-   Multi-Rotors (http://www.Wattflyer.com/forums/forumdisplay.php?f=244)
-   -   Quick help! Spektrum DX5E work w/ quad? (http://www.Wattflyer.com/forums/showthread.php?t=73716)
leadpan 05-09-2014 04:12 PM
Hi folks,
I'm building my first quad. I've order a 9 channel transmitter from China.
But my quad is ready last night and I want to test it on my Spektrum DX5E.
IS THIS POSSIBLE?
Thanks.
Wildflyer 05-09-2014 04:31 PM
If your quad's receiver is DSM2, then it should be possible to have basic control. If you have anything more than just basic flight functions, they probably won't work until you get your 9 channel.
fhhuber 05-09-2014 05:15 PM
Can not answer without knowing what RX is in the quad... and what mix functions, if any, are needed to run your quad's multifunction board.
JetPlaneFlyer 05-09-2014 05:23 PM
For a basic flight controller like a KK2 then yes, five channels is enough. Assuming obviously that the quad in question uses a DSM2/DSMX compatible receiver.
leadpan 05-09-2014 06:02 PM
hi,
I'm going to use OrangeRX 710 with HobbyPeople flight controller http://www.hobbypeople.net/index.php...ller-4-6x.html
The instruction on this flight controller says I need to tune the ESC first with my transmitter then plug into flight controller? :confused:
Sorry, this is my first quad setup (i fly rc planes usually) so i'm bit unsure. :rolleyes:
JetPlaneFlyer 05-09-2014 06:33 PM
Yes, that sounds correct. You need to calibrate the throttle end points on the ESC's.
Directions for that should be in the ESC manual, but most often you do it by putting the Tx throttle to full, then turning on the Rx/ESC, when you get a beep close the throttle.
Flubber 05-10-2014 02:57 AM
Remove the props. Connect the esc directly to the receiver throttle channel. Turn on radio move throttle stick to full up. Power up the esc. (prop removed only) wait for beeps. Move throttle to low stick listen for more beeps, Power down esc. Repeat this process for each esc. Then connect them back to flight controller. You can us a y connector to do two at a time. Double check everything and have a great first flight.
leadpan 05-10-2014 07:19 AM
2 Attachment(s)
Thanks, I got the ESC calibrated.
But now I can't get the OrangeRX to bind with transmitter or could it be the transmitter is not talking with flight controller cause it needs a S-bus cable? :confused:
JetPlaneFlyer 05-10-2014 07:55 AM
You have me confused now... How could you callibrate the ESC's if the Rx wasn't already bound to the Tx? And if it was bound why are you trying to do it again?
To clarify; you must bind the Tx and Rx together before you do the throttle calibration. After binding remove the bind plug.
You don't need anything plugged into the S-bus, but do double check that all plugs are plugged in the right way around.
Flubber 05-10-2014 12:02 PM
In your images I think the bind plug is still in the receiver.
From the F/C 's manual you have to set the dip switches for the type of transmitter / receiver you are using. Then do a radio calibration process. Is this where you are getting stuck?
Double check all the connections and instructions. Bind the receiver again without powering up the F/C remove the bind plug and power down. Set the dip switches and make the Throttle thru rudder connections. Then power up and complete the radio calibration.
One step must be completed to start the next. The F/C has proven smarter than I am on many occasions.
leadpan 05-10-2014 04:15 PM
Hobby People Flight controller issue
2 Attachment(s)
Sorry guys, let me try explaining again.
-I did what flubber said "Connect the esc directly to the receiver throttle channel" and calibrated the ESC individually.
-Then I tried following direction from this HP manual for this flight controller. I already set the DIP switch to quad-X and for DSM2 Tx. But I can't bind at this point.
http://www.hobbypeople.net/media/upl...sers_Guide.pdf
-I've done everything up to this part of the F/C guide. It says I need to do special S-Bus something for DSM2 transmitter? (I have the Spectrum DX5E)
(from F/C guide) :
DSM2 and DSMX Receiver Binding:
If you’re using a standard or S-BUS receiver, bind your transmitter and receiver pair following
the instructions in your transmitter User’s Guide. If you’re using a DSM2 or DSMX receiver, follow
the steps below to bind the transmitter and receiver pair along with the Super Multi-Rotor Controller.
1) Connect your receiver to the DSM2/DSMX Receiver Port, then set DIP switches 3 and 4 for receiver
type Standard or S-BUS. Plug your model’s flight battery into its power adapter to power ON the
Super Multi-Rotor Controller and wait for 2 seconds, then disconnect the flight battery.
2) Set DIP switches 3 and 4 to match the receiver type you’re using (DSM2 or DSMX), then plug the
flight battery in again to power ON the Super Multi-Rotor Controller. Once your receiver’s bind LED
begins to flash, turn on your transmitter to complete the binding procedure.
JetPlaneFlyer 05-10-2014 06:11 PM
You need to set the dip switched for 'standard' receiver type, not for DSM2. The reference to DSM2 and DSMX is only applicable if you are plugging a satellite type receiver direct into the flight controller (which you aren't).
Of the section you quoyed only the first sentence is applicable for you:
leadpan 05-10-2014 06:16 PM
OIC!
I'll try it and report back.
Thanks!
leadpan 05-10-2014 07:33 PM
No dice.
Set DIP to "standard" and calibrated on f/c but still nothing. :(
The f/c is green light and seems on but no response when I throttle.
I'll take to HobbyPeople today and see what they say.
JetPlaneFlyer 05-10-2014 07:50 PM
Originally Posted by leadpan (Post 948066)
No dice.
Follow these steps:
  1. Remove the flight controller and bind the Rx to the Tx as per the Spektrum instructions. You should see the light on the Rx turn solid when bind is achieved. Remove bind plug after binding.
  2. Do callibration of ESC's as per previous instructions with ESC's connected direct to Rx (flight controller still removed)
  3. Test that system is working by test running the motors and ESC's one at a time connected direct to Rx throttle channel and with props removed (flight controller still removed).
  4. Double check that dip switches are correctly set for 'standard' receiver and connect up flight controller double checking connectors are all in the right place and not plugged in upside down. (Do not re-bind and do not re-calibrate).
Flight controller should now operate. Most flight controllers have an arming procedure that you need to follow in order to power up the motors, if so this should be in the manual.
leadpan 05-11-2014 07:27 AM
Update:
I went two different local hobby store; they could not figure out.
The guy at HobbyPeople have not built one yet so he didn't know.
Both store thought the OrangeRX R710 was probably the culprit.
I took my quad home and re-ran the steps in the manual on a 3 different receivers.
-Sprectrum Eflite Rx
-OrangeRX 615
-LemonRX
It worked on the Sprectrum RX then on the OrangeRX 615! :eek:
Then I tried LemonRX and it STOPPED working again! :confused:
I put back Spectrum RX then OrangeRX 615 again; no dice.
Clearly getting frustrated at this flight controller from HP. :mad:
It's late so will try again tomorrow.
JetPlaneFlyer 05-11-2014 09:51 AM
Just make sure the Rx is bound to the Tx prior to connecting the flight controller.
The various receivers are probably different protocols (DSM2 vs DSMX) which would explain your problems. Try re-binding to the OrangeRx 615 or eFlite Rx and all should be good again.
If the Lemon is DSMX then after binding the Tx to the Lemon then the DSM2 receivers wont connect to the Tx any more as the Tx will now be in DSMX mode.
Flubber 05-11-2014 04:17 PM
Oh Joy
When you say throttle what do you mean?
All the F/C need to be armed. Yours is throttle stick down and to the right for five seconds. The status light should flash green. If it does not, Try down and to the left. If it arms stop, keep the throttle down and move it to the right to disarm. Reverse the channel and start again.
If left or right do not work try lowering the throttle channel trim and arming. One of mine multis needs low trim to arm. Proceed with caution. Prop removal would be a great safety idea.
Good Luck
fhhuber 05-11-2014 06:19 PM
Each ESC controls power (throttle) for its associated motor.
If any ESC is not properly programmed then that motor will not respond the way you want it to.
It can be a mess trying to program all of the ESCs of a quad at one time, so what was recommended above was to disconnect the quad's multifunction mixing/gyro board and just use the TX and RX for the ESC programming.
If you follow the same steps in the same way when programming each ESC separately they they will all have the same throttle response: not moving anything except the main power stick they will all start spinning together and will all hit max power at the same time.
This makes it easier for the multifunction board to hold the quad steady in a stationary hover.
leadpan
Swapping in an RX with problems might cause you to need to redo the ESC programming and/or any programming in the multifunction board... or it could even damage the ESCs or multifunction board.
Its very hard to predict the results of attempting to use a failed RX.
Since that quad DID work with 2 RXs and won't work with the 3rd you know the 3rd failed.
I'd blame the Lemon RX (appears to be well named...) not the other stuff.
pizzano 05-11-2014 06:20 PM
Originally Posted by leadpan (Post 948132)
Update:
-OrangeRX 615
-LemonRX
To reduce the frustration, first find out from HP (although, I never buy anything but batteries from them)......what the manufacture states are compatible control board systems......you may find there are a few that are.....Also, consider calling a few other LHS's like Hobby World, if one is near by, I've found they employ guys who have ton's of experience or are able to refer you to a good source for info.
Then take a look at this link....it's well done and is updated:
http://oddcopter.com/flight-controllers/
Compare those on the above list.......and replace the HP module with a better system.....make sure, if you intend to use something other than a Spektrum TX/RX, that what you replace is also compatible.
I think I mentioned previuosly:
"Never go with "low-budget" electronics......the frustrations you will experience trying do dial in the various aspects of the OS and telemetry (especially for a novice) can be a "deal breaker" if you do not have a buddy or club member walk you through such......do not rely on the forums to get you very far quickly!"
Flubber, knows his stuff and is very experienced with less expensive sytems like those sold by Hobby King....Multiwii, arduino, and the multiwii GUI, KK2.0........although most of those are PC programmed, have a more complicated learning curve to dial-in and require firmware updates .......I'm more familiar with NAZA, but it's pricey.
Try to stay patient and positive.......determination will overcome frustration.......;)
leadpan 05-11-2014 06:35 PM
Pizzano, that's a great link for F/C comparison!
Has anyone have experience with UAVP?
pizzano 05-11-2014 06:50 PM
UAVP.....?
Opening another can of worms......:D
I'd walk before I'd run.....it's advised that incorporating UAVP must be adaptable to a "closed loop-control algorithums" platform......that said, most "higher-end" NGOS are compatible to NAZA....and requires more than a "apprentices" knowledge to confiqure and refine......but I guess if one wants to "DYI" as part of the beginning build....it would save adding to ones system later.....:rolleyes:
leadpan 05-12-2014 04:00 AM
3 hours trying and still nothing! GRRRR!! :mad:
I'm about to take this whole thing back to HobbyPeople.
None of my RC planes were this PROBLEMATIC!
leadpan 05-12-2014 04:33 AM
Its working now!
I was about to give up then tried putting OrangeRX 615 once more and motors spins!
Quick observation:
I notice when motors are unlocked just 2 motors are low spinning until I give more throtle . is this normal?
leadpan 05-12-2014 07:42 AM
Hmm, it seems not all the ESC (or motor?) is working correctly. Any ideas?
Also, I'm not sure if the props needs to be upside down? The pitch seems off?
http://youtu.be/MelQJn0QUnE
Thanks for all the help! :)
Page generated in 0.04518 seconds with 13 queries
