-   -   osilating Motor (http://www.Wattflyer.com/forums/showthread.php?t=73882)
egrave1 06-12-2014 05:33 PM
osilating Motor
I have a motor that when I throttle up the motor sits there and goes forward and backwards what could be the problem
JetPlaneFlyer 06-12-2014 07:44 PM
Nine times out of ten it's a bad connection or bad solder joint on one of the three bullets between motor and ESC.
Other less common causes are a motor lead that's broken under the insulation, or burned out winding, or a faulty ESC.
Larry3215 06-17-2014 09:24 PM
+1
xmech2k 06-17-2014 10:09 PM
Egrave, is it really going forwards and backwards, or just pulsing the power? If just pulsing, then JPF is probably right. If really going fwd/reverse, it probably needs to be exorcized!
Larry3215 06-17-2014 11:43 PM
Ive seen the forward/reverse thing quite often with bad connections. How it behaves seems to depend on how bad the connection is.
ron_van_sommeren 06-17-2014 11:52 PM
Don't play with throttle when this occurs, you may burn motor and/or controller.
Larry3215 06-18-2014 12:03 AM
Excellent point Ron. The current will go through the roof whenever the motor isnt spinning.
P.S. I almost didnt recognize you Ron! You lost the hat! :)
ron_van_sommeren 06-18-2014 12:18 AM
Originally Posted by Larry3215 (Post 950735)
... P.S. I almost didnt recognize you Ron! You lost the hat! :)
Not the only thing(s) I have lost since my previous picture was taken :D On the bright side, I gained a bit of forehead
kyleservicetech 06-18-2014 02:23 AM
Here is where it might be a good idea to temporarily wire in an automotive fuse between the battery pack and the ESC. Typical fuse size would be about 30 - 50% of the ESC current rating.
That way, if your malfunctioning setup is really pulling a lot of Amps, you'll hopefully blow the fuse, not the ESC.
Page generated in 0.04337 seconds with 13 queries
