Old 02-17-2017, 12:33 AM   #1
rabbithill17
Default Battery Chargers?
So I'm looking around for an rc battery charger but i'm just a bit confused.
I want one for my batteries: Power Cell NiMH Battery - 3000mAh 8.4V 7S iD Stick. I looked through: http://rcjudge.com/lipo-battery-charger/
Would the Tenergy TB6 be a good fit for them? Can anyone give me any pointers?
rabbithill17 is offline
Old 02-17-2017, 05:50 AM   #2
Past President of PSSF
Friends: (8)
There are several types of batteries used in RC
NiCad-- nickel cadmium
NiMH -- Nickel Metal Hydride
Lipo---- Lithium polymer
Life ----Lithium iron
+ others not real common
All take different chargers,
The nickel types are close enough to be charged on the same type, but maybe should have slightly different settings. the most common chargers use a voltage peak sensing system. The voltage across the cell or battery (a pack of cells usually in series) drops slightly after the cells reach full charge, then the charger shuts off.
Lipo's and LiFe again are very similar, but don't charge without the correct settings on a good charger. They must be charged by a voltage controlled system.
Usually the charger puts out 4.2 volts per cell and the current tapers off as the battery gets close to full charge. At 4.2 (Lipo) the charger shuts off
These are really short versions of how the chargers work.
I gave you this because the battery you have is a NiMH and the charger I found on your link is for Lipo's. I can't tell if it has NiMH functions. I am not familiar with it.
You could charge your batteries with any good charger made for, or has NiMH functions.
Do not charge it on a Lipo only charger.
I hope I have helped some, The field of batteries and how to use and charge them, is a big and confusing area. If you have more questions feel free to ask.
Dave R, Proud PGR rider.
http://www.pugetsoundsilentflyers.org/
Wildflyer is offline
Old 02-17-2017, 06:12 AM   #3
Friends: (18)
In budget terms there is little to beat the '6' range of chargers ... as they are priced to sell ... cover literally any battery you would have ...
I like the Accucel 6 80W charger ... all in for about $30 .... will charge :
NiMH
NiCd
LiFe
LiPo High Voltage
LiPo
Lead Acid sealed and unsealed
LiIon
Not bad for a $30 bit of kit !!
Check out Hobby King for it.
https://hobbyking.com/en_us/turnigy-...v-capable.html
It will need a reasonable power supply to power it ... I suggest a 15V 10A as best ... or at least a 12V 10A at minimum to be able to supply the required watts. Ebay is full of them for $10 to $30 depending on watts.
Old 02-17-2017, 02:52 PM   #4
rabbithill17
Thank you! This helped so much. You are correct. I hadn't even noticed.
I looked around and found some more information thanks to this. I really appreciate the help!
Old 02-17-2017, 02:52 PM   #5
rabbithill17
NiMH
NiCd
LiFe
LiPo High Voltage
LiPo
LiIon
Thank you! From your suggestion I decided to get this
Old 02-17-2017, 03:15 PM   #6
Friends: (18)
OK ... nice ... and the price is not so high that if you want to move up in power later - you haven't spent so much.
Its a great charger in the car as well ...
Just remember that you need an XT60 plug to connect your power supply to it ... I just cut the usual plug of a power supply and fitted the XT60 in its place.
Old 02-17-2017, 05:00 PM   #7
Friends: (8)
I have this one from Hobbyking. I find it very easy to use. 250 Watt and up to 6 cells, $44.00 + shipping in the US
You can set a charge current, and it will sense the cell count, and charge accordingly, I have a very similar Venom, that does not do this.
This unit is becoming my standard charger, I will buy another soon.
I want the 1000 watt unit someday.
I really like the foam cut program, it regulates the current through the cut wire keeping it just right regardless of length.
I have a home made feather cut machine.
https://hobbyking.com/en_us/turnigy-...e-charger.html
Old 04-07-2017, 11:18 PM   #8
View Panther's Gallery6
My first charger was the Turnigy Accucel 6 but sometimes the buttons needed to be pressed several times before they worked. So I bought a iMax B6 by Sky RC and thought it was pretty good until I realized it just wasn't charging my batteries properly. It is less than 2 years old and I have Junked it. 'Funny thing is, now my Accucel buttons are working fine.. ?? Maybe it had its' nose out of joint when I bought the B6.
Anyway, long story. I couldn't keep up with charging batteries as I use quite a few when I go out so I looked around and most of them are to damned expensive for what you get.
I settled on one that can do 2 batteries at once although not as fast as some but cost was a factor.
TomTop was $10 cheaper than Banggood so I ordered from them.
I hope it will be OK. I already have a adapter for the 240V. It is AC and DC. I can use Ch 1 for my 3S and Ch 2 for my 2S batts.
http://www.tomtop.com/charger-adapto...808.1488644194
Old 04-08-2017, 01:29 AM   #9
dereckbc
No they do not. Icharger and FMA (Revolectrix) will charge any battery made today and tomorrow. Now you can certainly buy uni-taskers, but why? Only thing that varies is the Charging Algorithm, and any of the smart chargers out there can be programmed for any algorithm you want. Only real choice you have to make is what size do you want.
dereckbc is offline
Old 04-08-2017, 02:46 AM   #10
1kW
Friends: (7)
Why? Cost.
I don't have a short temper. I just have a quick reaction to B.S.
Rob
Old 04-08-2017, 03:23 AM   #11
Friends: (8)
I guess I should have said they take different charging protocols or methods.
When you change the settings on almost any decent charger, you are changing the basic type of charger in use. Yes they may all be in the same box,and use the same leads.
You can't charge Lipo's on a Nicad charger, The electronics inside take care of the different requirements, when you make the correct settings.
You know enough about batteries to know what I meant.
I have had guys ask if they could use a automotive car charger on their RC car. I'm not kidding.
I just want people to understand that our new high energy batteries, need to be cared for correctly.
Old 04-10-2017, 04:08 AM   #12
Update on my iMax B6. I did some research on youtube and found how to calibrate it. After a bit of fiddling it is now working again perfectly. Very surprised I must say.
New charger is already on the way anyway...
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 159 02-16-2016 12:56 AM
Spektrum DX8 transmitter Battery kyleservicetech RC Radios, Transmitters, Receivers, Servos, gyros 37 04-21-2014 10:28 AM
Page generated in 0.13295 seconds with 42 queries
