Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Sport Planes (Formerly I/C & Gas Conversion)
Old 11-23-2012, 04:01 PM   #1
franklin_m
franklin_m's Avatar
Club: State College RC Club
Default TH Kaos Recommendations?
I love the looks of the Tower Hobbies Kaos, but without the landing gear, so I'm thinking of making mine electric (makes for easy hand / bungee launch and belly landings).
So, what's recommendations for power system? I'll probably use HK stuff, so if that helps.
Frank
If at first you don't succeed,
...carrier landings are not for you!
"Fly Navy"
franklin_m is offline
Old 12-04-2012, 09:19 PM   #2
gyrocptr
Strongly suggest landing gear. If nothing else, to protect the prop and motor shaft.
Here's an example:
http://www.youtube.com/watch?v=LWVGXXFS2C4
Another example:
http://www.youtube.com/watch?v=jk5EYCRYoJo
.... AXi 4120/14 brushless outrunner, ICE 75 amp esc, 5-cell LiPo (18.5 volt) 6,000 mah. ...running a 13-10 or 12-10 prop.... weighs in at 8 lbs.
TurnigyTR50-55B 600kv Brushless Outrunner may be similar to AXi Gold 4120/14,... Uses 4-6 cell Li-Poly packs and 11-12 inch props on planes up to 8 lbs flying weight. Manufacturer suggests a 12 x 8 prop on 6 cells or 13 x 10 on 4 cells.
gyrocptr is offline
Need Recommendations - Micro Plane JR2012 Indoor & Micro Electric Planes 8 01-03-2013 10:01 AM
Foam Trainer Recommendations...3S 2200 or 1S 300 / 500 madmaxed Beginners 10 05-24-2012 12:19 PM
3.7V charger and batteries recommendations qwerty Indoor & Micro Electric Planes 2 02-20-2012 07:15 PM
First Kit recommendations?? Nieuport Fly Guy Scratch and Kit Built Aircraft 12 08-19-2011 04:23 PM
Getting back into RC. Electric ARF recommendations? C_Watkins General Electric Discussions 24 07-11-2011 02:46 AM
Page generated in 0.17536 seconds with 23 queries
