Old 01-15-2017, 11:28 PM   #1
squidger
squidger's Avatar
Default Servos not centering
I am currently putting together a Hangar 9 Meridian which I have decided to build as electric. Everything has so far gone well until I get round to the servos. I decided to go for standard size metal gear servos. The first lot I bought were tower pro and none of them centred properly so I bought some others which did exactly the same. It's definitely the servos and not stiff linkages as I have tried them just plugged into the receiver and they have a different centre each time you move them. I have used these servos in lots of models before and not had this issue. What use is a servo that centres in a different position each time you use the controls. Have just ordered some futaba s3003 servos but with ball race conversion. Hopefully these will be better.
squidger is offline
Old 01-15-2017, 11:47 PM   #2
giflyrc
Gravity is Attractive
Club: ALLIANCE BALSA BEES
Default servo centering
My first thought is if you have the same problem with two different sets of servos I would look somwhere else for the culprit such the servo tester if you are using one or your transmitter stick pots may be worn.( I don't think that would affect every channel though) perhaps a weak transmitter battery.
Check your system with another transmitter to isolate the problem.
Keep us posted----Roger aka GIFLYRC
Independently Poor
giflyrc is offline
Old 01-15-2017, 11:55 PM   #3
squidger
squidger's Avatar
Thanks for the reply Roger. I use my DX9 transmitter currently for 35 fixed wing and 6 helis so I know its not the tx. I have tried another receiver to rule that out. It is definitely the servos. I can plug a known good servo into the receiver and it works and centres fine. I must have just been unlucky and received two bad batches of servos from different suppliers. You would think they would have failed quality control on this issue though.
squidger is offline
Old 01-16-2017, 12:02 AM   #4
1kW
Friends: (7)
What is your BEC voltage? How long are your extensions? Are they heavy enough?
I don't have a short temper. I just have a quick reaction to B.S.
Rob
birdDog is online now
Old 01-16-2017, 12:14 AM   #5
squidger
squidger's Avatar
BEC is good Rob. Everything is good except the servos.They even have centering issues on my servo tester. Have tried all different setups including plugging these servos into a different model. The troubleshooting confirms it is the servos that are faulty.
squidger is offline
Old 01-16-2017, 09:41 PM   #6
View Panther's Gallery5
I would be interested to know if they are Coronas. But you said you had 2 different brands.(one Tower Pro I guess)
Can you please name them since they are obviously faulty?
Old 01-17-2017, 02:36 AM   #7
squidger
squidger's Avatar
The first batch were tower pro MG996R. The second batch were tower pro MG945 and the futaba servos I've just ordered are S3004.
squidger is offline
Old 01-17-2017, 02:54 AM   #8
The Futabas have nylon gears as opposed to metal but the centreing should not be a problem.
Old 01-17-2017, 01:42 PM   #9
squidger
squidger's Avatar
So long as the centering is good the plan is to see if I can fit the metal gears from the tower pro servos to the futaba. If I cant I will buy a metal gear conversion set later.
squidger is offline
Old 01-17-2017, 06:26 PM   #10
Past President of PSSF
Friends: (8)
I have some MG 995 servos and also found the centering to be poor. I would not fly them in an aerobatic plane but in a big gentle trainer they should be okay.
I have a half circle plastic protractor with about a 1/2" dia notch at the center point. I put a long pointer on the servo, lay the protractor on the table and hold the servo against the edge, rotate the protractor to read 90* using a known good standard. I have a servo driver with digital readout down to 1 micro second.
Using this setup has shown me that different servo brands and type can have HUGE differences. Some turn 30* each way going from 1000-1500-2000 micro seconds (my standards) some turn 45* I have a couple that turn 55*.
Most new servos travel the same amount both directions, I have a few that go maybe 10* more in one direction, like a built in differential.
Most new servos center well, less than 1/2* diff. every time.
A few servos will stop before reaching the center, and some will overtravel and stop on the other side of center.
I must have well over 150 servos, so I had to come up with a way to test and understand them. I like to have matched servos in a plane, especially when using 2 servos on ailerons or flaps or split elevators. 2 servos on 1 surface and you must have matched servos.
Centering issues were very common back in the 70's, many cutting edge aerobatic planes could only use the best servos available. Those may have cost $100.00 each, I was only making $3-$5 per hour through most of the 70's, that made them out of reach. Also the control pots would build up little piles of carbon dust from the wiper scraping at the resistive surface. Giezendanner carbon button pot wipers cured the most of that problem.
The famous Hobie Hawk glider, was put down as wandering through the air, it was the fault of the servos and the rest of the control chain of 1974 when it came out.
I have two of them, they fly fantastic with modern tight centering equipment. They are simply very sensitive to small control inputs.
Our equipment today is so good, that we are startled when it doesn't work right. Man it's great to have these modern radios
Dave R, Proud PGR rider.
http://www.pugetsoundsilentflyers.org/
Wildflyer is offline
Old 01-17-2017, 10:46 PM   #11
FoxProGT
Iv seen some vids and post about Tower Pro servos not being very good. This post just adds to their stigma. They're some of the cheapest servos on the market. I personally wouldn't run them in my planes or expect to much from them.
FoxProGT is offline
Old 01-17-2017, 10:56 PM   #12
squidger
squidger's Avatar
To be honest I have tower pro servos in alot of my models and havn't have issues but this last couple of batches have been bad. I'll put it down to experience.
squidger is offline
Old 01-18-2017, 12:58 AM   #13
I mainly use smaller servos but I am fussy with centreing too.
The EMax are my favourites in 9-12 gram and are tough as nails.
Next size up I use some of these
There was also a purple transparent variant slightly cheaper but Hobby King seems to not stock them any more.
I will be sticking mainly with Emax anyway.
Porcupine have always had the best prices.
Old 01-19-2017, 05:31 PM   #14
squidger
squidger's Avatar
Fitted the Futaba s3004 servos today and they perform perfectly. I have left the flaps with the towerpro servos as they don't need to centre.
squidger is offline
Old 01-20-2017, 02:11 PM   #15
squidger
squidger's Avatar
Heres a vid showing the centering issue.
https://www.youtube.com/watch?v=7SRwCB5Orzg
squidger is offline
Old 01-20-2017, 02:57 PM   #16
squidger
squidger's Avatar
Here she is ready for the maiden. Finally. Shame its only 3 degrees c outside. Don't fancy freezing so will wait till warmer weather.
https://www.youtube.com/watch?v=na4JWqqac_w
squidger is offline
Old 01-20-2017, 09:01 PM   #17
That centreing issue is nearly as bad as my 1st World Engines Blue Max RC gear I bought back in the early 70s.
Old 01-21-2017, 01:28 AM   #18
squidger
squidger's Avatar
That wasn't the worse one either. Of the 12 servos I now own with dodgy centering the worse one is about double that. I'm going to strip one down and see if I can find the cause.
squidger is offline
Old 01-21-2017, 05:51 AM   #19
Friends: (8)
I definitely would not put that in plane doing anything more important that pulling the release on a bomb drop.
Like Panther says that looks like a servo from the 70's in fact most of those were better.
I had servos that put a glider into a dive or a series of stalls, depending on which side the servo tried to center from, they acted just like yours.
A high speed servo would probably over shoot and stop on the other side.
The problem is most likely in the feedback pot, it could be dirty or if it is an indirect drive type there could be slop in the gears or something like that.
Old 01-21-2017, 10:02 AM   #20
squidger
squidger's Avatar
Absolutely. I wouldn't dream of using servos like that. If I can find the cause it will give me 12 useable servos for later but I need to rectify the issue first.
squidger is offline
Old 01-21-2017, 11:24 AM   #21
Just looks like a 'crap servo' issue to me.. Only fix would be chuck them in the bin and get different servos, unless the seller will change them under warranty (they should)
Slop in the drive to the feedback pot is a definite possibility but what if anything you can do about it is a different question. Hard to imagine that's it's just a dirty pot given that you have several servos with the same issue.
Old 01-21-2017, 02:07 PM   #22
squidger
squidger's Avatar
I'll know once I strip one down. If I cant fix them I will keep the metal gears for spares.
squidger is offline
Chinese Servos - The good the bad and the UGLY GunnyJeeves General Electric Discussions 31 10-22-2015 01:01 AM
Let's talk about servos - Whatever is on your mind AEAJR Beginners 285 08-27-2015 12:05 AM
Serious flutter of servos ! solentlife RC Radios, Transmitters, Receivers, Servos, gyros 32 09-29-2014 02:26 PM
Hitec BRUSHLESS servos now in stock! ServoCity New Product Announcements 0 07-09-2014 04:26 PM
3S or 4S Battery Question(s) RCFlyer44 Power Systems 22 03-29-2011 05:55 AM
Page generated in 0.51390 seconds with 62 queries
