Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Foamies
Old 03-03-2013, 05:02 AM   #1
Toonamelt
Default Prop options for a park 450
I'm converting my Hobbyzone Super Cub and putting in a Turnegy Park 450. The recommended prop sizes for this motor are 9 x 5 and 8x 4.3. Just wondering, can I try any other sizes with out causing serious damage to the motor? Like, if I wanted to get more torque, could I use a larger prop with a lesser angle... like a 10 x 4.7? Or if I wanted more speed could I use a 8 x 6? I'm not clear if you can mathematically stray from the recommended props for EP motors at all.
Toonamelt is offline
Old 03-03-2013, 05:23 AM   #2
flydiver
flydiver's Avatar
View flydiver's Gallery1
Outstanding Contributor Award
Friends: (10)
You certainly can try other options. Once you leave the security of RTF systems though it's very wise to get a wattmeter, learn how to use it, then you get proper answers to your questions.
Too small a prop > lacks power (may be more efficient though)
Too large > maybe burn something up.
Over propping is very common. Folks think they are getting more for nothing. Pretty much they are producing heat, running their batteries down faster, and feeling good about it.
So, there's a range that will work well. You need to stay inside that range and from there pick a prop that you feel works best for the plane and you.
fly
If you're going to learn to fly them, you have to learn to fix them.
flydiver is offline
Old 03-03-2013, 02:41 PM   #3
max2112
WG1 pilot #2.
max2112's Avatar
View max2112's Gallery59
Globetrotter Pilot
Friends: (12)
Hi toonamelt, WELCOME to WattFlyer! It's always good to see new faces.
+1 to what flydiver posted.
A Wattmeter is a device that plugs into your setup in between the battery pack and the ESC. It then measures the Watts being generated, Amperage being pulled and some can measure mAh used.
I use mine every time I set up a plane. Even my BNF planes get measured so I know the base numbers.
Please call me John. I came up w/ Max2112 when I thought you were all internet predators after me Lucky Charms!!
max2112 is offline
Old 03-03-2013, 02:50 PM   #4
Toonamelt
Thanks flydiver and max2112. I recently got a watts up meter, and am just starting to get familiar with it. it's fun in a geeky kind of way.
So as long as the prop doesn't cause the motor (one ESC) draw more amps or watts than specked, than I should be fine? Sounds like I will just need to tests a few props then. Is there a formula for determining the efficiency?
Old 03-03-2013, 05:18 PM   #5
flydiver
flydiver's Avatar
Friends: (10)
To determine efficiency you need a few more tools (tachometer, IR thermometer, maybe even a thrust stand). Some folks go there but for most simply staying within the max spec range is suitable.
Generally you'd like to prop so max RPM is ~70% of max unloaded RPM. The motor should only get warm, not hot.
As there is poor cooling on the bench limit motor runs to less than 30 seconds. If a motor gets hot in that time > it's over propped most likely.
Beware of GWS SF props under much power. They are pretty floppy, distort readily (you can hear it) and if pushed can break. All props have a max RPM with the SF (skinny hub, fat blade) being lower than the thin electric (fat hub, skinny blade). APC publicizes that info, GWS does not.
fly
flydiver is offline
Old 03-04-2013, 01:53 PM   #6
Toonamelt
Thanks again flydiver! You've been very helpfull!
Tags
park 450 , prop selection , super cub lp
Welcome New Members to Wattflyer - We ONLY do electric flight here! admin General Electric Discussions 4727 Today 11:55 AM
100+ MPH Club CHELLIE Hi-Performance and Sailplanes 1932 04-08-2013 02:16 AM
Dunam HAwk sky glider with grayson v2 pusher upgrade Prop problems Alabama Flying Dude Pusher Park Jets 3 05-19-2012 04:13 PM
3mm prop adapter impossible? Prop saver issue? mclarkson General Electric Discussions 12 11-26-2011 10:09 PM
Sold E-Flite Park 450 and CC Phoenix 25 - $50 shipped Grasshopper Motors and Speed Controllers for sale & WTB 1 08-21-2011 04:17 AM
Page generated in 0.23170 seconds with 31 queries
