Old 01-08-2013, 02:53 AM   #1
p3arljam
Default Motor burned up need help
Well my second flight was going good until my E Flite Apprentice wing clipped a branch and nose dived. I was shocked how little damage was done looked like just the cowl and motor mount until.... i tried the motor wheni got home and its fried. My question is if you look at the photo how do i remove the motor from the esc the wires go thru the front of the fuselage and the esc has a white plastic piece holding it in place. Also how do i remove the wires connecting the esc to the motor?
p3arljam is offline
Old 01-08-2013, 02:57 AM   #2
BBCorvette18
I Would try to pull the esc towards the front until the connectors are visable.
BBCorvette18 is offline
Old 01-08-2013, 03:44 AM   #3
CrimzonRider
Fastest PropHead Crasher
CrimzonRider's Avatar
View CrimzonRider's Gallery18
Friends: (14)
'jam...Yeah, they might be a little tight being new and all, but there is little bullet connectors in between esc and motor just pull towards front, the glue on the little esc "mounting" bracket was easy to break loose and slide forward....
Looking real close....is the blue wire stripped out of the motor?? or what is that shiny spot/tape?? on blue wire right at motor??? might just be me or reflection just looks odd.
cr
BTW the ol' app goes really good with a 15 size motor, if that one is toast. I put a Cermark Neo-dym 15 in mine couple yrs ago, but yeah headsuprc is real good everything.
CrimzonRider is offline
Old 01-08-2013, 03:49 AM   #4
hayofstacks
Looks the same to me.
I haven't had much luck fixing pulled out windings. No matter what I tried, I couldn't get solder to stick.
Headsuprc has quite a few motors that should be a quick and easy replacement. I've gotten things from florida to utah in 3 days.
hayofstacks is offline
Old 01-08-2013, 11:18 AM   #5
p3arljam
The blue wire had a piece of the shrink tube come off the wire looks good but the motor is shot for sure.
p3arljam is offline
Old 01-08-2013, 02:20 PM   #6
paxskipper
New Electric Flyer
paxskipper's Avatar
Club: Cumberland County RC Club
After your crash did you reduce the throttle? If not you may have burned it up because it was still energized.
I also crashed my apprentice and had to place the motor, I believe that I bent the shaft. I replaced it with an E-Flight 15 and it flew a little better. Also check the offset, I had actually mushed the nose a little and had to readjust the down / right offset.
Enjoy
Steve P.
Now flying a Pulse XT25
paxskipper is offline
Old 01-08-2013, 03:02 PM   #7
CrimzonRider
Friends: (14)
Enjoy
Yeah, IMO the App is pretty sensitive to very minor changes in offset and CoG. and the eflite 15 might be a better choice.
http://www.wattflyer.com/forums/showthread.php?t=59609
cr
Old 01-08-2013, 03:27 PM   #8
CrimzonRider
Friends: (14)
Jam, this might help a bit...
http://www.horizonrcflyers.com/forum...ead.php?t=1716
have a good one
cr
Old 01-08-2013, 05:05 PM   #9
CrimzonRider
Friends: (14)
Probably most important when swapping motors, you are going to need a wattmeter.
post #7 is about wattmeters and why, but entire thread is very important info.
http://www.wattflyer.com/forums/showthread.php?t=31368
cr
http://www.wattflyer.com/forums/show...ight=wattmeter
Page generated in 0.31016 seconds with 39 queries
