-   Pusher Park Jets (http://www.Wattflyer.com/forums/forumdisplay.php?f=226)
-   -   YF-23 Black Widow, Grey Ghost (http://www.Wattflyer.com/forums/showthread.php?t=73175)
Clickety 02-11-2014 04:45 PM
5 Attachment(s)
Hi Guys,
I just posted my plans, videos, build guides etc for my YF-23 design on Parkjets.com.
Shumate-style full fuselage 6mm depron build, 2212kv motor, 6x4s prop, 30A esc, 2200mah lipo.
Thought you might like it!
Link to Plans
http://www.parkjets.com/yf-23-grey-ghost/
thepiper92 02-11-2014 05:24 PM
Very sleek looking plane. How many sheets of depron are used. I'm interested in potentially building this.
Clickety 02-11-2014 06:11 PM
9 Attachment(s)
Just two sheets of 6mm 1000x700 depron, and about 1/4 of a sheet of 3mm Depron.
Please find partially complete plans attached :) unfortunately Wattflyer is preventing me from uploading my construction guide & Finishing guide, as its quite large approx 3mb.
You can download the full set from http://www.parkjets.com/yf-23-grey-ghost/
http://www.youtube.com/watch?v=G1A0HkoaybI
If you build it, please post pics!!
Cheers :rolleyes:
thepiper92 02-11-2014 06:48 PM
Is the plane better with a pusher?
Clickety 02-11-2014 06:56 PM
Pusher = Longer flight times, torque effects in high speed tight rolls.
Edf = faster, noisier, shorter flight times.
Both good :)
Edf version awaiting a Edf upgrades from don at wicked rc. Should get close to 100mph.
thepiper92 02-11-2014 07:27 PM
Sounds like pusher is the way to go. I'll wait till spring probably. Already have a plane to build.
Clickety 02-11-2014 08:58 PM
Great! I hope you enjoy it as much as I have :)
Bobdaeronort 02-13-2014 01:44 PM
Very Nice!
fhhuber 02-13-2014 03:11 PM
Both good :)
To get the same performance at the same weight the EDF need 50% more watts to go the same speed as the pusher. (as much about the aircraft being the same as possible)
We tend to put in double the watts when going EDF, add a marginal amount of weight and take a huge hit on duration.
The EDF having a reputation as being faster is a fallacy based on the tendency to add a lot more power. Put the same power pusher on and you'd go even faster and get similar flight duration compared to the EDF.
Clickety 02-14-2014 07:01 PM
Hi Fhuber,
Thanks for your comments.
I should have explained... My preferred / recommended setup for each type gave the EDF higher speed and the Pusher greater duration.
The reason I did this, was because I wanted my pusher to be an easy to fly parkjet which has a nice and low wing loading (9.5oz/ft2) so I can throw it into the air with an easy hand launch, and 'plop' landing.
I wanted my EDF version to look and behave like a fast jet, to be an exhillarating crowd pleaser. so I am about to fit a couple of 4s 4800kv wicked motors in the Wemotec 50mm fan unit it is heavier at approx 900g (11.7oz/ft2 wing loading). If my calculations are correct, then it should reach close to 100mph. I know that EDF is much less efficient, but it helps to feel like a real jet, which I totally love!
Because of the higher wing loading, I designed a launch trolley to help me take off from grass. It may hand launch but I've not got a feel for how it will handle yet.
I am also at sometime going to convert my proto to use a turnigy 2836-2350 on a 4s setup with a smaller pusher prop which should really scare the pigeons!!:eek:
Page generated in 0.03608 seconds with 13 queries
