Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Foamies
Old 09-25-2012, 11:08 AM   #376
romanxdsouza
chelie but 0 to 3 would be upwards i thaught 3deg down so as per ur ex[planation whr would the fuse b,i got the degree part ,on the fuse how would down b..... question depron 5mm should i use for wing.ribs, elev,rudder right so full plane built with 5mm depron .......am i correct.chellie sorry need to clear my doubts 5mm full plane all parts
romanxdsouza is offline
Old 09-25-2012, 06:51 PM   #377
View CHELLIE's Gallery13
Ambassador Award  100mph Speed Demon  Outstanding Contributor Award.
Friends: (281)
the protractor is just showing what 3 degrees looks like, its not to be applied as up thrust, we are just showing what 3 and 5 degrees looks like, then you apply that amount of down thrust to the motor, the down thrust helps to load the main wing to stabilize the plane, hope that helps, Chellie
the 5 mm depron will work great, brace the stabilizer where it attaches to the fuse at with balsa as in the picture, foam alone is not strong enough by itself.
Old 09-26-2012, 05:28 PM   #378
romanxdsouza
hey chellie ,check the diagram i drew is it correct 3deg but down from fuse,to brace the stabilizer where it attaches to the fuse how many mm balsa should i use ,i have ordered for 5mm depron and will use it to build all parts of the ss,another question i had was is the battery fine jst behind the motor as the fuse is of TWO parts please have a look let me know,planning to put servos behind joint as i will b dismantling it as in the pic below
ID:	162853 this is the joint
ID:	162854 battery behind motor and esc bellow
ID:	162855 servo holder will cut accordingly after screwing them
Old 09-26-2012, 09:04 PM   #379
Friends: (281)
Hi The battery placement will depend on the CG balance point, the CG will be at 25% back from the main wing front leading edge, you will need to move the battery or wing fowards or back to get the Proper CG. the Plane will tell you where the down thrust wants to be at, start at 3 degrees down thrust and adjust if needed, you cant use MM to get the down thrust, you need to use degrees, you can Eyeball the amount of degrees by using the protractor . like i said, 3 degrees is not very much.
Old 09-26-2012, 09:07 PM   #380
Friends: (281)
just add 2 washers on the 2 bottom holes to lessen the amount of down thrust on the mount that you already have,
Old 09-27-2012, 03:03 AM   #381
romanxdsouza
got u thanks for ur reply waiting for the foam now,to brace the stabilizer where it attaches to the fuse how many mm balsa should i use
Old 09-28-2012, 04:03 AM   #382
romanxdsouza
more questions chellie
1-to brace the stabilizer where it attaches to the fuse how many mm balsa should i use
2-need ur help making under cambered wing 48inch polydihedral with ribs wanted to knw if i hav to put a rib between the wing cords and the dihedral breaks ............where the arrows are pointing below in the pic below
Old 10-01-2012, 06:51 AM   #383
romanxdsouza
hey chellie ,ive recvd the depron found out that 48 WS is to to big max i can make wing span is 34inches will it work with my electronics if YES,then what size elev and rudder to go for or should i stick to the same, i want to make only ss i love the way it looks
Old 10-01-2012, 06:46 PM   #384
Friends: (281)
make the wingspan 36" and you can make the tail feathers the same size as in the plans, hope that helps, Chellie
Old 10-02-2012, 05:54 AM   #385
romanxdsouza
thanks chellie ,do i keep the fuse the same size 34inch ,please reply to my last post #382 if possible,do i put the wing tip rib also.i can start my build after this info.....thanks again
Old 10-07-2012, 02:29 PM   #386
romanxdsouza
Old 10-09-2012, 03:42 PM   #387
romanxdsouza
chellie
,i want to learn to use a flight stimulator on my futaba transmitter t6ex , how do i download it for free online, cant find 1 where i stay, and how is it connected to my laptop
Old 10-10-2012, 03:24 PM   #388
romanxdsouza
hi chellie, dint do polydihedral was ver difficult to shape for the first time depron 5mm, secondly coudnt find the best glue hear used hot glue every were but its quite strong,waiting for basswood for le and te and servos, first build so a bit messy and heavy
Old 11-04-2012, 07:39 AM   #389
romanxdsouza
chellie thank u for ur help,long time no replies nway this is d plane i made this was the madien , ,had 2 crashes b4 this mud went in the motor,now ive made another plane to protect motor n learn to fly once i learn ill go lighter pics below of the new plane
Old 11-04-2012, 09:08 AM   #390
Friends: (281)
Yea it flew good job, just keep it away from the side of the house when Landing Take care and Have Fun, Chellie
Old 11-08-2012, 10:16 AM   #391
romanxdsouza
chellie help again were can i post this ,this guys a fraud in india..........http://www.rcelectronicworld.co.cc/p...l-sources.html this guy dhiraj rajendra jadhao is a cheat,i ordered for 5 sheets of depron was charged 1400rs,from pune - mumbai recieved it in pieces ,check .pics below on delivery day along with the guy who delivered it,he said he will send new sheets its been 2 months now i have not recieved it,he doesnt answer his phone even,guys from mumbai here a good place to buy heres the adress...abdullatif habibbhoy 196 abdul rehman street,400 003 tel 23425314..........per sheet 60rs thats 6mm sheet around 72inch x 26inch you can call and ask exact size
ID:	164012 the delivery guy
Old 11-08-2012, 11:51 PM   #392
Friends: (281)
Hi, I dont think posting that store here would do much good, just dont buy from them anymore, keep after them to resend, but dont expect to much, sorry you got taken for a ride, take care and have fun, Chellie
Old 11-13-2012, 08:02 AM   #393
romanxdsouza
cool will do so
Old 12-13-2012, 03:55 PM   #394
Rockin Robbins
Rockin Robbins's Avatar
Friends: (7)
It sure has been fun watching your progress, Roman. Don't get discouraged!
Rockin Robbins is online now
Old 12-18-2012, 07:58 AM   #395
romanxdsouza
hey robbin and chellie im not discouraged!.im working on a slow stick again with alliminum fuse removable wing, if it flies will post videos, till then fingers crossed,i am looking for a good combo for my futaba rx r6106hf futaba recievers Size: 0.85 x 1.53 x 0.48" (21 x 39 x 12mm) Weight: 0.24 oz (6.7g) Voltage Range: 4.8 - 7.4V ,looking for prop ,motor,esc,battery to plan a good small 24inch wing span like a hangar rat, please let me know if u have any info on it,im doing my research as well
Old 12-21-2012, 03:06 PM   #396
romanxdsouza
Default heli motor friends scratch built plane
this is of heli motor madien a friends bulid http://www.youtube.com/watch?feature...&v=rayYljVSL9k
SUPER Quick Delta Scratch Build CHELLIE Delta & Flying Wings 894 10-03-2011 06:36 PM
SUPER Quick Rifle Stock Video Camera Mount Build CHELLIE Aerial Photography 32 11-14-2008 04:11 AM
DR1 - fun slow flyer - scratch build - hillbille Foamies 34 02-20-2008 08:02 PM
Slow Stick on the super cheap - build log Merlin ParkFlyers 51 02-14-2008 01:18 AM
slow stick quick-change floats pcs2007 ParkFlyers 0 02-05-2008 05:06 PM
Page generated in 1.82377 seconds with 88 queries
