-   -   Today's lesson (http://www.Wattflyer.com/forums/showthread.php?t=73168)
DavidR8 02-10-2014 03:49 AM
Today's lesson
Despite air temperature of 36 degrees and random snow flakes, I went out for some airtime with the Super Cub.
All was good for my first battery, getting used to the ailerons, several rolling takeoffs, working on low, slow passes to mimic landings etc.
Second battery not so good. About 5 mins in, when she's at the far end of the field, the motor sound changes and the nose drops. I thought perhaps I had mistakenly put in the previous battery. I bring it as close as I can, but the landing is a nose over.
Do the long walk, swap the battery but not getting full throttle. Then no throttle.
Not good but by that time it is actually snowing.
Come home to discover the set screw on the bell of the motor had come loose and pull of the prop pulled everything forward.
Pop it out, add a drop of blue Loctite and put it back in place.
All good. :D
Took the time in the shop to work out my aileron/flaperon programming as well. Now I have flaps!
Hopefully I can fly tomorrow and to test the changes!
Don Sims 02-10-2014 10:29 AM
Glad it was something simple and easy to repair.
carpetbagger 02-10-2014 11:21 AM
After having a little 250 motor leap out of the plane while I was doing as simple run-time test I became a fan of Locktite. Take new motor out of box, apply Locktite on all appropriate fasteners.
DavidR8 02-10-2014 10:48 PM
No test flight today
It is pouring rain... :-(
Page generated in 0.03738 seconds with 13 queries
