-   RC Radios, Transmitters, Receivers, Servos, gyros (http://www.Wattflyer.com/forums/forumdisplay.php?f=68)
-   -   Spektrum Maintence (http://www.Wattflyer.com/forums/showthread.php?t=73539)
eagle33 04-10-2014 01:29 PM
Spektrum Maintence
I have a Spektrum Dx6i transmitter which is seven years old. I'm not having a problem with it. Should I send this to the Spektrum folks for routine maintenance considering its age? Or should I just wait until something goes wrong and then send it?
xmech2k 04-10-2014 03:52 PM
Surely by now you must have heard of their legendary service?! What sorry of maintenance does it need? If it was simple and I didn't have some sort of backup maybe I'd do it myself. Also, have you checked their site to see if yours is one on their recall list? You may get more fixes than you thought you need, and they often do it for free.
fhhuber 04-10-2014 04:03 PM
Early AM and FM RC transmitters needed to be sent in every year for re-tuning.
Modern radios don't need that. Even the cheaper AM and FM radios made after appx 1990 will work for many years without any frequency drift.
2.4 ghz radios have no frequency drift issues.
It won't hurt to send it in for a checkout and cleaning... but its not needed unless it shows evidence of problems.
The battery may need to be cycle tested if it has a NiCd or NiMh. After about 4 or 5 years I'd replace a NiCd or NiMh TX battery just to be safe.
I believe the DX6i uses alkaline (disposable) AA cells though.
pizzano 04-10-2014 04:18 PM
I believe the DX6i had a recall in 2009:
http://www.horizonhobby.com/article/...onsumer-notice
If yours is one of those that has the listed recall codes, you may want to consider sending it in.
Most of the DX6i came with rechargable Ni-MH 1500mah, 1.2v AA batteries......if yours are original, consider replacing in-kind.
rcers 04-10-2014 04:20 PM
I would not send it off - as frankly you are likely close to "end-of-life" for a low"ish" end box. Time for an upgrade and a apply that cost to a new box! Then you have a good TX for backup use.
xmech2k 04-10-2014 05:00 PM
Ugh! I was PWI: Posting While under the Influence, of drowsiness! :oops: Sorry Eagle33. If there's nothing wrong with it, I guess I'd still see if it was a recall one, but if it ain't broke...
eagle33 04-10-2014 05:13 PM
Thanks guys. My transmitter is not one that was subject to recall so I'm going to sit tight and see about getting a Spektrum 7 or 8 in the near future
rcers 04-10-2014 05:23 PM
Yep both are great. The dx9 even better, if you can swing it. :)
Hawk will sell you his - he is going the DX18 v2 anyway.... :)
kyleservicetech 04-10-2014 10:53 PM
Several years ago I sent in my 5 year old Spektrum DX7 transmitter, along with a half dozen Spektrum receivers for a "Factory Checkover", just for peace of mind. They checked everything out, all was within specs.
Got them back in 7 days, with a note indicating, for customer satisfaction, No Charge. They even paid return shipping.
FYI, Horizon Hobby has a history of doing this sort of thing.
swimmer 04-11-2014 03:30 AM
In that amount of time I'm surprised one or more of the trim switch actuators has not broken. I sent my DX6i in after four years for actuator replacement after I broke one of them. They replaced all of them and gave it a thorough inspection from which they determined the gimbals should be replaced. All this, no charge and sent it back postage paid. I'd call that great customer service.
kyleservicetech 04-11-2014 03:42 AM
Typical Horizon Hobby service.
Several years ago, one of my club members had a Spektrum DX7 that every so often would loose its bind to the receiver during power up. Never lost a model, just had to rebind all the time.
He sent it into Horizon with documentation on the problem. They couldn't verify it. So, Horizon returned a brand new, out of the box DX7 transmitter. No charge.
Page generated in 0.03505 seconds with 13 queries
