-   Hi-Performance and Sailplanes (http://www.Wattflyer.com/forums/forumdisplay.php?f=10)
-   -   Micro in-door tow line sailplane? (http://www.Wattflyer.com/forums/showthread.php?t=74035)
Larry3215 07-07-2014 06:15 AM
On of the guys in our club came up with a proposal for our indoor flying season. We typically fly once a month in the winter at a local church's gym.
His idea is to build and fly tow-line launched, micro sailplanes indoors. It sounds like a hoot to me! :D
Initially, a couple of the guys wanted to limit the wing span to 18". Then they upped it to 24". However, I pointed out that making things smaller is exactly the opposite of what you want to do if you want slow flight.
For sailplanes especially, wing span is your best friend. Wing loading is a distant second but still important. Its also much easier to get the span loading down if you build larger rather than smaller. Below a certain size, you start to need super light weight gear to make it workable. Ive found its much easier (and cheaper!) to use normal micro sized radio gear and put it in a larger foam model with as few weighty items as possible.
For launching, the options discussed were rubber band bungie, micro winch, something like the OneWinch and just pulling the string by hand as in towed launching. I thiink it would be a hoot to try to tow one up using another indoor model - like a Vapor :D
My plan at the moment is to shoot for something in the 60" to 79" range as far as span. It will have an under-cambered Depron wing with center dihedral and be RE only.
Even if it turns into a crash-n-burn session, it should be a hoot!
fhhuber 07-07-2014 06:44 AM
http://www.horizonhobby.com/products...nf-EFLU1280#t2
Been done... in mass production. And much smaller than you are planning.
I'm not sure why they discontinued it. Reviews were very good.
Larry3215 07-07-2014 06:53 AM
Ive seen those in person and got to fly a couple of batteries through a friends. They fly fairly well but waaaaaay too fast for indoor in the space we have. We have roughly the space of 1/2 of a basket ball court.
Thats the problem when you scale down. The weight doesnt go down fast enough to keep the speed manageable in a very small space.
Rockin Robbins 08-17-2014 07:05 PM
UM Radian is your pattern plane. Buy one and see how great they are and try to duplicate the characteristics!
Larry3215 08-18-2014 04:00 AM
Have you tried to fly one indoors? I have only watched other guys fly them, but they look to fast for indoor flying in the space we have.
We probably wont get a chance to try this until Oct/Nov. I will report back when we give it a go.
Rockin Robbins 08-21-2014 07:56 PM
Larry, if that won't fly slowly enough then I'm afraid it'll be necessary to build something based on some indoor free flight gliders. That could be fun!
fhhuber 08-21-2014 09:54 PM
Pull the motor off of a Vapor and move the electronics + battery forward. Longer pushrods needed... but that should float along about as slowly as is possible.
A stock Vapor should be able to tow it.
Larry3215 08-21-2014 10:51 PM
That would work for sure!
Page generated in 0.03161 seconds with 13 queries
