-   3D Flying (http://www.Wattflyer.com/forums/forumdisplay.php?f=5)
-   -   *Giant Scale 50cc* (http://www.Wattflyer.com/forums/showthread.php?t=73704)
Zippi 05-06-2014 10:40 PM
*Giant Scale 50cc*
Not only am I new to this forum I'm also new to giant scale electric. I have been flying giant scale gasses for some years it's just the electric part I'm new to. I have some small electric planes just nothing big. I have the E-flite Power 360 that I'm going to use on a 50cc size plane running 12S. Unless I missed it I did not see a "Giant Scale" forum.
CHELLIE 05-06-2014 11:14 PM
Hi Zippi :ws: and Welcome to Wattflyers :ws: Your Right, We Need to start a Giant Scale Forum Thread here on Wattflyers :ws: Take care and have fun, Chellie
kyleservicetech 05-06-2014 11:27 PM
Giant scale and electric power work rather nicely together. Just be prepared for $$$$ Sticker Shock!
Here is some of my stuff.
Model Airplane Power Systems (Electric, glow, gasser)
http://www.wattflyer.com/forums/showthread.php?t=73275
Carl Goldburg Extra 330 Electric Conversion
http://www.wattflyer.com/forums/showthread.php?t=59273
Giant Scale electric motors vs Gasoline Engines
http://www.wattflyer.com/forums/showthread.php?t=58035
Harbor Freight Gasoline/Alternator Setup
http://www.wattflyer.com/forums/showthread.php?t=66066,
Great Planes Giant Big Stick Electric Conversion
Giant Scale Cessna Model
http://www.wattflyer.com/forums/showthread.php?t=66414
Redwing MXSR Model
http://www.wattflyer.com/forums/showthread.php?t=72225
That MXSR model is currently my favorite. Flies well, looks very nice, and that Hacker A60-5S motor with a 10S2P A123 pack hauls that model straight up, out of sight. The wheel pants are crap though. Cheap plastic.
fhhuber 05-06-2014 11:30 PM
Sticker is not as bad as it used to be... You can get the batteries for 12S 5000 mah for under $150 now.
Zippi 05-07-2014 12:01 AM
Thanks for the info guys. Fhhuber is correct. As long as you don't go all out like the Hacker Q80-8M which is $650.00 it's about the same price as a gasser. You can get 5000mah 6S 40C packs anywhere from $70.00 - $100.00 that will hold up well. ESC's are about the same. Depends on what you by.
Zippi 05-07-2014 12:06 AM
1 Attachment(s)
I'm looking at the new 60CC Extra 260 Free Style that Aeroworks just came out with. A club member has the new 3DHS 92" Edge 540 running on 12S with the E-flite Power 360 running a 22X10 3 blade prop and it has tons of power. My current project. Was going to use my E-file Power 360 on this one but went with the EME 60 C.
kyleservicetech 05-07-2014 12:30 AM
That Eflight Power 360 looks really good on motocalc.com. And, it's half the price of the Hacker A80.
Do have a question though. Your friend is running this motor on a 22X10 three blade prop? Has he measured the RPM and Amps input? Just curious.
$140 for a 12S LiPo pack? Prices have come down.
One thing for danged certain. Since you've run giant scale before, you're will aware of that propeller up front. But with electric power, just a flip of the throttle can start that :censor: thing up. If your transmitter has a "Motor Kill" switch function, be sure to use it. :cool:
Also, with landing your model, be careful with a sudden full power "Go Around". If the model is close to stalling, sudden full power can result in the motor instantly accelerating, and the model instantly rotating 90 degrees to the left. Apply power slowly, like a second or three. I had a giant scale model 5 feet off the ground with wings at 45 degrees, doing that.
kyleservicetech 05-07-2014 12:34 AM
Question
Is a 5000 Mah battery big enough for this motor while pulling 130 Amps? That's over my level of expertise. :oops:
kyleservicetech 05-07-2014 12:38 AM
Something I've run across on these giant scale conversions, is that motor. The Eflight 360 motor is 44 ounces. I think that is a lot less than those 50 cc gassers. Makes for really trying to move the LiPo battery pack as far forward as you can to avoid a tail heavy model.
One big difference between electric power and those big gassers. That would be vibration. Last year, I put together a "G" meter that measures acceleration some 4000 times per second, and shows peak values. One of my club members had a gasser with a 150 cc twin cylinder engine up front. While that engine was idling, that G meter showed over 25 G's vibration directly on top of the aileron servo. Vibration levels at the location of the internal rudder servos (there were three of them ganged up) was on the order of 12 G's depending on throttle position. Higher RPM's smoothed it out a bit.
With electric power, there is none of this hammering the servo gears, or the airplane itself.
Zippi 05-07-2014 12:46 AM
Originally Posted by kyleservicetech (Post 947597)
Question
12S so that's running two 5000 mah 6Spacks. Here is the video I shot. The power of this motor is amazing. Judge for yourself.
http://youtu.be/zIwZopcGVsY
CHELLIE 05-07-2014 12:49 AM
1 Attachment(s)
Hi Everyone :ws: I asked one of the Adm. to see about Starting a New, Giant Scale E Power Forum :ws: We Shall see what Happens, as there are a lot of Giant scale builders here on Wattflyers :tc: My Scratch Built Giant Foam Biplane.
http://www.Wattflyer.com/forums/atta...9&d=1399420141
http://www.wattflyer.com/forums/atta...9&d=1238377779
Zippi 05-07-2014 12:51 AM
CHELLIE,
You are the cats meow :p>
CHELLIE 05-07-2014 12:54 AM
Thank You For The Complement Zippi :$ :ws:
kyleservicetech 05-07-2014 12:56 AM
Oh :censor:
I forgot to remove the 1.6/1 ratio gear box in motocalc.com from a previous model evaluation :oops: :oops:
So, the motocalc numbers pretty much look like how your friends models flew. Even more incredible, motocalc suggests 95% efficiency. Even if that efficiency value is way the heck off, don't matter, just look at your video.
Wasn't that long ago, the common complaint is "Electric models are underpowered". I used to take a long long take off run on my 1200 watt 8 pound models, get it in the air really slowly. Like its under powered. Then, right in front of the pit area, hit full power and turn it vertical, and fly straight up out of sight. :D :D There were always a few "Holy Cows" from the peanut gallery.
kyleservicetech 05-07-2014 03:49 AM
Hi Chellie
Now that's a nice looking foamie that doesn't look like a foamie!!
Good work :cool:
CHELLIE 05-07-2014 04:18 AM
Originally Posted by kyleservicetech (Post 947616)
Hi Chellie
Good work :cool:
Thank You Denny for the complement :$
thepiper92 05-07-2014 05:32 AM
Originally Posted by kyleservicetech (Post 947604)
Oh :censor:
Sounds like a drag racing Prius.
fhhuber 05-07-2014 06:50 AM
I was attempting one of the extreme standing starts possible with electric now and spit the bell, 22 inch prop and spinner off the airplane. From a standing start the 13 lb plane jumped forward 6 ft and the prop assembly went over 75 ft.
Sheared the snap ring holding the shaft in the motor.
The ESC didn't survive the sudden loss of resistance in the motor windings.
That one was propped for appx 3500 watts.
kyleservicetech 05-07-2014 02:36 PM
Yikes! The motor came apart? What brand motor?
For other wattflyer readers, without the bell, electrically that motor is pretty much a dead short circuit.
For what its worth that can't happen with the Hacker A60 series motors. Their shafts are one piece with a shoulder on the back side of the motor. I've had the A60 shaft grub screws come loose though.
Methinks every motor has some sort of problem eventually. Those cheap screws came loose after about 300 flights. That was a real sob to fix.
fhhuber 05-07-2014 02:57 PM
Turnigy motor, rated for 12S and 100 amps.... I bought a pair of them and both were nothing but trouble. Turns out they put the magnets in with hot melt glue and it only took 120 F to get them out.
thepiper92 05-07-2014 05:49 PM
Oh I know that well. Were those motors red? I have one in my mini switch, 2836 size. Power: 1200kv with 8x6 prop, unlimited vertical. Quality: not great, couple flights an a magnet debonded.
kyleservicetech 05-07-2014 05:54 PM
Good grief. What are they using, old chewing gum:D :eek:
thepiper92 05-07-2014 05:55 PM
Good idea for a motor shaft, eliminates the need for a screw to secure it. Wonder if it is possible to find a screw and use that as a motor shaft, as the head of the screw would hold the shaft in.
fhhuber 05-07-2014 10:01 PM
You can get a NAIL and have it machined into a shaft with a head to prevent ejection from the motor. It will be less hard than original, but should work fine.
Probably cost more than the motor if you can't do it yourself...
kyleservicetech 05-07-2014 10:32 PM
LOL
I've done that myself on my lathe. Machining to the tight tolerances required for the bearings to fit right is a real pain in the :censor:. It's going to take a few hours.
Especially when you can buy a Hacker replacement shaft for an A40 motor for $5.00. :oops: :oops:
Just thought, you can buy millimeter sized shafting for motors that don't sell spare parts. Right off the shelf from www.speedymetals.com and likely many other places.
http://www.speedymetals.com/s-18-o-1-metric.aspx
This web site is interesting looking over, since it lists all sorts of metal products, their specs, and typical uses.
Page generated in 0.04233 seconds with 13 queries
