-   ParkFlyers (http://www.Wattflyer.com/forums/forumdisplay.php?f=16)
-   -   Mini cub (http://www.Wattflyer.com/forums/showthread.php?t=74361)
twoslick2 08-25-2014 02:59 PM
Mini cub
I have a mini cub that I would like to bind to my dx6i . Can anybody give me any hints on how to do this and what parts to use? The mini cub is stock right now. Thanks
Brian VT 08-25-2014 03:25 PM
What brand/rx is the Cub ?
twoslick2 08-25-2014 07:57 PM
It's a hobby zone mini super cub
Brian VT 08-25-2014 08:22 PM
Connect battery to plane. Light on rx should start flashing.
Hold trainer switch up while turning on DX6i. DX6i will beep until you let go of trainer switch. Let go of trainer switch.
Should bind in a few seconds.
twoslick2 08-25-2014 09:27 PM
I tried that and it didn't work. It's an older plane and I was wondering if there was another receiver that I could get that would work
Brian VT 08-25-2014 11:07 PM
It probably has an FM rx then. The rx is built onto the "brick" with the esc and servos. You'd prob. have to get a whole DSM2 (Champ?) brick or an FM tx.
twoslick2 08-25-2014 11:18 PM
Are you saying that rx from a Champ would work?
Brian VT 08-26-2014 12:13 AM
You can't buy just the rx. Most ultra micros have the rx, esc, and servos built onto a pc board (then often called a "brick"). The Champ brick could probably be fitted to your fuselage, but they're not cheap.
http://www.parkzone.com/Products/Def...ProdID=PKZ3351
...and your motor's plug might, or might not, be the correct one to plug into the esc (you might have to solder).
Brian VT 08-26-2014 12:18 AM
...I would look for a cheap used TX (that's on the correct FM frequency) or sell your plane to someone that already has one and wants a spare. Then get yourself a DSM2/X plane.
twoslick2 08-26-2014 12:21 AM
Ok Thanks BrianVT
Turner 08-26-2014 04:57 AM
If you are interested in a conversion to standard electronics here is a whole thread about converting the Mini SC.
http://www.rcgroups.com/forums/showthread.php?t=939534
twoslick2 08-26-2014 02:16 PM
Thanks Turner.........I'll give it a look.
pizzano 08-26-2014 06:33 PM
The Hobby Zone Mini Cub (RTF) came with a 27mHz TX/RX......in order to bind with a DX6i you'll need to swap-out the RX to something like a Spektrum AR400 or equal.
Brian VT 08-26-2014 07:24 PM
I figure his plane has this rx/esc ? Would be tough to work a new rx into that ?
http://www.greathobbies.com/producti...rod_id=HBZ4851
twoslick2 08-26-2014 07:24 PM
Pizzano have you done this swap before?
Brian VT 08-26-2014 07:31 PM
Do you have the rx/esc I just linked to or do you have the larger Cub with a stand-alone rx ?
Turner 08-26-2014 07:41 PM
1 Attachment(s)
I've got one in progress but it's on the back burner right now. Have servos and Rx installed. AR6110e Rx (discontinued) and some E-flite RS60 6gm servos.
mclarkson 08-26-2014 10:32 PM
I've got an old HobbyZone Mini Super Cub FM transmitter I'd happily let you have for the cost of shipping.
pizzano 08-26-2014 10:36 PM
No I haven't......A friend owns the Mini Super Cub.
Like Turner has shown.....if you want to use your DX6i, you'll need to mod the entire OS to be compatible with a 2.4ghz DSMX or DSM2 system.
In the case of the Hobby Zone Mini Super Cub, that means installing different, seperate servos, RX, and ESC compatible with the 7.4v battery and stock motor.
Brian VT 08-27-2014 12:14 PM
That seems like his best bet. Just needs to be on the same channel ?
twoslick2 08-28-2014 02:55 PM
After thinking about it I'm going to just sell the mini cub for parts.
Thanks to everybody that helped me
Page generated in 0.03458 seconds with 13 queries
