-   Foamies (http://www.Wattflyer.com/forums/forumdisplay.php?f=9)
-   -   4mm Prop Adapter (http://www.Wattflyer.com/forums/showthread.php?t=72815)
thepiper92 12-16-2013 08:04 AM
4mm Prop Adapter
Does anyone know where to get a 4mm collet adapter with a screw hole on the end to mount a spinner. I recently ordered a spinner, figuring it would dress the plane up a bit, but now I am runner a motor with a 4mm shaft and this spinner has a 3.2mm collet. Is it possible to make the 3.2mm collet into a 4mm without destroying it?
This is the spinner I ordered:
http://www.hobbyking.com/hobbyking/s...dProduct=14815
solentlife 12-16-2013 08:21 AM
It is highly unlikely that you can get a 4mm collet to fit the 3.17mm spinner back-plate. It will pass through the threaded part - but it will not slide back enough on the taper ..
Sorry but you will have to source a 4mm adaptor / spinner combo. Keep the 3.17mm one aside - it's a very common shaft size.
hillbille 12-16-2013 11:02 AM
Simple fix. What you need are some of these:
http://www.hobbyking.com/hobbyking/s...s_M6x1_M4.html
http://www.hobbyking.com/hobbyking/s...s_M7x1_M3.html
The M number is the thread size on the adapter side.
The X1 is the length of the nut overall.
The _M number is the thread size on the SPINNER side.
The one thing you will NEED to know is the THREAD size of your adapter - if you don't know what it is, the simple solution is to take the adapter part to a hardware store and go to the small parts department and try nuts until you find the one that threads onto it - and then you will know the correct size you need.
That second "m" number is kinda important too because if the original used a 3mm bolt then you do NOT want one that uses a 4mm as you don't want to enlarge the hole in the end of the spinner - it won't work then. LOL!!
Good luck!
Hillbille
solentlife 12-16-2013 12:03 PM
Good luck!
Hillbille
?? How is a thread adaptor nut going to help him fit a 3.17mm Collet to a 4mm Shaft ?
He needs a 4mm collet ... because his shaft is 4mm ...
hillbille 12-16-2013 08:22 PM
LOL!! Nigel - of course you're correct - it won't help at all! I was up late and for some reason my powers of reason were not functioning! LOL!! This sometimes happens to us old guys - and we mumble a lot too.
Hillbille
solentlife 12-16-2013 08:24 PM
Hillbille
No problem - I tend to drop food down my front as well !!
hillbille 12-16-2013 08:28 PM
I think I was thinking about him using an adapter he ALREADY had that would fit the 4mm shaft, BUT did not have the retaining threaded hole in it's top. THAT'S when one of these babies comes in handy.
Of course I didn't say that either!! LOL!! It was a long day!!
Hillbille
Page generated in 0.14713 seconds with 13 queries
