-   -   new flyer from Alberta Canada (http://www.Wattflyer.com/forums/showthread.php?t=73305)
bigmac3737 03-07-2014 02:17 PM
Hi there my name is iain, just purchased a PZ UM spitfire because I've always wanted to
get into the rc game. So far only flown once ( broken the landing gear off, which is ok they
glued back on). Finding a place to fly is challenging, last night I flew
at a local skating rink in -26c so if all I broke was some taped on landing
Gear I think im doing ok. Just thought I'd introduce myself I am very excited to
become a member of this forum and meet all you fine chaps!
Cheers!
ziptie 03-07-2014 02:36 PM
Welcome, I'm new as well and just bought the Realflight SIM to help me practice on.
bigmac3737 03-07-2014 02:56 PM
Im too poor for a computer so im going trial by fire, mostly t akeoffs,
short flights and landings right now, when I get a decent handle on it ill
post videos. Spent all nice taxiing it through an obstacle course in my
basement last night to get a feeling for throttle response. This is
much more difficult, but much more fun then an rc car :-)
dahawk 03-07-2014 04:48 PM
bigmac,
If you're were flying on ice they would call you a "hoser" Just kidding.
Welcome to WF ! There's lots of help available here, from a cadre of experts ( my not included) free for the asking. No question goes unanswered so don't be shy in asking.
The UM's would not have been my first choice as an entry level plane , especially, a Spitty , with it elliptical wing. But it seems like you've gained some early success. Does it have the gyro ? Normally, we start with a high wing trainer like an Apprentice or even a HZ Super Cub. But, whatever floats your boat.
Best of luck !
A Sim like real flight or Phoenix is a good idea as is buddy boxing with an experienced pilot.
bigmac3737 03-07-2014 07:55 PM
Yes I did some research that advised against it, but it has the as3x system
onboard, and the up wing Cessna models just dont make me smile
like a spitfire. its definetly challenging, been reading up lots on it.
first few flights I used very little aileron and it went ok.
Im sure I will crash it but at 77$ and its small size you cant go wrong!
Before this plane I almost bought an eflite 540qq, glad I didnt get that one...
spit is hard enough! Thanks for the warm welcome!
The ice had a couple inches on it, seemed ok the boards around the rink were the real
issue!
bigmac3737 03-08-2014 07:26 PM
I am happy to report my first real maiden flight in an open area went very well!
Launched off the roof of my truck with a board, even managed multiple
barrelrolls and a hammerhead, I think my experience with video games
may have helped me control it, amazingly responsive and agile
perfect speed, trims were great out of box and not a single un intentional
stall, I think im in love :-)
AEAJR 03-22-2014 10:00 PM
Glad to hear you are progressing well. Congratulations.
Be sure to read the following:
Six Keys to Success for New Pilots
http://www.wattflyer.com/forums/showthread.php?t=18
> THINGS TO CHECK ON AN RTF
> http://www.wattflyer.com/forums/showthread.php?t=26372
HOW TO FIX WARPS, DENTS, TWISTS OR UNCRUNCH FOAM PARTShttp://www.wattflyer.com/forums/showthread.php?t=66805
EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
http://www.wattflyer.com/forums/showthread.php?t=31071
bigmac3737 03-23-2014 04:59 PM
Thank you AEAJR !
This is a great forum :-)
bigmac3737 03-23-2014 05:04 PM
Thank you! Excellent read!
bigmac3737 03-23-2014 05:10 PM
Update, the plane was crashed, replaced a wing and a new prop.
the old prop was 4 grams! New one is less then a gram, tried my hand at
clay balance! Is there a chance installing a lighter proper could be detrimental
to engine performance? I wouldn't think so, but my first flight after
Installation the plane kept hitting lvc very early across 3 different fully charged
Lipo. Changed all batteries, labelled them and charging them now.
going to go try again soon with a flight timer.
could less than perfect batteries in the transmitter cause early LVC?
Manual states LVC is for flight battery only. .
xmech2k 03-23-2014 07:31 PM
LVC is all about the flight battery. As for a lighter prop, being that much lighter makes me wonder ifit flexes and possibly flattens under load. Another consideration, is the new prop the same diameter and pitch as the old one? It can be drawing a little more amps than your old prop, or it may even cause the motor to pull more amps than the esc or perhaps the battery can deliver in worst case scenario.
AEAJR 03-23-2014 08:05 PM
If you crashed and damaged the prop, what else did you damage that you may not know about. Is it possible the motor or the spinner are rubbing against the body of the plane? This would cause extra drag and drive up the power draw. This could cause voltage to drop below LVC.
Is it possible you bent the motor shaft? This would cause the prop to spin unevenly which would put tremendous pressure on the bearings. This would cause heat build up which would swell the bearings, binding the shaft and causing a voltage drop that would kick in LVC.
Check the motor, the motor mount and be sure nothing is rubbing or wobbling. Finally make sure the new prop is not bent. Also make sure it is the same width and pitch as the old prop.
zoltron55 03-23-2014 09:47 PM
welcome these are a great bunch here. make sure your new prop is the same pitch & diameter
bigmac3737 03-26-2014 02:22 PM
I actually just re glued the motor in place, it was a bit loose but nothing was rubbing.
Took it for a flight yesterday with a new flight battery, no LVC.
I guess the service life for those little lipos is about 20 flights.
thanks for all the help guys!
AEAJR 03-26-2014 02:59 PM
If you are not over discharging them and not over charging them they should be good for at least 100 cycles and as much as 500 cycles.
bigmac3737 03-26-2014 07:09 PM
Hmm thats strange. Chances of a defective battery?
bigmac3737 03-26-2014 07:13 PM
Went from a 4 blade to a 2, when I get home ill measure them up.
its definitely wider across, I figured that would be ok do the fact of
2 less props, I believe the new one is slightly less angle.
Ill post it when im off work. Thanks again!
Page generated in 0.03939 seconds with 13 queries
