Old 02-07-2017, 07:33 PM   #26
dereckbc
Originally Posted by Xpress.. View Post
The way the circuit interprets the signal out of the box is 900-2100μs will give you a 120 degree rotation total. With the programmer, you can change that so that the servo will rotate 180 degrees with a 900-2100μs signal. Your HPP-21 will let you do that, you just have to set the center and EPA's. But generally you don't use 180 degree rotation with airplanes, 120 degrees is plenty enough.
We don't have any documentation on it that I'd be able to post, the HPP-21 should have a general guide that came with it.
Thanks I got most of it figured out last night playing with it. If you couple enlighten me on the End Points. Example if I go into Program , set the center as it comes out of the box, and then grab the Handle and drag it Right or Left it spits out a number from 0 to 215, and 0 - -215. I stretched it out to 215 and -215 and got the 180 degree rotation. Is there any kind of Scale?
I think I got close by doing simple ratios that 90 degrees = 215, thus 45 degrees os 107/108. Put another way if I wanted to keep 120 degree Rotation to set the handles to 143 and - 143.
Am I on the right track? Seems to be close.
dereckbc is offline
Old 02-08-2017, 04:24 PM   #27
Xpress..
Team Hitec, CSR
Xpress..'s Avatar
Club: Alpine Aero Squadron
3kW
The numbers on the programmer don't actually mean anything or correspond to any particular degree of motion, they are just for reference on the programmer to tell you how far out from 0 you are. Move the servos center and end points to where you want them and set them, the servo will move to those positions when given the right signals from your transmitter.
Team Hitec, Customer Service Representative
Team Aerobeez Pilot
Xpress.. is offline
The Extreme Flight Edge 540T-EXP ARF-48 x-nitro 3D Flying 16 02-25-2016 02:58 PM
Servo Control Arm Orientation. Hitec dereckbc General Electric Discussions 12 10-27-2015 12:31 AM
Servo arm question.... time bandit ParkFlyers 17 07-12-2014 11:56 AM
Servo Arm - HiTec 65MG mustang71 RC Radios, Transmitters, Receivers, Servos, gyros 6 02-21-2012 07:08 AM
servo zero, angle of the dangle, and flight surface equal travel DanWard Beginners 4 02-10-2011 04:57 AM
Page generated in 0.05319 seconds with 22 queries
