-   -   Multiplex Dogfighter (http://www.Wattflyer.com/forums/showthread.php?t=73108)
jobu 01-31-2014 09:39 PM
I was looking at getting a Dogfighter and was wondering if anyone had good input about the plane and what a faster setup for 3s would be?
Thanks,
Joe
ps. not sure what category it falls under so I put it in gen discussion
CHELLIE 02-01-2014 12:41 PM
Tower hobbies sells a nice Hi Performance power system for the Dogfighter. If you used a 9x8 or 9x9 apc prop, rather than the 10x7 Prop with this power system, i think it will be plenty fast, check your amp draw with a Wattmeter
http://www3.towerhobbies.com/cgi-bin...?&I=LXBCKH&P=V
http://www2.gpmd.com/imagel/m/lmpum9250.jpg
This is the Power Pack for the Dogfighter Airplane from Multiplex. FEATURES: All power components needed to fly the Multiplex DogFighter
INCLUDES: Himax HC3516-1350 Outrunner Brushless Motor Castle Creations 54 Brushless ESC APC 10x7E Composite Propeller Prop Adapter with 0.79" (20mm) Aluminum Spinner Nut Motor Mount, Standoffs and all Mounting Hardware
REQUIRES: Three 4mm Female Bullet Connectors (GPMM3119) to connect ESC to motor
SPECS: ESC; Max amps: 54A Max volts: 15V, 3S LiPo, 10 NiCd/NiMH BEC: Linear regulator, 3A max Length: 2" (51mm) Width: 1.15" (29mm) Height: .04" (10mm) Weight: 1.2oz (34g) Brake: On/Off Motor; Max Power: 350W depending on several factors Max RPM: 20,000 RPM Diameter: 1.39" (35.2mm) Length: 1.66" (42.2mm) Shaft Diameter: .1969" (5.0mm) Mount Screw Thread: M3, max depth 5mm on 25mm (1.0) circle Maximum Case Temperature: 149F (65C)
CHELLIE 02-01-2014 01:33 PM
1350 kv motor x 11.1 v = 14985 rpm + 8 pitch prop = 114.5 mph prop pitch speed - drag + voltage drop off.
with a 9 pitch prop = 127 prop pitch speed - drag and voltage drop off.
http://www.pgam.ca/airspeed.htm
The form below will calculate the speed at which a propeller will move through the air at a given RPM and Pitch. This will give an approximate top speed and can help you decide which prop to use for a plane. For example if your airspeed calculates to 150 MPH and your plane is a Lazy Bee, then you've got the wrong prop on your plane because there is now way that plane will do 150 MPH. (Slight exaggeration, but you get the idea.)
Flubber 02-01-2014 03:25 PM
Hi Joe
My dogfighter uses the motor that Jeff at Heads up RC recommends and lists with the plane.
You can use different props to modify the speed and amp draw. I started with an 8 x 4 and hand launching was so easy.
Tried an 8 x 6 and it was awesome but pulled alot of amps. Now I am flying a 7 x 6 and it really moves. The smaller props are good for belly landing.
This really is a great flying plane from hand launch to ballistic and back to slow for landing. One of my favorites. It loves to do really big loops.
jobu 02-01-2014 03:58 PM
Thanks to both of you. I've put it down for a while but thinking of getting back into it. I was flying fast Strykers but looking for a simple fast plane that flies and looks better than a wing.
Page generated in 0.03794 seconds with 13 queries
