-   Batteries & Chargers (http://www.Wattflyer.com/forums/forumdisplay.php?f=6)
-   -   Thunder AC6 dual power question (http://www.Wattflyer.com/forums/showthread.php?t=73933)
time bandit 06-20-2014 10:39 PM
I'm back into R/C planes and have this AC6 charger from about five years ago. I have noticed when I go online to look for battery packs to buy the balance plug looks different from the ones I bought before. Is my charger out of date? Have all the battery companies changed their balance plugs? The battery pack I have left is from an old Hawksky kit. Everything online says JHT XS series. I don't know what kind my old battery has but they look almost the same but I don't know if they will fit into my chargers ports. I hope this makes sense.
JetPlaneFlyer 06-20-2014 11:21 PM
JST-XH is by far the most common type of balance connector, however a very few manufacturers use their own propitiatory connector. Thunder Power (the makers of your charger) being one of them. Your charger will only accept Thunder Power balance plugs, though you can get adapters.
time bandit 06-20-2014 11:48 PM
Well I just found out what you have posted. There's a LHS that has ONYX batteries that fit my charger port. I have to swap over for deans plugs which is not a problem. This didn't seem to a problem a few years ago. Everybody has to be different. Geeezz.
pizzano 06-20-2014 11:50 PM
Take a look at this link.....could help out in the long run:
http://www.rtf-heli.com/lipo_chargers_adapters.html
I bought the large bundle multi plug package and the modified balance plug board from them a few years ago......been lucky I guess, have not purchased any battery it did not match.
time bandit 06-21-2014 12:01 AM
Thanks for the info guys. I should have reasoned that there was some gizmo that would plug into what I have now. I swear every time I turn around there's something else I need or have forgotten about in order to get going again in this hobby. But I'm glad to be back.:D
time bandit 06-23-2014 12:20 PM
It's a real shame that these companies won't get on the same page and use the same type connector. They make it difficult for the consumer. Why should I have to buy special balance boards (although inexpensive mostly) to cover the wide range of different balance plugs?? :mad:
Wrongway-Feldman 06-23-2014 01:45 PM
I don't think I've ever bought a battery that didn't have a common balance plug. I've got a 8 year old lipo that also has a standard plug.
I think that ONYX battery might be a little different due to it being a duratrax battery made to go with their charger.
Those rc car guys really get screwed over when it comes to manufacturer specific parts. They spend $500 on a model and then spend double that upgrading it.
fhhuber 06-23-2014 04:54 PM
The plug used on Sky Lipo, Turnigy and E-Flite packs is the most common. (note that some smaller packs by these companies use a smaller pin spacing plug to save weight with a reduced size plug)
Thunder Power and Poly Quest are among the oddballs.
Page generated in 0.03395 seconds with 13 queries
