-   Batteries & Chargers (http://www.Wattflyer.com/forums/forumdisplay.php?f=6)
-   -   Lipo Battery fully charged?? (http://www.Wattflyer.com/forums/showthread.php?t=73540)
Hogflier 04-10-2014 03:42 PM
How can you tell if a lipo battery is fully charged. I bought a Turnigy Accul-6 50W 6A Battery Charger. I hooked it up to the proper port on the charger and got all kinds of readings except what I wanted to know, and that is, the state of charge the battery is in. When i put it into my trans. it showed 9.9V right out of the box, no charging or nothing. I then tried it out on my plane and everything worked great. Its a zippy 1800 mah Transmitter battery. Do these things come fully charged, this one seemed to have. I have just recently switched to electric, so actually I know hardly anything.
Rodneh 04-10-2014 04:13 PM
You do not say how many cells but from the info you gave it must be a 3 cell unit. Now a LiPo should read 4.2 volts per cell or, in your case if a 3 cell, should read 12.6 volts fully charged. At 9.9 volts, the cells were dangerously near the critical low level. LiPo's are normally delivered in a partially charged state and never lower than 3.7 volts/cell. It will serve you well to do a bit of study on the care of LiPo's, lots of info here on this site. You can quickly ruin a LiPo be discharging it to low.
fhhuber 04-10-2014 04:56 PM
They shouldn't ship a 3 cell at 9.9 v.... it should ship at 11.1 v.
Full is 12.6 for 3 cell.
LiPos are very predictable about voltage relationship to % of full charge. Modern LiPos start to be damaged below 3.5 v/cell at rest. 9.9v might be OK for a LVC setting, but its TOO LOW for the battery with no load on it.
xmech2k 04-10-2014 06:07 PM
Where was that chart? Here it is. Found it posted by immelguy over at RCG. Mind you, the voltage is the voltage per cell. If you're going to stay in this hobby, you should really get a volt meter that can plug into the balance plug and tell you each cell's voltage.
http://static.rcgroups.net/forums/at...ageEffects.png
JetPlaneFlyer 04-10-2014 06:29 PM
Are you sure the battery is a LiPo and not a LiFe? LiFe batteries have lower voltage.
As noted above, if it's a 3s LiPo then it's basically already over-discharged at 9.9v and risking permanent damage or 'instant death' if you run it any lower. You also will suffer loss of power on the Tx shortly because voltage will be about to collapse catastrophically, there is almost nothing left in the tank of a LiPo when they get that low.
What about a link to the actual battery?
solentlife 04-10-2014 07:49 PM
Details of LiPo and details of Transmitter ..
If its a 9x Transmitter - the voltage reading is wrong anyway - they all read low.
The main thing to remember with the charger - is that it will cut-off at FULL charge when operated. So no need to know exactly voltage or charge state - as the Charger will look after that for you.
It's always good to know state of your batterys though and that's where the WATTMETER comes in handy .... it gives a direct reading of % capacity remaining etc.
kyleservicetech 04-11-2014 04:45 AM
Do you have the tread at RCG? That long time storage at 4.2 Volts DC affecting battery internal resistance is interesting.
Hogflier 04-11-2014 02:28 PM
battery condition
Yes thanks Kyle, somtimes just asking a question will keep a guy from reading a manual the size of a telephone book.
Hogflier 04-11-2014 03:02 PM
you are right, this battery is a life, but my charger says life/lipo, so i guess i will charge either one the same.
xmech2k 04-11-2014 05:10 PM
Is that not true? I already asked the poster permission to use it in our club newsletter, and it turns out he found it elsewhere himself. And it was posted to give a new person an idea of how to care for his batts iirc. If it's not true, I'm certain it is bad to keep your lipo fully charged, what is the science behind it? One of our club members who flies a large electric plane was complaining the batteries were getting puffed and would barely fit any more, and in the course of the conversation it turned out he stored them fully charged. I forget if he was losing performance.
@ hogflyer: Not that I've ever charged a life battery, but on my chargers I have to select the type of battery I'm charging. You post sounds like you're not making a battery type selection? IDK, maybe your charger is ok with that, but just checking.
hayofstacks 04-11-2014 05:20 PM
Storing fully charged does kill batteries. i had a few a barely used that i chargrd up and forgot about that puffed up badly in about 6 months.
my 4000mah 3 cells sat for a year before u charged them above the storage charge, and worked fine since.
Hogflier 04-11-2014 05:51 PM
Thanks to you guys I might not have ruined the battery, i also got more info on Youtube in a video. It covered charging , discharging and storage. The storage recommends the battery be about half charged.
JetPlaneFlyer 04-11-2014 06:25 PM
Yes, it's true.
The best resource I've found that talks with authority on the subject is here: http://batteryuniversity.com/learn/a...ased_batteries
kyleservicetech 04-12-2014 02:24 AM
LiFe and LiPo batteries use different chemistry. And, each one has its own charging routine. Don't mix them.
LiFe cells are to be charged to a peak voltage of 3.60 Volts per cell. Compare that to a LiPO that is to be charged to a peak voltage of 4.20 volts per cell.
Charging a LiFe battery to 4.2 Volts per cell is not good for it, and may damage it.
kyleservicetech 04-12-2014 02:34 AM
Originally Posted by JetPlaneFlyer (Post 945202)
Yes, it's true.
Thanks for the link. That article is interesting.
I'm beginning to appreciate my over weight, oversized, undervoltage A123 cells even more and more. They don't care how they are stored, and as long as you don't discharge them below 2 Volts per cell, they last a long long long time. Also, it seems that as these batteries get old, like five years or more, with hundreds of flights on them, their internal resistance doesn't change. What does happen is lower ampere hour capacity, like a loss of 10 or 15 percent of original Amp Hours.
I just flow my Redwing models MXS-R model today for three flights. (Winds were gusting at 23 MPH). The 10S2P A123 pack was last fully charged November 10, 2013. Topping that battery off today took 74 Mah. So, in five months of sitting in the model, the 10S2P battery lost 1.7% due to internal discharging. That's typical of these cells. Not bad. :D :cool:
thepiper92 04-12-2014 02:35 AM
Fully charged certainly does kill lipos. I had a 5000mah 3s was originally taking my rc car up to over 70mph, then came winter, and after the snow was gone I couldn't get past 40mph with it and it lasted maybe 3 minutes.
solentlife 04-12-2014 07:24 AM
That totally changes the matter and voids near all replies.... LiFe are a different ball game and charger needs to be user set to them.
Hogflier 04-12-2014 03:39 PM
I'm back guys. I've learned a lot about Life batteries. This particular Life battery is a 1800 mah transmitter battery. I have studied my Accucel -6 charger and learned how to quick charge, balance charge and store charge. What's puzzling me now is when I get it all set up, I get a connection break error. I'm using one of those jump start things for my power supply, made to jump start a car, it has a USB port and Cigarette lighter port. Does this thing have a diode or something to protect the car battery and interrupt the current?? I cannot figure out why i keep getting this error, I've followed the directions to the letter.
thepiper92 04-12-2014 04:07 PM
Get an ac adapter first of all, so you can just plug it into a wall. There should be some available for that charger. I don't even think a cigarette lighter has enough oomph, but I could be wrong. A USB charger definitely won't suffice, very low amps. it takes 30 minutes for me to charge a 250 mah battery. 1300...really long time. A connection break shouldn't have to do with the source, as if there is one...well your charger would be off, but it could be detecting too weak of a supply. It may be the wires going between the battery and charger, one could be not plugged in all the way, or a solder joint giving a bad connection, or a connector isn't making good contact.
Hogflier 04-12-2014 04:20 PM
You'd think that a power source with the oomph to start a car would be enough to charge an 1800 mah battery. Im going to try it straight through my car battery via cigarette lighter port. I'll let you know what happened.
thepiper92 04-12-2014 04:39 PM
The car battery yes, but is that lighter port receiving enough? I don't know what they produce myself. If you connect right to your car batt, there will be no issues.
xmech2k 04-12-2014 05:36 PM
I hate to send you to the manual hogflier, but you might want to verify, I imagine a connection break error is between the charger and the battery you're charging, not the power supplying the charger. If that were the case the charger just wouldn't be on. Check the connections between the charger and the battery. Make sure it's set to the correct cell count too.
thepiper92 04-12-2014 07:04 PM
Connection break on my iMax only means a bad connection. It will have another error if battery is the wrong type. Ive had a number of connection breaks when I was using nimh batts in receiver, and i stick tape on the positive of one batt, tape on negative of another and throw the other 6 batts in between. Lol, maybe not the best way to charge, as if one batt wasn't touching, connection break. For charging, mine has lipo, life, nimh and nicd, all separate. Your charger should be the same for the most part
kyleservicetech 04-12-2014 09:47 PM
You might want to check the LiFe batteries balance connector with a voltmeter, to make certain the individual cell wiring matches what your Accucel - 6 charger expects. I've seen several LiFe batteries that use the standard servo connector wiring for the balance cable. And, the pin-outs have varied on some of them.
As for me, I re-terminate these wires with my own connector, so there is zero possibility of accidentally mixing a LiFe battery connector with a servo connector while hooking everything up.
nidly 04-16-2014 12:21 AM
Used to be the most common (connection break) error was to forget to hook up the main lead.
Page generated in 0.05170 seconds with 13 queries
