Old 01-02-2013, 05:48 AM   #1
MaxSpeed
Default is it possible to combine 2ch into 1?
i have an FS TH9X and was wondering if i could combine two channels into one (ailerons and rudder)? i guess what i am trying to get at is, operating both the ailerons and rudder by using the aileron switch? has anyone done this before?
thank you
MaxSpeed is offline
Old 01-02-2013, 07:08 AM   #2
View CHELLIE's Gallery13
Ambassador Award  100mph Speed Demon  Outstanding Contributor Award.
Friends: (281)
thank you
Maybe this link might be of some help, the Turnigy9x is the same transmitter. You can also use a seperate mixer to do the same thing if its not possible to do it with the transmitter
http://www.rcgroups.com/forums/showthread.php?t=1333412
Old 01-02-2013, 07:16 AM   #3
Friends: (281)
http://www.rcgroups.com/forums/showthread.php?t=1266162
Originally Posted by crucial
I figured I might as well start the thread since there was interest in it by a few.
Custom Firmware by Thus
Homepage for the custom firmware : http://code.google.com/p/th9x/
Direct link to manual : http://th9x.googlecode.com/svn/trunk/doc/th9x-en.pdf
btw: you should add the FlySky FS-TH9X in your headline - from web site to show that its the same transmitter as the turnigy 9x
Old 01-02-2013, 07:37 AM   #4
MaxSpeed
thats great guys!! i was able to program it. now my last question is, is it possible to use an on/off (AUX) button to switch between the 2 mode? basically, i want to have control over all the channels, but once i flip the switch i get the mix in (combining 2 channels in 1)?
MaxSpeed is offline
Old 01-02-2013, 07:51 AM   #5
Friends: (281)
Glad you were able to program it I am not sure about the Aux button as a switch, there are a lot of Gurus here that should be able to answer your question, Take care and have fun, Chellie
Old 01-02-2013, 10:24 AM   #6
Scratchbuilders Award  Outstanding Contributor Award  125mph Speed Demon
Also join the FlySky group I started ... which caters more for the un-modified 9x and others of the FlySky range.
http://groups.yahoo.com/group/Flysky_RC_radio/
Yes it is possible to switch the mixing on / off ... using usually the 3 position switch top right centre.
The 9x is far more capable of things than many realise - but it does have it's own quirky style of language ...
We also have the manuals links in GOOD english without watermarks etc.
- Subscribe to my Youtube: "solentlifeuk"
Old 01-02-2013, 05:31 PM   #7
MaxSpeed
Nigel[/QUOTE]
is it possible to do it on a different switch? because i would like to program the 3 position switch for flaps.
- i will be joining the fly sky group. thanks
MaxSpeed is offline
Old 01-02-2013, 06:17 PM   #8
To be perfectly honest - I don't know ! Ask on the group - someone with far greater knowledge than I will answer.
Personally I use the top left centre knob to control flaps - full turned left is zero ... full turned right is 30 degrees down flap. It gives me proportional control of flaps instead of sudden steps as with the 3 position. By rolling my middle finger across the knob - I am able to go from full left to full right ... so I know what amount I use by position of my finger.
The other with the 3 position switch - it needs to be tricked to not default to OFF - ON - OFF ... why they did that I have no idea !
Old 01-02-2013, 07:27 PM   #9
MaxSpeed
Thank you for your reply solentlife. i was wondering though, how did you program you flaps to function with the left knob?
MaxSpeed is offline
Old 01-02-2013, 08:58 PM   #10
The set-up is also on the group ... it's in the files section if I remember right ... this is Flaperons...
To have just flaps - then I would Y lead 2 servos of the Aux ch and set the knob to operate the servos. No need to go into Flaperon settings. (I'd have to check up on this later - as it's late at night here ... I'm in a different part of the house from the radio and it's time for me to sleep !! But I will get back on this ! ..)
Old 01-03-2013, 03:57 AM   #11
Beemerider
Beemerider's Avatar
Club: Augusta County RC Club
Uh.........Chellie is a gal.............and a pretty darn sharp one too
Beemerider is offline
Old 01-03-2013, 04:17 AM   #12
Friends: (281)
Thank You for the complement
Old 01-05-2013, 08:11 PM   #13
Friends: (8)
These videos may be helpful:
VIDEOS – STANDARD HARDWARE AND SOFTWARE OVERVIEW
FlySky TH9X – How to use - I think this is the basic SW
This looks pretty easy to use. Should meet most people’s needs
Basic introduction of buttons and menus
http://www.youtube.com/watch?v=5xOATDBmbbc
Turnigy 9X – Review of switches, buttons, etc – based on standard SW
Same as the FlySky Software
http://www.youtube.com/watch?v=V0-b2Umo7YE&feature=related
Binding additional receivers
http://www.youtube.com/watch?v=z_-ruNd1FcU&feature=related
Setting up Channels 5-8 AUX channels
http://www.youtube.com/watch?v=YHMDW0TDIZc
How Set Up TH9x for Plane with Dual Ailerons and V-Tail
http://www.youtube.com/watch?v=893rdC0i-TU&feature=fvst
Setting up Flaps
http://www.youtube.com/watch?v=L3Mw6jDlUzI&feature=g-vrec
FlySky TH9X – Elevon Mixing
http://www.youtube.com/watch?v=FgLPAIPMptA
Setting up SnapFlaps
http://www.youtube.com/watch?v=UVSiTuHJym8&feature=related
Going back to default settings
http://www.youtube.com/watch?v=zhadIdLOrw8&feature=related
Setting up a Buddy Box
http://www.youtube.com/watch?v=ZWHTAiluPUI
CCPM Heli set-up for FlySky TH9X
http://www.youtube.com/watch?v=LErVMysykhY&feature=related
www.lisf.org
Eastern Soaring League
www.flyesl.org
Suggest how to convert 2ch rubbish ! solentlife General Electric Discussions 18 09-25-2011 03:56 PM
Page generated in 0.40792 seconds with 46 queries
