-   Foamies (http://www.Wattflyer.com/forums/forumdisplay.php?f=9)
-   -   My hunt for the right size inrunner motor (http://www.Wattflyer.com/forums/showthread.php?t=73236)
frankinfremont 02-23-2014 12:40 AM
OK foamie glider drivers, I am looking for a 1200 kv inrunner motor for my Multiplex Easyglider. Tons of outrunners out there but so far I've had no luck finding what I want. 1000kv is a tad light but 1200 to 1300kv would be just right for max flight time for just leisurely flying or climbing up to thermal hunt. An outrunner won't fit unless I use an external mount and I want a clean profile so that's out. Any help pointing me in the right direction would be appreciated.
Larry3215 02-23-2014 12:59 AM
What are your diameter, length, weight limits? Lots of inrunners in that kV range, but sizes and especially weights are a big factor. Would a geared setup work? How much power do you need?
gramps2361 02-23-2014 01:41 AM
This place is still having a sale on the Hyperion motor for sail planes the motors have a tapered front to fit into the tight nose of these planes. Might work and I have bought from them pretty quick shipping from Japan think it was 10 days.
http://aircraft-world.com/shopdispla...que+outrunners
CHELLIE 02-23-2014 01:51 AM
Hear you go :ws: Lots of power when you need it, and it will make your Easyglider Fun to fly, you dont have to use all the extra power, but its there when you do need it ;) This motor will turn your glider into a mild hot liner. use a 6x4 prop on 3 cells.
http://www.headsuphobby.com/Firepowe...00kv-C-424.htm
http://www.wattflyer.com/forums/show...y+scout&page=2
frankinfremont 02-23-2014 03:09 PM
My EasyStar is a powered glider and uses a pusher motor mounted in an enclosed "pod" facing aft behind the wing. The motor must have a 28mm diameter and in the kv range I specified weight would not be much of a factor. I don't need or want a lot of power, any motor in the range of 1200kv up to 2000kv would work. My preference would be at the lower end of the scale. A geared setup would not work btw. I've searched dozens of retailers, large & small but so far no luck on the smaller kv ratings. I'd appreciate any finds you might come up with.
frankinfremont 02-23-2014 03:11 PM
Just checked it out and they show no inrunner motors. Thanks anyway for your effort.
frankinfremont 02-23-2014 03:15 PM
[QUOTE=CHELLIE;940748]Hear you go :ws: Lots of power when you need it, and it will make your Easyglider Fun to fly, you dont have to use all the extra power, but its there when you do need it ;) This motor will turn your glider into a mild hot liner. use a 6x4 prop on 3 cells.
You're right about the hot liner part. :) Given the results I've turned up so far I may well have to go bigger than I want to just to get that thing in the air. Thanks for the url, I'll bookmark it in case nothing else suitable turns up.
gramps2361 02-23-2014 03:44 PM
All right in your first post you mentioned the Easy Glider this has the motor mounted in the nose. Why I posted the link for the motors. I just noticed in your other post that it is the Easy Star glider which is a pusher. Now I get ya.
http://www.headsuphobby.com/MULTIPLE...I-ARF-M104.htm
look at the motor Jeff recommends for this plane you just need to make a plywood mount to fit into the pod. I bought one of his metal mounts for the HK Bixler and did a little foam carving to fit it into the pod. I am sure you might be able to do the same. By the way I swapped the motor out after the plane was assembled, so it can be done.
Here are the links for the motor mounts I used the second link for the HK Bixler. Hope this gives you some ideas.
http://www.headsuphobby.com/Easy-Sta...ount-A-126.htm
http://www.headsuphobby.com/Easy-Sta...ount-D-241.htm
frankinfremont 02-23-2014 04:36 PM
If I go for the outrunner style that would be an excellent choice but the website shows out of stock. Will begin a search for a similar outrunner if no suitable inrunners pop up. Thanks Gramps, good find. Thank you all for your response to my plight. :confused:
gramps2361 02-23-2014 04:39 PM
Try Alltitude hobbies I bought mine from them Garret is another excellent web store. Glad Glad I could be of some help it's what this site and hobby should be about. Now I need to get out of here and go fly.:)
http://www.altitudehobbies.com/brush...s/suppo-motors
Page generated in 0.04175 seconds with 13 queries
