-   Power Systems (http://www.Wattflyer.com/forums/forumdisplay.php?f=17)
-   -   Kontronik Pyro Motor question (http://www.Wattflyer.com/forums/showthread.php?t=73887)
kyleservicetech 06-13-2014 05:49 AM
Just got an email from Espritmodel.com for their $$$$ Kontronik motors. This one has only an 8 mm shaft for a 10KW motor. The motor only has 14 poles. Just can't visualize a 28 inch diameter prop on that size shaft.
Am I correct in assuming these motors are designated for helicopter use?
http://www.espritmodel.com/kontronik...ong-shaft.aspx
JetPlaneFlyer 06-13-2014 08:33 AM
Yes, that's a heli specific motor. The shaft is long because it's designed to be supported at the end by a bearing that is mounted in the frame of the heli, so it doesn't have to put up with the bending moments that you get with a prop. I have a similar spec motor in my 700 size heli.
Heli motors are also higher Kv than similar power fixed wing motors. The one you linked is for 12-14s and has 480Kv, so up to around 25,000RPM... far too high for a direct drive prop that's big enough to take that sort of power.
You could use such a motor in fixed wing with a reduction gearbox.
ron_van_sommeren 06-13-2014 03:46 PM
Kontronik lists them as 5kW continuous power Denny
Kontronik - Pyro 800 series
And if you really want $$$$ :D
Kontronik - Pyro competion series
http://www.kontronik.com/images/stor...ide_web_gr.jpg
ron_van_sommeren 06-13-2014 05:25 PM
I take it this is not you Denny? First post, and you already had your anser from Nigel
www.rcgroups.com/forums/showthread.php?t=2185474
Prettig weekend ;) Ron
kyleservicetech 06-13-2014 06:06 PM
Originally Posted by ron_van_sommeren (Post 950426)
I take it this is not you Denny? First post, and 'you' already had your anser from Nigel
Hi Ron
NO THAT IS NOT ME!
Looks like this guy copied my question and pasted it into his own thread in this web page.
Very strange.
Question, should I notify RCGroups on this issue, and if so, how?
ron_van_sommeren 06-13-2014 06:13 PM
To be honest Denny, I had already reported that post before asking you about it here. Within 10minutes it was moved to the RCG bitbucket.
It's not the first first post, copy/paste message I reported. Annoying.
Why they do it, I don't know.
kyleservicetech 06-13-2014 06:18 PM
Originally Posted by ron_van_sommeren (Post 950431)
To be honest Denny, I had already reported that post before asking you here. Within 10minutes it was moved to the RCG bitbucket.
It's not the first first post copy/paste message I reported.
Hi Ron
Thanks for the tip. At least the guy could have slightly reworded my question :confused: :cool:
hayofstacks 06-13-2014 06:37 PM
Denny, at 10kw, you might as well just pony up for one of the ford ranger ev motors made by simons and hook it up to your car ;).
Page generated in 0.03405 seconds with 13 queries
