Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric General > Power Systems
Old 11-02-2009, 06:13 PM   #1
sam94
sam94's Avatar
Club: Websterflyers
Default servos- torque roll?
I have a new plane, and when i first attempted to fly it, it was very twitchy in the air, after inspection it shows that the servos was very twitchy causing the plane to swing side to side in flight.
The servos were probably roughly 10-11gm servos, so i replaced them with my 7.5gm servos, and on my next flight with the new servos it crashed
The crash was like this - i launched it into the air and it went forward a little then suddenly rolled and nosed into the ground.
Could this be because of the new servos i put in.
Please help
sam94 is offline
Old 11-02-2009, 08:10 PM   #2
Matt Kirsch
Matt Kirsch's Avatar
What do you mean by "twitchy?"
Were the servos moving on their own, jerking around?
That's a definite "no fly" condition. Don't fly until you figure out what's wrong.
As far as your crash... Did the 7.5gm servos twitch too?
If they did NOT twitch, odds are that the plane didn't have enough airspeed on the last launch, and tip stalled into the ground.
If they were still twitching, then the servos probably went hard-over due to whatever interference was causing the twitching.
Matt Kirsch is offline
Old 11-02-2009, 08:37 PM   #3
sam94
sam94's Avatar
Club: Websterflyers
well...when i mean twitchy i mean they move by them selfs and randomly twitch
But i decided to fly-BIG mistake
After a crash with the twitchy servos in, i decided to replce the large servos with small er servos (7.5gm), they are not twitchy at all and seem great.
Maybe your right-maybe the plane stalled, but i gave it a good hand launch.
Maybe its to nose heavy
i dont know??...
sam94 is offline
Old 11-02-2009, 09:46 PM   #4
eflight-ray
eflight-ray's Avatar
You should always do a range check with a new model, or when you change any of the electronics.
The CG should be checked, (and checked again), before a first flight.
Also check servos and control linkage to ensure there is no play/slop in the control surfaces. The control surfaces should always return to the same neutral position.
Once you have confidence that the model works correct, then you consider how your going to launch and fly it. And that's a whole new bag of worms.
Ray in Wales
As I get older I think more and more about the hereafter.
I walk into a room, and think, 'now what was it that I'm here after?'
eflight-ray is offline
Old 11-02-2009, 09:59 PM   #5
'Twitching servo' is very rarely caused by the servo itself, it's more often due to poor radio reception and/or interference.What radio gear are you using, and as suggested previously did you do a range check (with and without motor running)?
If first time it flew 'ok' apart from the twitching servos then providing all you did was change the servos it's unlikely to be a CG problem..
I assume you did check that after changing the servos the control surfaces still moved in the right direction?
Old 11-03-2009, 10:18 PM   #6
sam94
sam94's Avatar
Club: Websterflyers
Im using spektrum 2.4ghz tx and rx
Sadly i didnt do a range check
and once i had changed the servos the control surfaces were all moving correctly.
sam94 is offline
Old 11-05-2009, 02:40 AM   #7
Cyclops
Thumbs down Fix 1 problem & caused a worse one.
I had a definately buzzing servo. buzzed with nothing connected. Put in a same type. Fine. Hooked up linkage, works. CRASH !!
I forgot to put the rod into the right hole!! 2 really super barrell rolls into the ground.
Cyclops is offline
4 - DS821 Digital Sport Hi-Torque Servos - $75 coldsteel45 Radio Equipment For Sale & WTB 3 10-01-2008 06:03 AM
Roll out your SCs CaptainCub ParkFlyers 40 11-18-2007 05:16 PM
Parkzone FW-190: Torque roll on launch bigmark Beginners 0 04-07-2007 01:48 PM
Stryker Torque Roll or something else? Moonwalker Delta & Flying Wings 21 10-27-2006 02:39 AM
Roll Technique?? WThesing Beginners 12 08-18-2005 03:25 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.24455 seconds with 32 queries
