-   ParkFlyers (http://www.Wattflyer.com/forums/forumdisplay.php?f=16)
-   -   Some old planes never die! (http://www.Wattflyer.com/forums/showthread.php?t=73295)
quorneng 03-06-2014 06:06 PM
3 Attachment(s)
Way back in 2008 I bought a Wing Dragon 4 with a brushed motor and 9.6V NiMh.
Through a many iterations it is still flying - well at least the fuselage and tail boom are, everything else is different!
It is now a simple 'fun' flyer but a little bit more sophisticated than it might look.
Attachment 173905
The 44" Depron wing is made up from the outer panels from a 2.1m glider. It has an Eppler 195 wing section.
The primary object of the V tail (also Depron) is to keep the tail plane clear of the rough ground although it also keeps it clear of the direct prop wash to improve the aerodynamic efficiency a touch.
Flown as a 'bank and yank' the single elevator servo is built into the LH tailplane and works both surfaces with a single link rod.
Attachment 173907
It relies on the sideways flexibility of the elevator horns to maintain the geometry!
The motor (Emax 2812 1500kV - very cheap!) is closely cowled with a hollow spinner, drives a 7x6 and draws 15A giving 178W.
Attachment 173906
The fuselage houses the radio, 30A ESC and a 1500mAh 3s.
Nothing unusual so far but at 15.25oz all up its thrust exceeds its weight by quite a margin yet it requires no more than 10C from the battery to do it.
Simple, reliable and tough it is great fun to fly with a substantial endurance. Find a decent thermal and those ex glider wings work well too.
My motto - never throw anything away!
thepiper92 03-06-2014 07:45 PM
Nice looking plane, I've always had an interest in how they fly. How is elevator control?
quorneng 03-06-2014 10:07 PM
The elevator control is no problem.
The only video I have at the moment is an 'on board' with a Key Fob cam.
The camera mounting vibrated a bit but it does give an idea of its performance. For some reason the ESC refused to set the brake so the wind milling prop reduced the glide performance a bit but it still managed a power off loop.
This flight used about 1/2 the batteries capacity.
solentlife 03-07-2014 03:26 AM
Frankenstein planes ....
I have never binned a model yet.
My old Solent Saiplanes Ridge Recruit supplied its wings for modification for my Mig 17 ... You read correct. A slope soarer wing was chopped and swept back to provide wing for my Bosak Mig 17.
My Lanyu ME109 provided tail and wing for a part DIY Me109 ...
The list goes on ...
Just because original is one plane - doesn't mean that parts cannot be modified for another. The foam jobs we have now are marvellous for this.
In UK - we had sweet stores (candy in USA) ... that bins of sweets were open and you created your own "Pick & Mix" bag of sweets .. the same can be applied here !!
Chucksolo69 03-07-2014 03:45 AM
I have a flying buddy who has, what he calls, his Stickson. It is basically a Slow Stick fuselage with Parkzone Stinson wings and Eflight Mini Pulse tail feathers. It flies pretty nicely too.
solentlife 03-07-2014 04:11 AM
Recycling models is my game ... as many know.
I just don't understand why models are binned when so much can be re-used or even put back together again.
Todays foam jobs are easier to put back together and make fly - but harder to get cosmetically good after repairs. Traditional construction may appear harder to repair - but in fact is just a jigsaw puzzle and usually repairs are hardly noticeable - better cosmetically than foam ..
But I'm old school ... maybe that's why ?
Page generated in 0.03296 seconds with 13 queries
