Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Power - Batteries, Chargers, ESCs and More > Power Systems
Old 02-08-2013, 01:09 AM   #26
Dr Kiwi
Outstanding Contributor Award
Since DriveCalc was mentioned here is a plot for a Turnigy C3530-1100 (the Aerodrive version is not in there).. it suggests that 10x5 APC E loads the motor appropriately (about 70% efficiency and close to the 3W/g "rule of thumb").
Play with DriveCalc and you'll see how efficiency decreases once you get above 3W/g... you might get away with 11x5.5 or 10x7.. but that is pushing it.
Cheers, Phil
Dr Kiwi is offline
Old 02-08-2013, 01:40 AM   #27
Robio
Cheers, Phil
Fantastic, thank you. I'm still learning the relationship of all these factors and the effects the changes make. It's a bit of a mystery to me but it's starting to make sense.
Rob.......
Robio is offline
Old 02-08-2013, 08:09 PM   #28
Dennis V
Friends: (16)
Rob.......
Yeah
Once you get above about 100 watts per ounce of motor weight, or about 3 watts per gram, you've got to really watch the motor efficiency. Some of those el-cheapo motors are claiming 150 watts or more per ounce of motor weight. These same mfg usually NEVER list the motors winding resistance, a pretty important figure for these motors.
If you run these motors at these high levels, www.motocalc.com usually suggests the motor will burn up. At any rate, their efficiency per motocalc is often under 60 % or so, a lousy number, when a quality motor is in the high 80% or even low 90% range.
DennyV
Old 02-12-2013, 05:29 AM   #29
Robio
Yeah
This plane is a cheap foam/Depron slow flyer. I'm running it at just above half throttle for most of the flight. Takes only a bit more to get if off the ground!...
I'm curious though. I have a couple of higher performance planes to build. What do you like for motors?
Rob.....
Robio is offline
Old 02-12-2013, 04:40 PM   #30
flydiver
flydiver's Avatar
View flydiver's Gallery1
Friends: (10)
Rob.....
Too general. You're better off finding the thread about the particular plane(s) and asking there.
fly
If you're going to learn to fly them, you have to learn to fix them.
flydiver is offline
Old 02-12-2013, 07:55 PM   #31
Dennis V
Friends: (16)
Rob.....
IMHO, on these smaller "Foamies" just about any quality motor will do the job. But, I don't like to skimp on the motor when going to models over perhaps 1KW or so. As for me, all of my 1 KW plus motors have the Hacker name on them, and all of them perform very close to their specifications.
DennyV
Old 02-13-2013, 01:19 AM   #32
Robio
Thank you Sir,
I've heard nothing but good regarding Hacker motors.. I have an Axi motor I may use, but have'nt deceided on the build for this particular model yet. If I build it "light", I will use it.
Nothing I have requires 1kw of output, yet.. Somewhere in the neighborhood of 600w.
Thanks again, Rob....
Robio is offline
Old 02-13-2013, 03:27 AM   #33
Dennis V
Friends: (16)
Thank you Sir,
Yup
IMHO, about 1/3 of your models $$$$ should be for the model itself, about 1/3 for the power system, 1/3 for the radio.
So, it makes little sense to put one of those "Orange" receivers into a model worth well north of $500. Or, put a $200 receiver into a little foamie.
DennyV
Welcome New Members to Wattflyer - We ONLY do electric flight here! admin General Electric Discussions 4730 05-21-2013 04:13 PM
Helping People Learn to Fly AEAJR General Electric Discussions 166 04-08-2013 05:54 PM
100+ MPH Club CHELLIE Hi-Performance and Sailplanes 1932 04-08-2013 02:16 AM
New Guy, Asking for help! propduster8 General Electric Discussions 21 12-13-2012 01:42 PM
my mini ultra stick escapades hayofstacks Crash and Safety Forum 0 03-05-2012 12:07 AM
Page generated in 0.29037 seconds with 38 queries
