... flat on flat ...
mmmm and CA - not my favourite ... but when needs must ...
CNY_Dave 12-12-2013 12:00 AM
The grub screws I have run into aren't pointy, and aren't flat, they look like a pointy cone that then has a hole drilled in the end, so the end surface that touches is a ring.
That makes sense for deforming metal a bit to help keep it tight, but flattening it would provide more resistance to torque deforming the mating surface and causing it to loosen.
Now if they could just fit a collet or a ring that tightened around the gear leg...
kyleservicetech 12-12-2013 12:07 AM
From my experience, CA and screws is permanent. If it should deform the metal and come loose, methinks there is no way to re-tighten it.
Be sure to really clean everything first with pure alcohol, not that 80% alcohol - 20% water stuff found in the local drug store.
solentlife 12-12-2013 07:23 AM
My plan actually is probably Red Loctite ... or maybe test with Blue before committing to permanent stuff.
The retracts will rarely be used in fact ... most time be retracted and model hand launched. But I want them for when do the Public Shows at the airport ... and maybe other venues.
CNY_Dave 12-12-2013 02:21 PM
Whoah, no CA on the screws! Just a tiny bit where the strut enters the fitting... CA will loosen with heat easier than loctite. It gets nice and gummy at a fairly low temp.
Still might be a bit high for a plastic housing.
solentlife 12-12-2013 02:54 PM
Phew !! was getting worried there !!
Shame I don't know the actual leg size for my e-tracts ... otherwise I'd order a nice pair of oleo sprung legs !! Couple of Tina Turner jobs !!
Panther 12-13-2013 10:47 AM
Just got these Oleos today for my BAE Hawk. They are really well made for only about $14. Not using retracts though. I just cut off the original legs a bit.
Gonna get some more for my little PC9
https://www.hobbyking.com/hobbyking/...dProduct=11300
http://i1093.photobucket.com/albums/...ps85f5aa1d.jpg
http://i1093.photobucket.com/albums/...ps4055e0f8.jpg
solentlife 12-13-2013 10:50 AM
Yes ... nice - I've been looking at them myself ...
KeninAZ 12-28-2013 03:05 PM
Yep, they make many types of Loctite from removable (with some effort) to nearly a weld condition. Pick your application, been using the stuff for years and learned about it at work.
Page generated in 0.10555 seconds with 13 queries
