-   -   Servo suggestions for twist 480 (http://www.Wattflyer.com/forums/showthread.php?t=73510)
Pileofsticks 04-07-2014 05:18 AM
I just purchased a Twist 480 and can't decide what servos to buy. They suggest the Eflight DS76 servos but the reviews I have read aren't to positive for those servos. I do have a tendency to be hard on planes with blenders and violent direction changes. I have flown all nitro except a eep crack yak until now so I don't have experience with this size plane and need help choosing servos.
CHELLIE 04-07-2014 05:29 AM
use a 9 Gram servo, they are a little more robust than a 7 gram servo, I found problems with the Turnigy Digital servos, so this is a better servo to use.I Really like the HXT 9 gram servos, but they are sold out at this time on those servos. i use both the turnigy and HXT servos, they work great.
http://www.hobbyking.com/hobbyking/s...ro_Servo_.html
http://www.hobbyking.com/hobbyking/s...cro_Servo.html
or these
http://www.headsuphobby.com/Emax-8g-...ervo-E-123.htm
http://www.hobbyking.com/hobbyking/s...talog/9549.jpg http://www.hobbyking.com/hobbyking/s...9.jpg&width=48 http://www.hobbyking.com/hobbyking/s...s.jpg&width=48
THE WORLDS LOWEST COST (RELIABLE) SERVO
The TG9e boasts the same performance as other servo's 10x the price with a .10sec travel time and up to 1.5kg in torque and an ultra narrow dead bandwidth!
The TG9e performance is on par with the famous HXT900, however the TG9e isn't as resistant to crashes or over-loading.
Please always ensure your control surfaces are bind free.
Spec.
Dimension: 23x12.2x29mm
Torque: 1.5kg/cm (4.8V)
Operating speed: 0.10sec/60 degree 0.09sec/60 degree(6.0V)
Operating voltage: 4.8V
Temperature range: 0-55C
Dead band-width: 7us
Lead Length: 260mm
CHELLIE 04-07-2014 05:50 AM
Here is a video of my 48" W/S scratch built Katana with the HXT 9 gram servos, and a 480 motor, the turnigy servos are about the same, I think they are made by the same MFG.
My Friend Steve is doing the Maiden Flight, I am Doing The Video.
CHELLIE 04-07-2014 06:03 AM
BTW, Welcome To Wattflyers :D
Pileofsticks 04-07-2014 12:58 PM
Thank you for the welcome and suggestions. What do you think of the Hitec 5055mg servos? I like the idea of metal gear and digital is always nice for centering.
CHELLIE 04-08-2014 08:33 AM
You cant go wrong using hitec servos, they are some of the best of the best servos on the market, those metal gear servos will work great. They are a little expensive, but you get what you pay for :)
http://www.amain.com/product_info.ph...FVJffgodj3wA_A
This is a Hitec HS-5055MG Digital Metal Gear Sub Micro Servo. Since its introduction, the HS-55 has set the standard for affordable performance, offering precision components that have been engineered to provide long lasting trouble free service! Enter the new HS-5055MG digital, metal geared version...with this new servo Hitec takes ultra micro performance to the next level without breaking the bank. The new HS-5055MG is a perfect choice for ”smaller” high performance electric helicopters, aircraft and sailplanes, as well as micro surface applications.
Specifications:
Motor Type: Coreless
Bearing Type: None
Speed @ 4.8V: 0.20/60 sec
Speed @ 6.0V: 0.17/60 sec
Torque @ 4.8V: 18.05 oz/in (1.3 kg-cm)
Torque @ 6.0V: 22.20 oz/in (1.6 kg-cm)
Size:
0.89x0.45x0.94 inches (22.8x11.6x24.0mm)
Weight: 0.33oz (9.5g)
Pileofsticks 04-09-2014 03:02 AM
Thanks Chellie, I went with the Hitecs. Next time I get a foamie I will give those Turnigys a try, I just am leery about putting plastic gear servos in a balsa plane. I had a tower pro strip in flight and down came my foam yak but a little glue and a new Hitec it was back in the air. :)
satnaam 04-16-2014 03:28 AM
HS65 all the way
good servo, name brand and works like a horse.
satnaam[popcorn]
crxmanpat 04-16-2014 04:50 AM
I like the HXT900 9gr servos. I use them in all my pusher jet builds and typical park flyers up to 48" WS or so. I sell them on my site.
Page generated in 0.08100 seconds with 15 queries
