-   Batteries & Chargers (http://www.Wattflyer.com/forums/forumdisplay.php?f=6)
-   -   Big Sparks! (http://www.Wattflyer.com/forums/showthread.php?t=73507)
JetPlaneFlyer 04-06-2014 05:34 PM
Big Sparks!
Today i was hooking up one of my 6s batteries to the charger only half concentrating on what i was doing and I must have accidentally bridged between the + and - bullet connectors with the male bullet of the charging cable.
There was a big flash and this is what the 5.5mm bullets looked like a millisecond later:
http://i3.photobucket.com/albums/y65...120/sparks.jpg
The burned male (red) connector on the left is the charger cable, the two connectors on the right are the +/- off the battery, all are beefy 5.5mm bullets. the spark blew the end off one bullet and burned a hole straight through the side of the other!
Close up:
http://i3.photobucket.com/albums/y65...0/sparks_1.jpg
Luckily that was all the damage apart from a couple of tiny burns on my finger caused by flying molten metal (sounds worse than it was). Normally I keep a cap over the male (negative) battery terminal until I've connected the positive side up, but today I must have been daydreaming.. There's a lesson to be learned - Always concentrate when working with LiPos!!
This wasn't the only lesson though. I went about replacing the battery bullet connectors. These were original factory supplied connectors on the Turnigy LiPos.
Here's what the soldering socket of the male connector looked like:
http://i3.photobucket.com/albums/y65...0/sparks_2.jpg
Notable is the TOTAL lack of any solder in the socket:eek: All that was connecting the wire to the bullet was a thin fillet of solder between the side of the wire and the edge of the bullet, and that only ran around half the circumference. I shudder when I think I was pulling 140A through that connector.
So lesson number two - Re-solder every connector on your LiPos! (especially cheap ones)
xmech2k 04-06-2014 06:41 PM
Oops! Thanks for swallowing your pride and sharing that with us, and glad there wasn't any major injury or damage. A good lesson.
sidybee 04-06-2014 06:56 PM
i think they call that ark welding lol
CHELLIE 04-07-2014 01:40 AM
I hate that when that happens :( I have done that too :D It sure is a wake up Call :Q
Larry3215 04-07-2014 05:11 AM
Thats very scary seeing the lack of solder in that bullet!
I did almost exactly the same thing one time. I was charging at the field and one of the exposed male bullets touched the frame on my truck while connecting the charger.
I not only ruined the connector I shorted, but I also blew one of the aluminum tabs on one of the cells in the pack. It blew just like a fuse.
It took me a while to figure out why the pack read zero voltage after I soldered on a new connector! I knew it couldn't possibly have discharged down to zero that quickly.
Not paying attention can get expensive!
kyleservicetech 04-07-2014 06:26 AM
Yikes
140 Amps through that??? You're right, that was very fortunate to not have blown out in flight.
Page generated in 0.03649 seconds with 13 queries
