-   -   Tacon Big Foot 110 (http://www.Wattflyer.com/forums/showthread.php?t=73802)
weakcreature 05-28-2014 01:17 PM
Tacon Big Foot 110
Im still new to this electric flight thing. I have been having problems for a while with motor esc and battery setups. I do own a wattmeter.... but Im messing everything up so please be patient. Im trying to put a SIG Four Star in the air. Ive seen 6s setup ups with 100a esc's and and 110 size motors. SO I went and got a Tacon Big Foot 110 and a Castle Creation 75a HV ESC up to 8S. Will this setup work if Im running (2) SkyLipo 4S 4000mah lipo in series? Prop will be a 18x6. TIA
Chris
CHELLIE 05-28-2014 01:48 PM
Chris
Hi Chris and Welcome to Wattflyers :ws: What size SIG Four star do you have, they make the Four Star 120, 60, 40, 20 we need more info on what plane you have, second, the Tacon 110 is a low KV motor 295KV and is ment to fly on 14 cell lipos, an 8 cell lipo might not be enough voltage for that Motor,
http://www.hobbypartz.com/96m607-big...325-295kv.html
CHELLIE 05-28-2014 01:53 PM
here is a 90 size motor that will work with a 8 cell lipo and your 75 amp ESC,
http://www.graysonhobby.com/catalog/...0gsvvd2jcstir4
weakcreature 05-28-2014 01:57 PM
Im sorry I thought I put that in there. Its a Sig Four Star120....
weakcreature 05-28-2014 02:03 PM
https://www.youtube.com/watch?v=4i4LniMkez8
I found this....
CHELLIE 05-28-2014 02:04 PM
I Found this on You tube, the guy is using a 8 cell liop, and a 19x8 prop with a tacon 110 motor, So Maybe you might be ok with 8 cells
I found the same video :)
CHELLIE 05-28-2014 02:09 PM
here are the specs on the Four Star 120, you might be OK with your set up. Give it a try :)
http://www.sigmfg.com/IndexText/SIGRC65ARFR.html
http://www.sigmfg.com/images/yy1SIGRC65ARF.jpg Its gentle handling will set the low time flyer at ease but it is capable of satisfying the advanced flyer with its maneuverability and smooth handling. This is a sport model you will want to take to the field every time. You will love the two-piece wing that makes storage and transport easy. The Four-Star 120 ARF has been engineered to get you into the air as quickly as possible with an R/C model that will truly last. The balsa airframe has been expertly built making extensive use of lite-ply for strength and covered with Sig AeroKote®. Sig Checkerboard AeroKote® is used on the bottom of the wing and horizontal stabilizer to make this model visible even at extreme distances. Includes virtually everything to complete your model including engine mount, fuel tank, matching anodized aluminum landing gear, factory-painted fiberglass wheel pants, wheels, deluxe tailwheel assembly, Sig spinner, pushrods, linkages and decals. Assembly is super quick using the detailed, fully illustrated assembly manual.
  • Key Features
  • Two Piece Wing For Easy Transport
  • Professionally Covered With SIG AeroKote®
  • High Visibility Checker-Board Trim
  • Fiberglass Wheel Pants
  • Deluxe Tailwheel Assembly
  • IMAA Legal
  • Low Wing Loading Gives Outstanding Slow Speed Characteristics
  • Pull-Pull Rudder Linkage
http://www.sigmfg.com/images/yy1SIGRC65ARFa.jpg http://www.sigmfg.com/images/yy1SIGRC65ARFb.jpg Specifications Wing Span 81 in. 2057 mm Wing Area 1205 in² 77.7 dm² Length 65 in. 1651 mm Flying Weight 11.5 - 12 lbs. 5220 - 5440 g Radio Required 4 Channel w/5 servos
(rudder servo 80 oz./in. minimum and 1200 mAh receiver battery required)
Engine .90 - 1.20 in³ (15 - 20 cm³) 2-Stroke
1.20 - 1.50 in³ (20 - 26 cm³) 4-Stroke
Page generated in 0.07651 seconds with 15 queries
