-   Scale E-Powered Aircraft (http://www.Wattflyer.com/forums/forumdisplay.php?f=18)
-   -   PA-46 Twin Comanche (http://www.Wattflyer.com/forums/showthread.php?t=73156)
chardesa 02-08-2014 01:29 AM
PA-46 Twin Comanche
2 Attachment(s)
This is another of my conversions to electric flight since I gave up on glow and gas 40 years ago.
As some of you may know I was looking for a Top Flight C-310 which is out of production and stumbled on this Seagull Models PA-46 Twin Comanche. Not quite the same caliber as the TF 310 but acceptable for my twin project this time. It took me a while to figure out how to get pictures up, since this Wattflyer program is actually broke in that department, so I am stating back at the begining. So hang in there.
Opening the box things were packed nice and everything seperatly packaged. The parts count was as stated so we started.
First there have been questions here and there about servo size for some of Segulls kits so I played it safe and did not order any until I could see for myself what was needed. In this kit they are all standard and also for the K8-B sailplane which I have built. So I sent my order in to Horizon Hobby.
CHELLIE 02-08-2014 03:29 AM
Wow, Thats a big plane :ws: Good luck to you on the build, Chellie
DEG 02-08-2014 04:39 AM
Nice project....will be following along...
dahawk 02-08-2014 01:05 PM
I love it. Seagull makes some nice stuff. My big twin is the eflight Deuces Wild that I bought used. It has Scorpion 710's. Going with G-46's ?
Always liked the Piper twins. Aztec and Seneca
I can't understand why these RC mfg.'s discontinue these beautiful planes
Following.
chardesa 02-08-2014 02:46 PM
Did you notice on the box cover it said "ALMOST READY TO FLY", now that is a very loose statement for this model which did not come with any electronics installed or motors and lots of parts that needed to be glued on.
Chardesa
dahawk 02-08-2014 02:58 PM
Not unusual for planes like this. Add motors, esc's servos and it's 2x. But also, it provides flexibility of choice.
The PNP versions sometimes include stuff you end up replacing / upgrading anyway.
rcers 02-08-2014 03:01 PM
Chardesa
Chardesa - that is exactly the definition of ARF. That means the plane is built, covered and ready to add your components and do general assembly.
RTF = Ready to fly is what you want if you don't want to do any of that work. Even then - you will usually have to bolt a thing on here or there.
This looks like a nice plane....has me thinking about one!
chardesa 02-08-2014 03:06 PM
Yes sir, been there and done that.
chardesa
chardesa 02-08-2014 03:25 PM
3 Attachment(s)
Since I did not have servos or motors to install I started working on the tail feathers and anything else to make ready for the installation of the servos.
So I mixed up some 30 minute epoxy and put the Vertical and Horizontal stabalizers on. NO screws here just fitting and glueing. By the way it is a very good idea to dry fit everything prier to glueing as I will tell later of a goof I found by the model maker. Alignment of the horizontal stab is very important and a little more dificult without the main wing on for a referencs point. Using the slow epoxy gave me time to check this.
I give you a couple of pictures of the cockpit just as it came out of the box. I am impressed! Is this what they mean ready to fly.
Since I had one standard servo on hand I fitted it to all the servo positions in the fuselage and wings and pr-drilled all the screw holes.
I am waiting for 4 Hi-Tec HS-5645DMG and 2 HS-645DMG servos, 2 60 Amp E-flite ESC, 2 Power 46 E-flite motors and a set of 60-120 electric tri gear retracts.
chardesa
gramps2361 02-08-2014 04:14 PM
Chardesa that's a sharp looking twin be following along on the assembly.
Another definition of ARF is ARM (almost ready to modify) found that out on a few ARF's I have bought over the years.:)
chardesa 02-08-2014 04:30 PM
Yes id deed, been there too. But you know they are getting better all the time. I am about ready to give away some of my old stuff so I can have room for a new one. What about that?
chardesa
gramps2361 02-08-2014 04:44 PM
I hear ya on the making room part. I recently sold 3 planes to make room for the new. These where planes that I just didn't fly much because my field is not retract friendly. At least they will be enjoyed, and flown by the guys that bought em.
chardesa 02-08-2014 05:07 PM
Yes that is just what I need to do. I am out of space with this twin, they are on wing racks and hanging from the rafters and on the floor everywhere, I have a museum! WOW!
Chardesa
dahawk 02-08-2014 08:14 PM
Some really high quality gear you're stuffing her with. Like it.
I'd love to find a good deal on a used Bonanza, PC-9, etc. Balsa. The Deuces Wild deal I got was too good to be true. $200.00 RTF.
chardesa 02-08-2014 09:18 PM
Some people have all the luck. When I was looking for the C-310 I missed out on two by hours, and that's the luck I have.
As for the eteltric equipment I use, well I have learned from experience that it does not pay to skimp on the quality. The stuff I ordered is not top shelf but quite a bit above the bottom. I like using Digital servos because I can adjust them and reverse them easily. I lost a big DC-3 twin because I used a servo reverser that decided not to work when I needed it. So you live and learn. You will see if you follow my build some of the neat stuff I use.
Chardesa
chardesa 02-08-2014 11:45 PM
Chardesa
There are several places that the Pilatus PC-9 in a foam ARF model are available.
AS for Bonansa they helped Pilatus build the MARK II version.
chardesa 02-09-2014 03:03 AM
4 Attachment(s)
Today I worked on the wings putting on the motor boxes and fitting the nacelles and installing the wing tip tanks.
The motor boxes have to be epoxied to the wing and become a ridgid part of the wing. The first one did not fit well and I discovered that there were two tabs on the bottom that had not been removed, so once those were done away with it fit perfectly and I used 30 minute epoxy to attach them to the wings. After this set up I reinforsed it with Hysol 9462 epoxy to let it dry over night. If you people have not treid this Hysol, it is great. It comes in 2 blends, 9462 which is cream color, stronger and slow drying and then there is E-20 HP which is almost clear and dries much faster. The only bad thing is that you have to buy the little application gun and the nozzles that go with it, but I tell you it is worth it.
I went to put on the tip tanks which are finished and just need to be glued on. Well I was working on the right wing so I picked up the tip tank with the green light on it but it did not fit right so after fussing with it for a minute I picked up the one with the RED light and sure enough it fit perfectly. Well I sent Segull a little FB message about that.
So the tip tanks were epoxied on and a strip of covering material was put on the seam with the heating iron.
The nacells were fitted over the motor boxes and checked for allignment and then attached with 5 screws and the wings were ready for the servos and motors and last to have the retracts installed.
chardesa
chardesa 02-09-2014 01:43 PM
My order has arrived from Horizon, I just can not give enough praize to Horizion for getting orders out quickly. However they were out of stock on thr Power 46 motors so I went to RC Buyers Warehouse by phone and they had them on the shelfe and I had them in had in two days.
So to work installing the rudder and elevator servos in the fuselage along with the Spectrum 621 RX which I had pre binded with my Spectrum DX7S TX. Now I can center the servos with the RX as I set them up useing an Li Fe battery and an on off switch for powering the RX for the time being. At this time I also added a JR Match Box to the system by hookining it directly to the TX Flap socket, this will control the flap servos and keep them in sync. If you have not used a JR Match Box it is a very handy device. Of course you need digital servos to make it work but the beauty is you can adjust the center and end points as well as the direction of up to four servos hooked up to it.
Now I started on the wings again with the aileron and flap servos and because I had predrilled the holes it was quick work. As I put inn each servo I hooked it up to the RX and centered it and made sure it was traveling in the right direction.
Next are the motors.
I show you the fixed gear that came with this model, they are really nice and I hate not to use them.
chardesa 02-09-2014 11:38 PM
6 Attachment(s)
I had added pictures to this post but they disapeared. so we try again.
chardesa 02-10-2014 01:45 AM
4 Attachment(s)
Mounting the motors takes a little time to fit them in so that they lined up with the center of the Nacelle. The trick I used here was to put stickey tape on the back of the motor mount bracket then press it onto the mouter mount on the plane. This way I could move it around until it was centered properly then mark and drill the holes for the blind nuts. This works very well.
On this model the plane motor mount is adjustable for depth so that is another thing that has to be adjusted for the proper distance so that the prop and spinner will fit on correct. I just used balsa wedges to do this and when it was just right I used CA glue to hold it and then epoxy to secure it in place.
With the motors installed I added the ESC's with 2 sided tape then added the wire extention to the wing root. I also had to make up a special harness for the ESC to connect to the batteries.
chardesa
dahawk 02-10-2014 08:02 AM
Found a Top flight C-310 RTF but with Nitro. He says its too big to convert. Do you agree?
What's a plane like this worth?
http://www.rcgroups.com/forums/showt...4#post27460736
Curious,
chardesa 02-10-2014 02:00 PM
Curious,
It is not to big to convert. The original model C-310 ARF-- NIB was about $600. so it depends on the seller.
chardesa
rcers 02-10-2014 02:42 PM
chardesa
+1 an easy conversion. :) I have no idea what they are worth....
chardesa 02-10-2014 05:17 PM
Bargin with the seller.
Good luck
chardesa
chardesa 02-10-2014 05:46 PM
6 Attachment(s)
The installation of the wing retracts was the hardest part of this build and took the longest of any other part of the build. We started out with a bubch of parts and the E-flite 60-120 electric retracts.
First make the cut out and fit the wheel well. Next fit the retract and for this wI needed to get the Dremel tool working to route out a rib to allow the retract to fit. Then I fit the axle and wheel and trimed the gear leg to the proper length. Then I secured the retract with four 1" wood screws, out blue lock tite on the screws for the wheel. I tested the retract and it worked fine so I used rubber cement to secure the wheel well in place and that completed the job for one wing. The second one was easier since I knew exactly what I needed to do. Next the nose wheel retract and steering servo.
Page generated in 0.04538 seconds with 13 queries
