Old 01-30-2017, 11:27 PM   #1
Vic Z
Club: Mt Rainier RC Club
Question Thrust angle problem?
Hey guys. Has been a while.
Hope everyone has been well.
Not much has been going on in the great northwest except for crappy weather. From the tempo of posts on here I am assuming that I'm not the Lone Ranger in that arena. Have been lurking and it has looked pretty boring on here.
Had the Sukhoi out a couple of weeks ago and between having to play with both mode and rate settings I plowed it into the ground pretty dang hard. Purely my fault. Just not smart enough to play with 2 switches at the same time. I immediately threw the AS3XA RX away and put a straight no frills 4 channel in it. I Put the 3 fuse pieces back together and it looks pretty straight, and had to replace the bent prop adapter. It trims out fine and flies great, but when I go vertical and add throttle it wants to veer way off to the right. Even when I add left rudder (vert) it kind of tries to straighten out but heads starboard as soon as the rudder is released.
I am thinking maybe too much thrust angle to the right.
Any suggestions?
Thanks,
Vic
My biggest fear is that when I die my wife will sell my planes for what I told her I paid for them
Vic Z is offline
Old 01-30-2017, 11:53 PM   #2
Yeah, sounds like either too much right thrust or the fuselage/tail is bent thus giving right rudder effect.
Sighting down the fuselage should spot and misalignment, right thrust is topically 3 degrees give or take half a degree or so.
Old 01-31-2017, 10:27 AM   #3
Friends: (19)
OK this is where pilots start to get experimental ...
We all go through the correct with rudder trim for vertical - but then find that other attitudes start to suffer. So we correct the vertical. Land and see where rudder is.
A rough rule of thumb I use is that 1 deg of right thrust on a motor is equal to 4 - 5 degrees on rudder. If the rudder is deflected visibly to one side ... in this case likely to left when looking at tail from behind ... then slack back motor mount and stick washer under the mount top and bottom starboard side (left side looking at spinner from ahead). That will reduce the right thrust a touch.
Go fly and now rudder trim should be reduced ....
Keep going till you have a good balance. Its common to have a degree of offset to rudder ..
BUT of course you are flying with recc'd optimum prop / motor / setup ? The amount of power / thrust of your setup makes a huge difference to a model ... if you increase power to waht its designed for - then often you need to reduce thrust offsets to compensate UNLESS you fly at reduced throttle all the time !!
All these things are always a compromise ...
Old 01-31-2017, 03:46 PM   #4
Vic Z
Aside from the rx all is completely oem. Exactly as it was before the crash.
With rudder trimmed straight it flies true in normal flight. It only veers when vertical and under full power. That's what makes me think thrust.
Looking down the fuse all seems to be straight (with my old eyes).
Vic Z is offline
Old 01-31-2017, 05:06 PM   #5
Friends: (19)
My Zlin and Extra fly straight as arrows but when they go vertical - I needed bootfuls of left rudder !! I could trim that rudder for verticals and unless knife edge - level was literally no different
So I altered thrust lines and now both are good ... straight and vertical.
Old 01-31-2017, 08:07 PM   #6
Vic Z
Thank you Nigel. That's what I was hoping to hear. I am really good with glue and inserting washers, but that is about the top of my skill level. I have seen some of the hamburger that you have resurrected and I had a feeling that you might have the answer.
You and JPF usually chime in with good help. Always appreciated
Weather permitting I will be at the field tomorrow. Report to come.
Vic
Vic Z is offline
Old 02-01-2017, 02:53 PM   #7
flypaper 2
flypaper 2's Avatar
At any rate I would stick a couple of washers under the right side of the motor mount just to see the difference in flight. The washers I use are about .030 thou. thick , or 1/32 in.
Look down from the top of the fuse, you should just barely see the right thrust in the motor.
Gord.
Gord.
flypaper 2 is offline
Old 02-01-2017, 03:52 PM   #8
Friends: (19)
My thrust adjusters run from paper ... card .... thin washers ... thicker washers ... prop shaft rings from props (we all have loads of those !!) to ply plates ...
Instead of using multiple washers - try a prop shaft ring ... lighter, only one item to put in place !!
Welcome New Members to Wattflyer - We ONLY do electric flight here! admin General Electric Discussions 5313 Yesterday 11:25 PM
Quick question on motor thrust angle hankg General Electric Discussions 19 07-17-2012 07:13 AM
Thrust angle question icarus46 General Electric Discussions 5 06-15-2011 11:38 PM
Thrust angle adjustments Davethebluessinger Delta & Flying Wings 17 06-09-2011 07:43 AM
Prop Selection Hose Man Beginners 7 03-23-2011 02:57 PM
Page generated in 0.10117 seconds with 34 queries
