-   Foamies (http://www.Wattflyer.com/forums/forumdisplay.php?f=9)
-   -   FMS Extra 300 needs more power...ideas? (http://www.Wattflyer.com/forums/showthread.php?t=74318)
jeff4912 08-18-2014 12:38 AM
Anyone have recommendation for boosting power on this plane?
Has a proprietary type prop shaft on it.
Current specs:
Length
1285mm / 50.6in
Flying Weight
1880g
Power System
3948-Kv760 Brushless Motor
Speed Control
60A ESC, Internal 3A SBEC, T Connector
Propeller / EDF
13x5 3 Blade Scale Propeller
Servos
17gx4 metal gear
Landing Gear
Fixed
Required Battery
14.8V 2500-2600mAh 25C 4 cell LiPo
Required Radio
4 Channel
kyleservicetech 08-18-2014 02:55 AM
Current specs:
Length
1285mm / 50.6in
Flying Weight
1880g
Power System
Speed Control
Propeller / EDF
Servos
17gx4 metal gear
Landing Gear
Fixed
Required Battery
Required Radio
4 Channel
Have you checked the watts input to your motor with one of those wattmeters?
Your model is around 4 pounds, so good performance would be around 150 Watts per pound, or 600 Watts. Go above that, and look out!
I've got a Vyper model of about the same size and weight with aHyperion HP-Z3025-10 motor up front. This Z3025-10 motor might be a bit hard to find, mine came from Ebay. Running with a 5S A123 battery pack, this motor is running about 600 watts on a 13X6.5 prop that turns at 8300 RPM. The model flies straight up, and accelerates doing it.
http://www.wattflyer.com/forums/showthread.php?t=73065
Here is an 8 turn version of that motor. You'd have to play around with propeller sizes, and a wattmeter to set up optimum performance. FYI, this is a well made motor with real performance.
http://www.ebay.com/itm/Hyperion-ZS-...item2c8009b659
I don't know how strong your model is, but one thing to consider, really beefing up your power system could result in in flight structure failure of your model. From what I can tell, this is a foamie model, so putting far more power up front could be a real issue.
This motor is going to turn an 11-6 prop at some 12,000 RPM on a 4S LiPo battery, pulling around 60 Amps, and 700 Watts. Also, check out the various $$$$ Hacker A30 and A40 series motors. I've got two A40 motors that perform well on models weighing in at about 4.5 pounds.
What will help you on this model is one of those computer programs. I've been using www.motocalc.com, that works out well.
JetPlaneFlyer 08-18-2014 05:46 AM
In theory those specs should be giving plenty of power. I'd also suggest putting a wattmeter on it to see what's going on. It could be that it's just a case of the battery being tired and not holding voltage.
CHELLIE 08-19-2014 01:04 AM
use a 5 cell lipo 3000 mah and a 12 x 6 - 2 blade apc prop, check your Amp and Watts, keep the Amps to about 60 Amps, make sure your ESC can handle a 5 cell lipo
http://www.hobbyking.com/hobbyking/s...arch=wattmeter
Page generated in 0.03798 seconds with 13 queries
