-   -   outrunner motors (http://www.Wattflyer.com/forums/showthread.php?t=73659)
mrputz1 04-30-2014 12:00 AM
outrunner motors
Looking at small motors on ebay some have a hub on the output shaft with two large screws. What are they there for ?
fhhuber 04-30-2014 12:20 AM
Generally these are small motors. The device on the output shaft (sometimes built into the motor case) is called a "prop saver" you use an O ring or rubber band to hold the prop on.
Bub Steve 04-30-2014 12:22 AM
thats where the prop is mounted, an "O" ring goes over the prop an holds it to the shaft,, their called prop-savers,, and they work well,, hope that helps,,,
bubusteve
mrputz1 04-30-2014 12:33 AM
outrunner motors
Oh I get it now. I thought they all should have a prop hub and spinner .Wow does rubber bands hold a prop spinning at 1200 rpm ?
fhhuber 04-30-2014 12:58 AM
1200 rpm is actually pretty slow. Some of these small props can be held on with an o-ring or rubber band at over 10,000 rpm.
solentlife 04-30-2014 07:44 AM
It is no ordinary rubber band...... it looks same as an Oil O-ring in an engine.
Abuelo 04-30-2014 05:04 PM
That 1200 rpm quoted might be the rpm per volt. If it shows as 1200kv on the specification sheet multiply it by the voltage, i.e. 2 cell lipo 7.4 volts times 1200 = 8880 rpm.
And yes, the prop saver works just fine.
The prop saver o-rings are cheap but sometimes hard to find. Latex tubing, used in medical procedures and what we use in the high-starts, also works. Just cut of rings from the end. I found some at Lowes back in the plumbing area.
solentlife 04-30-2014 05:30 PM
Or trot along to local car accessory / parts shop and pick up O rings ... I buy them in packs of 10 for a couple cents each !!
fhhuber 04-30-2014 05:36 PM
Rubber bands do work.
solentlife 04-30-2014 06:35 PM
I was thinking in terms of flimsy office bands - you never know what people will take as meant by simple term like Rubber Band.
I would not like to think someone got injured by using such on a prop doing 8K .. 10K or more !!
Page generated in 0.03589 seconds with 13 queries
