-   Aircraft Reviews (http://www.Wattflyer.com/forums/forumdisplay.php?f=180)
-   -   E-flite UMX Pitts S-1S (http://www.Wattflyer.com/forums/showthread.php?t=73849)
thepiper92 06-07-2014 07:31 AM
The UMX Pitts S-1S has become one of my favorite planes, and so far my favorite micro. I have been flying for a year now, mainly planes 30 inch wingspan or more; I am currently building a 60 inch wingspan Hurricane. My main style of planes are single prop warbirds, and so the UMX SBach and Pitts are not only my first micros, but first aerobatic planes. The Pitts weighs in a bit heavier than the UMX Sbach, but with a larger prop and higher kv motor, speed is roughly the same. The UMX Pitts does not climb out to the extreme level as the UMX Sbach, but the aerobatic abilities of the plane are very good, nonetheless.
Take off and ground handling are very admirable; the plane steers quite easily, although has a habit of hitting the wing if turns are too fast. Taking off is easy and has no tendencies to stall, and I am sure hand tosses would work as they do with the SBach. During flight, the plane handles solidly, even in mild wind, with very good authority from all control surfaces, allowing one to do knife edges with help from aileron input, loops, rolls, snap rolls and inverted requires only a bit of elevator input. This plane is not one to hover, put it can climb vertical quite well. I have yet to carry more moves successfully in flight, such as the lomcevak or hovering, though I doubt a plane of this size can perform it, as well as the facts that I am still learning and wind is seldom zero. A larger 300mah does help in wind.
Slow flight performance is good, although it is not a plane that likes to be flown at much less than full throttle I feel. I seldom fly the plane sedately, and find myself constantly in the upper throttle ranges, unless I am purposely stalling the plane, or attempting hovering, which thus far has only resulted in the plane veering off vertical. Perhaps high rates will help, with the rods positioned on the second or third holes of the horns.
Landing is easy with the plane, and it can be taken down to a very slow speed without stalling. Because of take off and landing characteristics, one could actually learn these important aspects of flight as a beginner. This is not to say a new person to flight should get the Pitts, or perhaps any micro, but with the help of a more experienced flyer, and lessened throws from the surfaces, learning flight would be possible. What I mean by this is an experience pilot taking it up, letting the new flyer have a few chances with sticks and progress. Perhaps some feel this to be incorrect, but I personally learnt on a plane not many would use as a first plane, a mini switch, in mid wing configuration to boot.
The build quality of the Pitts is amazing, featuring great scale features, and actual wheel pants, versus the fake pants on the Sbach, which also happen to move around in flight. I admit, I have had two flights which resulted in damage. On was hitting into a powerline and the other was flying in too much wind and on landing the wind pushed it sideways. Repair was easy, although it doesn't quite look perfect if you look closely. One negative with repair though, is that the parts are expensive, including the prop mount, which is also far to weak. I don't crash too often, so this isn't a big deal, but it would be nice is props, mounts, spinners, etc, were a tad cheaper; a big APC prop costs less than a tiny thin UMX prop.
My only negatives about the plane are the cost for replacement parts, and run time. It would be nice if the plane had the same run time as the SBach, although it is heavier and has a higher kv motor, so it is impossible that it would get the same run time. I have already thrown in a 300mah battery, instead of the 200mah that was in the SBach, and run is noticeably longer, but I feel it is still less. It would take some experimentation to see how much larger of a pack can fit in the plane without hurting performance/actually decreasing flight time. The 300mah packs, being higher mah and higher C rating, 35C rather than 25C, actually increase performance and run time, clearly due to the fact that the plane is pushing the 25C 200mah packs, noted by the temperature of the packs after flight. I have 500mah packs on the way and I am hoping they will do well.
Overall, one amazing plane.
dahawk 06-07-2014 01:36 PM
Thanks for the review. Any video footage ? It's on my Fathers Day wish list I leaked to my wife and girls
thepiper92 06-07-2014 03:33 PM
I will try for some video of the plane on Monday.
max2112 06-07-2014 04:19 PM
Nice write up piper. I like when folks are honest and give good and bad characteristics.
I've been wanting a UMX for a while now. Maybe this will be the one.
thepiper92 06-07-2014 06:30 PM
There is very little negative about the plane. Flight time is a little disappointing, at less 6 minutes. The plane can get over that at lower throttle, but it is the most fun when the throttle is near max. I don't regret getting the UMX SBach, but the build leaved a lot to be desired when compared to the Pitts. I will be attempting to fly it with Hyperion 500mah 2s pack.
pizzano 06-07-2014 08:07 PM
Decent write up.....thepiper92,
A few things to consider:
1) The UMX Pitts does not fly typical of most bipes except landing ability.
2) Mention a word or two related to high & low rate performance.
3) It may be a good flyer, but what level of pilot does it best serve?
4) Can it be hand launched or better suited for ROG?
5) Given it's size, how does it handle +5mph breeze and occasional gust?
6) Mention a word or two about the authors previous pilot experience.
7) Compare flight times to a similar size/power (or equal micro/mini bipe)
Since I have now spent over 1.5 hours on my buddies UMX Pitts....(just came back from 2 more +6min flights on both low and high rate settings), just to help him adjust all of his TX settings mainly DX6i D/R & Expo, which helped with high rate/control service linkage.......this Pitts will hover for about 1.5min in calm conditions and careful throttle management.......losses power quickly when pressed at 3/4 to full throttle for long durations.......using a 2s, 7.4v, 300mAh, 30c, (which I also use on both the GWS Slow Stick and GWS Tiger Moth 400 occasionally)...we're thinking a slim line 2s 25c, 500mAh may work on this little bipe as well.... a small 3s may push the esc/motor a little to hard since it did get pretty warm when running over 3/4 throttle on high rates on 2s.
This little UMX certainly performs as advertised.......especially in calm conditions......too light and short on fuselage (15.5") to fight any windy or gusty turbulance with scale flight in mind!
thepiper92 06-07-2014 09:09 PM
Thanks for the tips. I'll add some in later. I am nowhere near as good as you at flying, I can't make the Pitts hover at all. I can get more than 6 minutes on the 300, but the 200 gets under 6. For high rates I have only been flying on stock horn setting and 90% setting on all surfaces on radio. I haven't use high and low rates.
3D MOFO 06-24-2014 11:35 AM
Has you or anyone on here ever tired to use a 6x4.5 prop wouldn't that help out to improve hovers????[popcorn]????
pizzano 06-24-2014 04:07 PM
I have not......since it will hover with stock prop, if surface throws are advanced and one manages throttle correctly.
thepiper92 06-24-2014 05:02 PM
I still can't get a hover. The SBach hovered by accident, this one takes a little more concentration. I have the Yak prop on it now, slightly higher pitch. Waiting for better weather to try it out. Well, I had one day to, but was flying the Blade Mcpx BL instead. I'll try it soon though. As for the larger prop mentioned, it would kill the motor, or batteries. The motor gets hot already if you fly it hard. Going up in pitch and diameter is a lot to ask. On the smaller SBach motor it may be worth a try. I also have 500mah packs from Hyperion, can't fit any larger of a battery than the 500, unless it was a 550. 600, no way it would fit. 500 should give close to 10 minute flights IF it doesn't weigh the plane down too much. It isn't a lot heavier than the 300mah, but then again all of the batteries are weightless when you hold them, but maybe not the case for the plane.
3D MOFO 06-24-2014 05:32 PM
By advancing throws you mean giving it more throw on the on the horn or on the radio?
thepiper92 06-24-2014 05:37 PM
On the horn, moving up to the third holes. Even full throws from the radio on the first holes don't do much
pizzano 06-24-2014 06:36 PM
Stock prop, battery, motor.....surface throws we have set are outer hole on everything...aileron, rudder, elevator.
Servo horns left stock....not much to adjust there except the little tab adjustment for internal linkage movement.
TX - DX6i adjustments.....we've only mixed DR/Expo for rudder and elevator since it did little when adjusting aileron due to limited physical ratios without modifying the linkage rods.........and the RX AS3x (set at the middle range)........we adjusted in every AS3x mode, seemed it was more comfortable with outer hole settings.
thepiper92 06-24-2014 06:47 PM
Can you adjust the level of AS3X aid? Or am I misunderstanding
xmech2k 06-24-2014 06:58 PM
Just don't set up the servo limits any higher in the tx. These linear servos have a knack for jamming at their end stops. If anything, despite the loss, turn the servo travels down to 95% for safety. That is, if you want that safety factor.
thepiper92 06-24-2014 07:09 PM
You are better off changing throws by horns, even on max throws you can dual rate it for low throws.
pizzano 06-25-2014 01:51 AM
Spektrum offers a USB interface programming cable.....which can be used to download various programing aspects to the SPMAS6410NBL reciever in the Pitts.....I believe my buddy has played with this....that is why we are able to adjust the amount of gain we achieve through the AS3X...or he has programmed a different model set-up and we have been tweeking that.......I'll ask him and get back with an answer...!
thepiper92 06-25-2014 03:02 AM
I noticed that device, although another programming thing to find legs and disappear. I was thinking of it for my blade mcpx BL, not sure if it would work though or if it does, whether or not you can adjust throttle. On the mcpx BL and all UMX planes low throttle doesn't exist
thepiper92 06-26-2014 04:25 AM
The Hyperion 500mah with UMX connector works well, fits in nicely, and I don't notice a loss in speed. I can feel the plane has more push however, and isn't floaty, so the weight is giving it a bit more authority I guess, and snap rolls have more snap. I quite like how it feels, almost like you have a bigger plane. If anyone else tries the 500, chime in of how it is. Note, I am using the Yak prop, but if seems the same with the stock 200, even though pitch is higher. I may have to take the idea of a six inch prop. The motor is cool with the yak prop, so maybe a 6 inch could be used, low pitch though, not 4.5. A 3 pitch maybe.
thepiper92 07-03-2014 05:22 PM
APC props are a no go. All the hubs are too high in diameter and the shaft adapters are too large. Oddly the 5.7x 3 and 6x4 are smallest, the 6x4 has a massive hub. Another odd finding is that a shaft adapter that comes with a master airscrew 14x8 prop fits the UMX mount. To make it work, it would need heavy modding such as a custom mount and something to fit in the front of the prop, so the screw can actually hold the prop on. Even then the spinner will not fit without trimming it to having barely any foam on the sides. Such experiments would suit the Yak better, which has no spinner and only the ugly screw is exposed. This is actually one of the things that made me look past the Yak, as well as the unrealistic silver canopy and the unfinished looking landing gear. I still may buy it at some point, but seeing as how detailed the Pitts is, perhaps they will revamp the other UMX planes a bit to actually look half as realistic as the Pitts. I still like my SBach of course, once I get it up and running again, but once one gets a Pitts, you see the lack of scale features on the other planes.
Joe.Lamb 08-31-2014 04:15 AM
Lovely review. Well written.
The one thing I would differ with is the slow-flying properties of the tiny Pitts. For my money, it slows right down with 200mah batteries and is very stable at near-stall-speed maneuvers three or four feet off the ground — of course you can screw the juice back on and do a rolling vertical climb back upstairs whenever you want to.
The way I fly the plane is to run my sole 180mah battery through it for a shakedown circuit and some slow rolls and Cuban 8s, then go through my menagerie of bigger batteries for vertical boom-n-zoom stuff and, like you, search for that perfect hang-on-the-prop hover, which I do think is possible with this model but it's awful hard.
At the end of the day I'll stick in a dinky little 120mah and just ooze it around a few feet off the deck like a park flyer and shoot touch-and-goes. It's a lovely airplane, and while it's really close-coupled it's got a lot of wing and it's very graceful when you slow it down.
A perfect three-point landing wants you to carry a little throttle on flare, and it is very, very pretty when you get it right with this model.
thepiper92 08-31-2014 04:55 AM
I managed a few hovers today, albeit fairly short. I was at the field earlier and was flying about, most not expecting me to be able to fly, let alone flipping around and doing knife edges. I had a crash, due to a hill actually. Being from the prairies, I'm used to flat areas, along with flat areas with an asphalt area to land. Here in this part of Ontario, even the field is hilly. I was flying low and didn't take into account the rise in the land, and it damaged the plane. When I got it fixed and went out to the field (only a few minutes drive from the cabin) everyone was gone except for one person with his son. I was flying around with his son for a bit, who was initially flying his dad's gasser, then went to a small T28. Now I never thought the Pitts of a fast plane, but compared to that T28, it like a Stinger, so I was able to fly where I wanted while the T28 was flying around lower. I took it through four packs, two 500mah, two 300mah, and managed to pull off a few hovers, all not very long, but one about 10-15 seconds, which impressed everyone including me. It was quite amazing looking. Harriers are also something difficult on this plane, or rather, not stable. This is due to the size of the Pitts and the design, causing it to teeter-totter. The only thing that was not fun was landing, as the grass is for 3 inch wheels...I cannot take the gear out of the Pitts, not sure if I accidentally glued it in the fuse during a repair, or it just is hard to remove compared to the SBach.
It is a fun plane to fly, and at some point I'll just buy a new one, run this one to the ground. It is looking a bit beat up, from a crash into a powerline, one crash because I didn't make sure an aileron horn had not slid down the control rod, one from an antenna failure causing a crash into a fence, and the one today, which broke the lower wing near the fuse and a strut (think that's what it would be called). All of these crashes have left the fuse scratched up, and the wings not looking too great. I've fixed it up and it doesn't hurt the flight characteristics, so there is no point in getting a brand new fuse or wing, especially as these new parts together are near the price of a new plane.
thepiper92 09-14-2014 11:23 PM
2 Attachment(s)
Dad took some pics of the Pitts, from a very far distance, but was able to zoom quite well. I was actually flying the plane a ways away from me to get background in, and I could barely see the plane myself. Yes...the Pitts is no WW1 fighter, but it still looks good I feel. I have the unmodified pics as well.
skywagon 04-24-2015 10:50 PM
Suggestions for the little Pitts. . . .
This is my first "tiny" flyer and I like it a lot. I am a mediocre RC pilot.
Some Control travel suggestions:
Control throw settings initially:
Aileron 50%
Elevator 50%
Rudder 70%
When you bind or fly, be sure the throttle control and its trim is set to the lowest position. The radio in these tiny planes sense if your throttle or trim is not fully down; the motor will not come alive when you go to fly.
Other Hints:
*The rudder is very effective in the air. If your new Pitts comes out of the box with a little offset, get it aligned straight before flying.
*The tiny tail wheel is usually not alighned straight with the rudder. "Bending" it into alighnment has to be done very carefully. The "wire" holding the wheel is spring steel. It is reluctant to bend and if bent too far, will snap. Use caution getting the tail wheel alighed.
*On hard landings the landing gear wheel strut panels may pop off. The tiny wire landing gear leg covers snaps into 3 little wire keepers. These snaps will break and the the panel will fall off again. CA glue will make a temporary repair, but, better is to use a small dob of hot gun glue.
*Later if the main gear wheels don't run freely, I have found that the wheel pant changes shape and may pinch the wheel causing it to bind. I fashion a small strut for a coffee stir stick or similar. Press inside the pant and glue in such that the pant cannot shrink and pinch the wheel.
*Don't try to taxi, takeoff or land in a cross wind. The take off is so short, it is always better to go directly into the wind even if it is at a crazy angle to your field. Always land into the wind.
* Don't use a lot of velcro on the LiPo. When you go to remove the battery after flying, you might dislodge the floor panel under the battery. Just use a 3/8" piece of velco so it pulls away easily. The battery will stay in place while flying with this small piece.
*If you and friends like pylon racing, this model is great for that sport. Suggest only 2 pylons, maybe set about 100 ft. apart
*Until you get the hang of the Pitts, you will most likely damage the foamy nose cone. For a while if can be CA'd back on. Buy a replacement bag of nose cones. Bag of 3 is very overpriced, $8, but, the Pitts looks "right" with a proper nose cone.
*Keep your Pitts box as it makes a great hangar for the plane and small LiPo's can be stored in the side compartments.
My apology if too much detail. . . .[popcorn]
matthewcornell 07-17-2015 03:47 AM
what props are compatiable?
Hi Guys. Busted up my first prop and I'm confused about what's compatible. HH's site says this under parts:
5.75 x 2.50 Electric Propeller (EFLUP575225) - http://www.horizonhobby.com/575-x-25...er-eflup575225
But the E-flite page says:
an E-fliteŽ 5 x 2.75 propeller - http://www.e-fliterc.com/Products/De...rodID=EFLU5250
Amain recommends the same:
E-flite 5x2.75 Electric Propeller (EFLUP050275) - http://www.amain.com/rc-airplanes/e-...050275/p185144
Thanks!
Page generated in 0.04481 seconds with 14 queries
