-   Indoor & Micro Electric Planes (http://www.Wattflyer.com/forums/forumdisplay.php?f=11)
-   -   Flyzone Micro Tiger Moth (http://www.Wattflyer.com/forums/showthread.php?t=73653)
eagle33 04-28-2014 06:37 PM
I'm considering buying Flyzone's Micro Tiger Moth. Does anyone know if the stock decals can be removed and, if so, how? I don't like the stock markings as it looks like Swissair (or maybe Austrian Airlines).
fhhuber 04-28-2014 07:29 PM
Generally the FlyZone micros' stock decals are peel-n-stick. These would pull the paint off the foam as you peel them but they can be removed. They won't re-stick without applying some sort of adhesive so if you peel them consider it as not being reversible.
Any repaint you do will come out heavier than the factory paint + decals. How much heavier might be important with this small of a model.
eagle33 04-29-2014 03:32 PM
Thank you for your comments, Huber
eagle33 12-30-2014 04:49 PM
Does anyone know if the little Tiger Moth will bind to a Spektrum Dx6i?
xmech2k 12-30-2014 05:56 PM
I don't think so. Doesn't Flyzone use Tactic tx's? But they sell those modules you can plug into your Spektrum and then it'll speak Tactic and work with it.
I googled it and found it on the Flyzone website, I was correct about the Tactic radio system. And here's Tactics Any link module. You'll have to get the Spektrum compatible one.
eagle33 12-30-2014 06:25 PM
Thank you xmech. I had completely forgotten about the Tx-R module.
Page generated in 0.03346 seconds with 13 queries
