-   -   I'm going frakking nuts! (http://www.Wattflyer.com/forums/showthread.php?t=73469)
FlyWheel 03-31-2014 10:09 PM
This is the part of a folding prop that the blades attach to that is fitted onto the motor shaft (or adapter):
http://www.hobbyexpress.com/images_p.../846_large.jpg I have been looking for over a week trying to find one of these stupid things that will fit the 5mm diameter threaded prop adapter on my outrunner motor, but so far all I have found* are those that have an 8mm hole which is way too big for a 5mm shaft.
Am I missing a page? Is there some "sold separately" thingamabob that I don't know and none of the retailers are telling me about that I am supposed to buy so I can fit a 5mm shaft into an 8mm hole? Any motor or prop adapter for a motor that would have an 8mm shaft would be HUGE. Folding props are used on virtually every electric sailplane built, most of which use motors similar to the one I have. Unless it is for a very large scale NONE OF THESE MOTORS would be anywhere near big enough to have an 8mm motor or prop adaptor shaft; they would be around 5-6mm.
So where are the Gorram yokes that fit them?!
:mad::mad:WHAT THE FRAK IS GOING ON??:mad::mad:
(*straight bore, not tapered as in one that uses a collet)
giflyrc 03-31-2014 10:31 PM
Since the desired part is not readiily available I would fill the 8mm hole with epoxy or Welders and redrill to 5mm--- or
1. wrap the motor shaft with electrical tape for a snug fit
2. use thin wall tubeing as a sleeve/spacer over the motor shaft
3. I guess surgical tubeing would work too
My 2 cents---Roger aka GIFLYRC
squidger 04-01-2014 12:13 AM
There are many different types of folding prop adapters on the market. The one you show is for 8mm shafts.
http://www.ebay.co.uk/itm/like/31021...f14=108&ff19=0
http://www.hobbyexpress.com/spinners...rs_358_ctg.htm
http://www.giantshark.co.uk/group/24...ding-propeller
gramps2361 04-01-2014 12:50 AM
Don't know if this will help you out great place to buy from.
http://www.alofthobbies.com/bb-foldi...-spinners.html
sidybee 04-01-2014 01:54 AM
get some brass tubing an insert those till you get the right size. if you lived closer i could just whip one up with the mill
solentlife 04-01-2014 03:56 AM
What about a collet prop adaptor that fits 5mm shaft but has 8mm OD ?
If the OD is not enough - then prop shaft rings ....
Here's a 5mm shaft collet with 8mm thread ... maybe a bit short - but gives the idea :
https://www.hobbyking.com/hobbyking/...t_collet_.html
carpetbagger 04-01-2014 04:10 AM
here ya go . . .http://www.headsuphobby.com/Folding-Props_c86.htm
FlyWheel 04-01-2014 04:56 AM
People please, you don't clamp a collet onto a threaded shaft, especially one made of a softer metal! <grimace> if it were that easy there are already folder spinners and yokes that have 5mm collets.
I'm thinking my best bet is going to be somehow coming up with a bushing of some sort (now I wish I hadn't retired, I could have had an entire CNC machine shop at my disposal!).
solentlife 04-01-2014 06:33 AM
Well sorry .... but based on your OP - how were we to know you have a threaded SHAFT when you type threaded PROP ADAPTOR of 5mm.
Second - who puts a softer metal as shaft ? unless it's a home made shaft ...
I've put collets on to threaded shafts when necessary - so what's problem ?
Right ... so what is problem with putting shaft rings from propeller's to build out the shaft to prop holder hole ? If the shaft is threaded - then a thrust washer behind and in front to lock all together with the prop rings cantering it all.
What's the problem ? There is no real stress or weight on the rings, that's taken care of by the thrust washer surfaces to the prop holder and nut.
carpetbagger 04-01-2014 12:51 PM
No problem - see my post #7. Heads Up RC has 5mm folder hubs with aluminum spinners. Also folder blades in various sizes. Heads Up ships cheap ($2) and fast.
eagle33 04-01-2014 04:33 PM
FlyWheel really has a chip on his shoulder with his smart comment. I could help out but I'm not going to do it.
FlyWheel 04-01-2014 05:49 PM
The folding spinners that fit 5mm are 2" in diameter, too big and they all attach using collets. However I think I'm going to go with just getting an APC plastic prop the same size as the folder. They re designed with a bore of 8mm BUT they also come with a pair of bushings, one of which has an I.D. of 5mm. The bushing will fit into the 8mm straight bore in some of the Aeronaut yokes. If the folder cannot be made to work this way then at least I'll have a straight prop to fall back on.
maxflyer 04-01-2014 05:52 PM
Kids...Kids! Flywheel is a bit overheated. You know how it can be at times when you can't solve something...and you don't realize the scope of your own ignorance. We've all been there.
CrimzonRider 04-01-2014 06:26 PM
.......I'm thinking my best bet is going to be somehow coming up with a bushing of some sort (now I wish I hadn't retired, I could have had an entire CNC machine shop at my disposal!).
Is this what you're looking for?
http://www.getfpv.com/propellers/prop-reducers.html
FlyWheel 04-01-2014 08:56 PM
Originally Posted by CrimzonRider (Post 944259)
PERFECT!! Thank you!! :tc: :$
(will you marry me?)
(Just kidding about the last part ;) )
(Unless you're a single female, of course. Then maybe... :D )
CrimzonRider 04-01-2014 10:06 PM
100% manly man farmer rancher dude with boots here.....lol
Anywho, I also remember seeing a wider range of items, if my memory still working right, I think they were sold by Cermark, the seller of NeoDym Motors(one of my favs), right here in the USA.
Good luck to ya.
cr
FlyWheel 04-02-2014 01:46 AM
Thank you again. That site will definitely be in my favorites!
Page generated in 0.03768 seconds with 13 queries
