-   Batteries & Chargers (http://www.Wattflyer.com/forums/forumdisplay.php?f=6)
-   -   Lipo lament (http://www.Wattflyer.com/forums/showthread.php?t=73823)
Beaverstretcher 06-01-2014 01:33 AM
Lipo lament
I recently purchased an rtf Flyzone Beaver with the 1800 mah battery and a spare 2200 for backup...when I charge them the charger never reads charged...any ideas what causes this? I've tried them on 2 different chargers with the same results.
CHELLIE 06-01-2014 02:24 AM
take a Multimeter and check the individual cell voltages at the balance plug, you could have a weak/bad cell, if not, then your battery chargers are not up to snuff. what battery chargers do you have. cheapy battery chargers are more problems then what they are worth.
Beaverstretcher 06-01-2014 02:50 AM
I have the electrifly balancing chargers that came with my planes...they charge my 1300 mah just fine but the 1800 and 2200 don't ever go red for full charge...will run to the shop for my meter shortly.
CHELLIE 06-01-2014 03:50 AM
I Think you need a stronger charger, the electrifly chargers only charge at about 120ma, here is a nice inexpensive 6 AMP charger that a lot of people like and it wont break the bank :D
http://www.hobbyking.com/hobbyking/s...cessories.html
kyleservicetech 06-01-2014 04:47 AM
Hi Chellie
Could you re-check that web page? Don't think it works.
DEG 06-01-2014 04:49 AM
Try it again Denny.....works fine here.
fhhuber 06-01-2014 04:54 AM
http://www.nitroplanes.com/73p-ac680-accharger.html
Or equivalent will work very well.
You have to check the site regularly because these sell out as fast as they come in. These chargers have a great reputation and Nitroplanes just can't get then fast enough to keep up with demand.
Turnigy (Hobby King) has the same charger just a different label. When ordering from Hobby King make sure you choose the closest warehouse and watch the shipping charge.
(Nitroplanes shipping isn't cheap either but cheaper than from Hong Kong to Texas...)
kyleservicetech 06-01-2014 04:56 AM
Strange, still no go.
Guess I'll have to reboot my PC and try it again :eek:
kyleservicetech 06-01-2014 07:37 AM
Rebooted my PC, still no go. Rebooted my cable and modem, and, got it back! :D :D
thepiper92 06-01-2014 07:51 AM
I use an IMax ACB6. It's cheap and has been going strong for 3 years.
Beaverstretcher 06-01-2014 08:09 AM
Thanx folks for the assistance..I'm a noob at electric and just got back into flying after a 17 year break...I'll be looking into one of these as soon as I can wrestle the CC from the wifes death grip :-)
solentlife 06-01-2014 09:00 AM
Get the Accucel from Hobby KIng ... they are a good machine ... and get a power supply as well ... minimum 5A ... on Ebay you can buy Mains adaptor supplies that are made for LED light strips ... I have a 6A one for my 6 ... works a treat.
I advise against the AC versions of chargers - those that have mains adaptor built in ... I have a ACB6 and the mains part failed first year .. which is not uncommon. So now it works same as my standard B6 - with separate 12v input. Much better to have separate ...
The charger overall is smaller.
JetPlaneFlyer 06-01-2014 09:26 AM
yeah, the problem with those ultra cheapo chargers that come with RTF models is that their cell balancing current is so low that they often fail to complete the charge because they cant balance the cells, especially on larger batteries than they were originally intended for.
The B6 or Accucell is a lot better and fine if you don't ever intend flying anything larger than about 2200 3s and/or you don't want to charge multiple batteries together. Personally my recommendation would be for a charger that had more power to better cover future growth, say one of these: http://www.hobbyking.com/hobbyking/s...e_Charger.html
While it is three times the cost it has six times more power of the Accurately-6, so far better bang for buck in terms of watts per $. It's also far quicker if you want to drain batteries down for storage and it's balancing current is higher. It will also do stuff like cell resistance checking that's lacking in the cheaper chargers.
But it depends on your budget of course.
solentlife 06-01-2014 11:18 AM
I hear the latest Acc 6 now has IR cell checking as well ...
For about $10 more - the Acc 8 is not so bad ...
CHELLIE 06-01-2014 02:42 PM
Originally Posted by kyleservicetech (Post 949441)
Hi Chellie
Hi Denny :ws: The link works, you might have your security set up to high on your comp.
Beaverstretcher 06-01-2014 03:24 PM
Again , thank you all for your input and speedy responses...I live at least a 5 hour drive from the nearest hobby stores or clubs so your advice is highly valued !
Page generated in 0.03931 seconds with 13 queries
