Old 01-05-2017, 07:38 PM   #1
garyp1029
Default Retracts on Elevator Switch on DX6i
Is it possible to use the elevator switch on DX6i to activate the landing gear?
garyp1029 is offline
Old 01-05-2017, 09:23 PM   #2
View Panther's Gallery5
Elevator switch? There is no such thing.
Elevator is on the stick.
Can you elaborate?
Old 01-05-2017, 10:36 PM   #3
garyp1029
Default lebel
On the FRONT (top left) of the DX6i there are two switches (each has two positions)---the one on the right is "FLAPS", the other on its immediate left is "ELEV D/R" (elevator dual rate). My question---Since the "ELEV D/R" is a two position switch AND since I don't use it, is it even POSSIBLE to somehow use it in place of the "GEAR" switch???
Old 01-05-2017, 10:46 PM   #4
I have a DX6 G3 and am not familiar with the DX6i.
However I think that switch would be coupled to the elevator to reduce throws. I am not sure it is a stand-alone switch unless the switch can be assigned to Ch 6.
It is a 6Ch Tx so you should have 6 free channels. ( 2 on switches)
Someone with a DX6i may have the answer.
Old 01-05-2017, 11:11 PM   #5
garyp1029
I think you are correct. It would have to be assigned to channel 6. That's probably not possible on the DX6i, but thought I would ask anyway. Thanks.
Old 01-06-2017, 12:50 AM   #6
No problems. Hope you can get something sorted.
Old 01-06-2017, 01:26 AM   #7
I believe Panther is correct........Channel 6 is an Aux and can be used for combo assignments related to heli's and LED's or function as a control assignment on 6ch quad receivers.........however, I don't believe the gear switch can be swapped to the elevator dual rate switch since there is no way to reassign ether of those switches to Aux channel 6 without reprograming the Aux to accept either of those functions...........I've never tried to switch them, but there are old threads at RCG and Helifreak that discuss the reasons it cannot be accomplished.
Old 01-06-2017, 08:37 AM   #8
squidger
squidger's Avatar
Think its channel 5 on spectrum for gear. You can assign any switch to any channel on the new spectrum radios but not on the dx6i.
squidger is offline
Old 01-06-2017, 12:18 PM   #9
Correct. 5 is gear. However you can reassign it.
For DLG I assign some elevator, rudder, aileron and timer start all to the I button (Bind button) for launch mode. It really is a versatile TX.
Old 01-07-2017, 02:18 PM   #10
flypaper 2
flypaper 2's Avatar
Why not use the flaps switch. Even if you are using flaps, you would want them to work in co-ordination with the flaps/
Gord.
flypaper 2 is offline
Old 01-09-2017, 08:01 PM   #11
Vic Z
Club: Mt Rainier RC Club
I don't believe that you can reassign switches on the 6i.
My biggest fear is that when I die my wife will sell my planes for what I told her I paid for them
Vic Z is offline
Add retracts to my Mig 3 solentlife Scratch and Kit Built Aircraft 9 05-04-2016 08:13 PM
On the hunt for metal trunnion 90 deg retracts and oleos dahawk General Electric Discussions 20 12-17-2013 08:39 PM
3 Stage Flaps on a DX6i and a AR600? Hose Man RC Radios, Transmitters, Receivers, Servos, gyros 0 08-29-2011 06:35 PM
Re: A dx6i mixing question please! Swanj Power Systems 1 08-26-2011 05:19 PM
How to hookup servos and retracts to a Parkzone P-47? mikail511 Warbird Electrics 3 08-14-2011 02:36 AM
Page generated in 0.11877 seconds with 40 queries
